Question about Asko T721 Electric Dryer
T721 dryer drum not turning (like belt broke) is that the likely prob. and I can (I believe) fix if an exploded parts view is available (as well as the part). What say?
  • 2 more comments
  • gmcreamer Sep 11, 2010
    TO: Macmarkus
    FROM. GMCREAMER (George)
    Middle of the night here-these instructions seem perfect to me. Will tear down dryer tomorrow after taking grandchild back to her parents.
    Am retired (age 76) from Navy and General Dynamics (Engineering Specialist). Never worked on this type dryer (never heard of it until moving here).
    Will let you know results.
    george
    TO: Macmarkus
    My first look confirmed that the drum belt was brokenn (viewed from the front panel area. I then went to the rear, looking for the fuse, and to take the top off. Turns out that the back is different than your photos-the main power cable from wall 220V goes into the bottom of an enclosed rectangular box , with a small cover and a (what appears to be) 110V plug in cord running to the washer below. AND naturally i don't have the correct tool to loosen the torx screws-so I'm off to home depot to get the tool if I don't have it in my tool chest.
    the saga continues, thank you very much- gmcreamer
    TO: Macmarkus
    Now I am concerned! The part I just ordered from Repairclinic is the original Asko # 8052626.
    The model series I have is ASKO TD22, serial #051120211965.
    I found the proper tool for the screws-the terminal box cnotained 220v input to eqt., with taps to the washer 120v from one phase-leg of the input. This was all on a black fuse block, designated "control fuse" It appeared to be a self contained fuse block (ie. no fuse holder). No fuseholders or fuses were inside the chassis
    Request another rundown on the part numbers with the new info in para. one above.
    resp. gmcreamer
    To: Macmarkus
    The PDF info came thru ok, and the part is on order (hope it's the right one), due to arrive on the 16th. Then we'll see if I can follow instructions.
    I'll update you-
    gmcreamer (george)
  • Asko Master
  • 2,605 Answers
Welcome to FixYa.
I suspect you are fairly accurate in the belt broken theory, based on your description...provided the unit is starting ok otherwise, not often a motor goes bad in an Asko dryer.
If you haven`t already checked the fuses or hi-temp cut out, I would suggest checking those as well. I will touch on that after.
You can confirm of dismiss the broken belt theory easily by way of removing the top or the service panel in the front.
**Unplug the unit from the wall first before servicing, safety first**
If via the top removal...
1) remove the three #25 torx screws along the back top, this will allow you to slide the top straight back and up away from the unit. That should present you with this ( looking from the back )...
As you can see by this image, it will be obvious if the belt is intact.
OR, through the front lower access panel...
2) Remove the two philips head screws on either side of the panel and the panel should pull straight off. You should see this...
As with the previous image, you can now inspect the belt status and condition...perhaps with a flashlight/torch.
If the belt is broke it is relatively easy to replace. Let me know what you find. Belt original Asko part # 80 526 26, but subs to 1154685 and usually will come new with tension spring and instructions "how to" at "repairclinic.com"
To check the fuse and hi-temp safety/cut out, access is at the back and there is no need to remove any panels...yet.
The Asko fuses are located at the back directly below the cord entering the dryer...
i.e.
To remove them, simply use a small knife or flat blade screwdriver inserted into the horizontal slots and turn it 45° left or until the slot is vertical...
T721 dryer drum not turning - 9f5c348.jpg.
The fuse holder should "pop" out slightly to allow you to pullT721 dryer drum not turning - b7351c9.jpg way out...
i.e.
It is necessary to check them with an ohm meter or by way of installing a replacement 15amp slow-blow fuse.
As a technician I also make it a habit to remove the top and check the wiring leading to and from the fuse holder assembly..T721 dryer drum not turning - 1d6f6d9.jpgr /> i.e. these are in good condition, it`s ok to replace the fuses.
