Question about Kenmore 15202 Mechanical Sewing Machine
The first time the machine was used it jammed. I hadn't been touched since and as I was trying to determine what was wrong when I discovered that the shuttle hook basically falls out of the machine. Don't know if a part is missing that should hold it in place. The shuttle race cover and the latches are in place.
    Genius:
  • 1,788 Answers
Take it to your nearest Sears store and go right to the sewing machine department, they are usually very helpful and can tell you if it needs service or not. Take your manual with you.
Posted on Sep 11, 2010
The drop in bobbin on my Singer model 600 will jam up when sewing. It will be okay for a short time and than jam up again. It will cause the thread to knot up when sewing w/material. Help
may have to go into an authorized singer repairer for that problem..
might not just be the bobbin but the tension of the cotton winder for the bobbins
or needle pickup issue
Page 1 Instructions for Using Touch & Sewo DELUXE ZIG2ZAG ...
www.singerco.com/uploads/download/1310_600revised.pdfInstructions for Using. Touch & Sewo. DELUXE ZIG2ZAG. Sewing Machine. Model 600 by SINGER. T H E S ' N G E R C O NM P A N Y ...
Oct 11, 2016 | Singer Sewing Machines
I have a Singer sewing machine model 9117. Every time I use the zig zag stitch the machine jams and I cannot continue sewing. Any ideas?
try a new needle
make sure the top thread has not come off the thread take up lever
there could be something wrong with the cam that does the zig zag stitch, if the problem continues you may need to have the machine checked
Apr 07, 2016 | Singer Sewing Machines
Why is bobbin tread jamming on my husqvarna viking juliett sewing machine
Most of the time, you should rethread the machine, take the bobbin out and put it in again and change the needle. Generally if it is jamming under the fabric, it is because something is wrong with the top ie rethread the machine.
Aug 02, 2014 | Husqvarna Sewing Machines
Cutter on speedylock
Servicing the Timing is NOT a home fix
Mar 08, 2014 | White Sewing Speedylock 1600 Mechanical...
Presser foot does not lower.
I had the same problem ! I had to take it to be repaired, they had to take it apart & grease the whole thing, I hadn't used the machine in a couple of years & the original "grease" became too hard for the foot to come down.
Jul 06, 2012 | Euro-Pro 9105 Computerized Sewing Machine
Futura 150. Using autopunch. The machine does some of the
have you tried changing the needle?
it could be a part of the computer is mal-fuctioning
it could be out of time
it needs to be serviced to find out what's wrong with it.
Mar 22, 2012 | Singer CE-200 Quantum Futura Computerized...
I was sewing, turned the machine off to pin something, and when I turned it back on, it jammed in the bobbin area. It will only stitch one stitch and then jams. I have taken it apart over 30 times, and...
have you tried changing the needle-
1.the needle may be bent or damaged--try rolling the needle on a flat surface to see if it's bent or not
Correct needle insertion
Correct needle insertion is mandatory for proper use of sewing machine.
Raise the needle bar to the highest point, then loosen the clamp screw to remove the old needle, place the new needle in the clamp with the flat side to the back of the machine or if using a round needle--the groove in the needle should face away from the shaft.
Push the needle all the way up to the stop or as far as it will go, then tighten the needle clamp screw
2.upper tension may be to tight--try 3 to 5
3.thread may be hanging up in bobbin case--check area for loose threads or lint
check the thread take up lever-if the thread come off the thread take up lever that will jam the machine up--I've had it happen to me
Sep 13, 2011 | Euro-Pro Shark 9110 Sewing Machine
The thread is tight and it jams
try adjusting the thread tension
check to see if the top thread has come off the thread take up lever--this can cause the machine to jam
change the needle----if the needle is the slightest bit damaged the cause the machine to jam---also the wrong needle for the fabric can cause problems also
try rethreading the machine incase the thread is caught somewhere
make sure the bobbin is in correctly & it's not warped
if you've already done all these things & it still jams up then it could be out of time & would have to be serviced by a repair shop with the correct tools to time it
Aug 29, 2011 | Singer 1120 Mechanical Sewing Machine
Very inexperienced sewer! How do I thread it?
The way I solved this problem was to take a break! When I resumed I was more patient and found that I wasn't doing the bobbin right. I took my time and got it right this time....hooray!
Aug 24, 2009 | Brother XL-3510 Mechanical Sewing Machine
Kenmore 15202 Mechanical Sewing Machine Logo
44 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
