Question about GE Washing Machines
Installed a new circuit board, and the same thing, lights just blink on and off. Any help you can give would be greatly appreciated. RIck
  • 2 more comments
  • rick moran Sep 10, 2010
    Ge.. man. WLE4000b2www
    ser mf103905g
    quit by design
    Are you still working with me
    Its A GE washer ser no. MF103905G part no. WLE4000B2WW the name is quit by design
    So just start unplugging everything. can i still get back to you
    President:
  • 1,554 Answers
Please indicate the make and the exact model number of the machine before troubleshooting can push through and appropriate advice is given. You don't have to accept or reject and rate this post to add information or post comments and follow-up questions should you need further assistance. But accepting a solution does not stop you from communicating with an expert. You may continue communicating with the expert as long as you need assistance regarding the issue stated herein.
Posted on Sep 10, 2010
  • 1 more comment
  • Jahn27
    Jahn27 Sep 10, 2010
    We may not be able to help you without the exact model number of the machine.
  • Jahn27
    Jahn27 Sep 10, 2010
    It is clear that the problem is not within the circuit board but rather in one or more of the components connected to it. Disconnect the components to see if the blinking goes out. If it goes out, reconnect the components one a time until you found the one that is triggering the blinking.
  • Jahn27
    Jahn27 Sep 10, 2010
    Yes. As what I've stated in my first post, you may continue communicating with me as
Hi, my samsung laptop has an intermittent charging problem i really need help with please. i changed the inside jack lead because there was a break in the wire, the new jack lead gives me power all...
this is a common problem with laptops as you are using a new ac adapter helps a great deal the problem lies in the dc jack on the mother board not an easy task it needs replacing
Mar 15, 2011 | Computers & Internet
Service Engine Soon Light
Engine light could mean many thing. There's about a 100 things that can make the light go on.
Best thing to do is go to an autoparts store and have them scan for the trouble code from the on board computer. Many autoparts store will do this for free. They should tell you what the trouble code means and you can start from there.
May 17, 2009 | 2001 Ford F250 Super Duty Super Cab
Ws55513 ticking noise and no picture after replaced caps
have you properly installed the back cover plate for the DM module, which has (apparently critical!) grounding straps essential to the proper functioning of the DM module - the DM might not be getting proper grounding. check it.....& let us know here..
Mar 16, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi ws55513
there is a small piece of a ground strap under the DM module that the metal case has to engage
Jan 22, 2009 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi ws55513
Hi and welcome to FixYa,
Appreciate the direct "Ask Me". My compliments on accomplishing the replacement of the 4 1000 uF/16V capacitors on the DM board.
To your concern, the blinking is still there even after having replaced the caps, a friendly reminder, the capacitors are polarized, there are specific +/-. Additionally, you may have to check the pico fuses. They would be on the backside of the DM board and would be very close near to the solder points of the 4 caps. They are marked FB900, FB901 and FB902. Rating would be 125V 4amp. Possible source maybe here.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Nov 24, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi ws55513 Blinking light -capacitors changed
check the resistor chips on the bottom side of the circuit board solderd directly to the traces one or more may be open.
Mitsubishi ws55513 Blinking green light- replaced capactitors
Hi again,
It would seem that you posted twice. My compliments on accomplishing the replacement of the 4 1000 uF/16V capacitors on the DM board.
Toyour concern, the blinking is still there even after having replacedthe caps, a friendly reminder, the capacitors are polarized, there arespecific +/-. Additionally, you may have to check the pico fuses. Theywould be on the backside of the DM board and would be very close nearto the solder points of the 4 caps. They are marked FB900, FB901 andFB902. Rating would be 125V 4amp. Possible source maybe here.
Justa start, do postback how things turned up or should you need additionalinformation. Good luck and Thank you for using FixYa.
Need Help big screen turns on thens goes off
The unit is going in to shutdown. Sounds like you have a short in the high voltage section.
Feb 18, 2007 | Panasonic PT-53WX52 53" Rear Projection...
Power light blinks
I would start with C869 a 2.2 Uf at 200 Vdc in the power supply. I have replaced a fair share of those in these sets. Of course the first thing to check would be the pico fuse in the power supply regulation circuits F860 a 4 Amp Pico Fuse and if it is blown, you will have to replace Q801 the Regulator IC Str-Z4214 Part # 23906369. If you're not that good at soldering and measuring capacitance and resistance, this would be a job for a more experienced tech.
Jan 24, 2007 | Toshiba CZ36V51 36" TV
Washing Machines Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