**In some cases the fuse holder and hub ( included in kit # 1460992 shown below ) become fatigued aT721 dryer drum not turning - e7a7586.jpg to be replaced should the fuse fail again in a short term.**
The individual fuses by Asko original are # 80 581 40, though you will likely need to by the complete kit unless you can go to a local electronics store and ask for a 15amp 250v slow blow in-line fuse.
Last but not least the safety thermostat, aka the hi-temp cutT721 dryer drum not turning - 0d17834.jpg located on the back wall under the small black "button" and is a manual reset with a simple push...
i.e.
As for a parts list and breakdown of your dryer, I do have them on my pc in adobe pdf, however they are too large to post here. If you wanted one you would have to post an email address in your reply where I can send it in the form of an "pdf" attachment.
Let me know how you make out and what you find. Good luck.
Regards,
Macmarkus :)
Posted on Sep 11, 2010
  • 2 more comments
  • Mark MacDonald
    Mark MacDonald Sep 11, 2010
    I'm just of to bed for the night too George. Let me know how you make out. The Asko are made in Sweden and I think you'll find are engineered quite well, they are one of my favorites for servicing for sure.
    Look forward to hearing what you find tomorrow.
    Regards,
    Macmarkus :)
  • Mark MacDonald
    Hello again George.
    Yes I see what you're talking about with the difference in design. Sorry, I was explaining the previous incarnation of the Asko the TD70 to TD 73 series.
    They are essentially the same as you will see by the photo's in my post with minor cosmetic changes and exceptions such as the terminal box.
    The part numbers should also be the same as per the fuses. The belt will be part # 8061961 but also subs to the number I gave you at "repairclinic.com".
    I do have the service manual for your machine though as well, as do I have the quick start guides.
    Keep me posted how you make out or if you have any further questions. Good luck.
    Regards,
    Macmarkus :)
  • Mark MacDonald
    Hi George,
    The serieal number indicates the unit was built on the eleventh week in 2005 as it starts with 0511...
    That indicates to me it is indeed the series I referred to in my previous post although Asko will use different numbers to identify where they are sold, i.e. Europe, South pacific, U.S.A./Canada etc.
    Can you email me at my windows live account and I will send you the files I have on your dryer ?
    macmarkus@live.ca
  • Mark MacDonald
    Hey George,
    I'm sure you'll be fine. Once you receive the belt let me know if you need assistance installing it.
    **NOTE** It is only necessary to loosen the back panel to fit the belt down the front...but we'll cross that bridge when we get there.
    Regards,
    Macmarkus :)
The dryer belt broke. I bought what I thought was the replacement belt but it is too large to fit the drum and tensioner pulley. Upon inspecting the motor, the shaft has a grooved portion around which...
You did not provide the model of your kenmore dryer so i can't provide the correct part # HOWEVER
you can go here:
http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080114x00001
and enter your model number and get exploded views of your machine, part numbers and the ability to order them directly from Sears
Feb 05, 2011 | Kenmore Dryers
How do i oil the belts? The dryer squeaks every time its turned on?
You don't oil the belts on a dryer. This will cause the belt to slip on the motor shaft and/or drum. Oil permiated into the metal of the dryer drum can ruin it causing any replacement belt to slip as well.
If the dryer is squealing, you probably need to lubricate the idler pulley wheel at the axle point (also known as a tension pulley). If this is a GE model they usually have drum slides and a drum bearing that support the front of the dryer drum as well. When they wear down, they begin to make noise. The drum slides are made of teflon and not only help support the drum, but ensures it turns smoothy. You may need to replace both the drum slides and the drum bearing.
If the model number is correct, the part numbers are as follows:
Drum Bearing - WE3M26
Drum Slide - WE1M481 (Blue), WE1M333 (White)
Replacement parts (if required) can be found at the following websites:
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The average cost of these components varies, so shop and compare. The first three websites I listed have helpful exploded view parts diagrams that can help you locate and properly identify the parts you need.
If you have any questions, or if your model number is different from the one you listed this question under, please post back and let me know. I hope this helps you.
Feb 24, 2010 | GE Profile Wizard DPSE592EAWW Electric...
The dry heats up great but the drum does not turn. Is the alot to fix and is it worth the money to fix this dryer
Good Morning, If the drum will not turn you may have a broken belt or one that's getting to the point of breaking. You can unplug the unit or turn the breaker off and remove the back. This will give you a view of the drum and belt. You can the plug it in being careful not to touch the wiring and see if the motor is turning or you will see the belt as it is rapped around the drum. If the motor pulley is not turning with the belt on, the motor is faulty. If it is turning and the belt is broke or having a rough time moving the tub it more then likey could be the belt, if it is not broke. If you determine that the motor isn't turning, then it may not be worth the $ to replace with labor + Parts. If it is the broken belt only, it may be worth the cost, you can call around.Take into consideration the age of this dryer also. I Sincerely hope this has given you some direction to follow.
Shastalaker7
Nov 27, 2009 | Frigidaire GLGR331A Gas Dryer
Older model dryer--drum will no longer spin. Need
The model number you provided is for a White Westinghouse. In order the access the internal cabinet to view the drum, you will need to lift the top panel. This is accomplished by inserting a putty knife along the front seam where the top meets the front of the dryer. About 2 inches in from each side is a small retaining clip. Push in with the putty knife and the top should pop free and lift up. The belt should be visible around the drum if it still intact. If the belt is loose, or missing, it has probably broken.
NOTE: The only way a belt will come off the drum while enclosed in the cabinet is if it breaks.
CAUTION: Make sure you UNPLUG the dryer before servicing. Dangerous voltage is still present inside the dryer even with it turned off.
To access the drum to replace the belt, you will need to remove the front panel. Remove the lint screen and lint screen cover in the door, first. Then, remove any screws holding the panel in place. The belt can be installed with the drum in place. Simply loop it around the drum first, then feed the remaining portion of the belt behind the blower fan housing and loop it on to the drive motor pulley and belt tensioner.
The part number for a replacement belt (if required) is 134503600. You can purchase a new one at any of the following websites:
repairclinic.com
Prices vary between these sites, so shop around for the best deal. The first three sites also offer very helpful exploded view parts diagrams you can use as reference. Repairclinic.com will have diagrams to show up how to properly route the dryer belt. Just click on the "Repair Help" link, followed by the "Dryer Belt Diagrams" link under the "Special Features" section. Refer to Diagram G under Westinghouse.
If you have any questions, or require additional assistance, please let me know. I hope this helps you.
NOTE: If the belt isn't the problem, please let me know.
Oct 10, 2009 | Dryers
The belt broke and i need to know how to put a new one on
The front of the dryer has to be removed to replace the belt. Best I can do is send a link to an exploded view. Unplug remove the top then the front slide the belt over the drum and make sure it will fit to the motor install the fromt tuen the drum by hand to make sure it turns freely. Slipthe belt over the motor pully turn again making sure it is smooth. replace the top and test the operation.
Aug 12, 2009 | Hotpoint Dryers
Kenmore Series 80
You can find an exploded view at Sears Parts Direct, as well as get P/N's for the parts needed. I suspect the roller assembly came apart which caused the belt to fail.
You will need your Model number to locate the exploded view. If you can not figure out the routing from that, then order the service manual from Sears. It will show the routing and describe how to assemble and test most all aspects of the appliance.
Jan 15, 2009 | Dryers
Dryer problem
I could be wrong, but I don't know of a dryer that DOESN'T use a belt to turn the drum. If the motor is turning on, and the drum is not spinning, more than likely your suspicions are correct and the belt is broken. You can find a replacement at searspartsdirect.com. Just type in the model number you have provided and look under the "Tumbler" heading for item number 5 (part #341241). The website also offers some helpful exploded view illustrations to assist in part location and installation.
Repairclinic.com carries the part at a cheaper price (item number 529597). Use the part number provided by the Sears website for your search criteria. Repairclinic also offers dryer belt installation diagrams. Just click on the "Repair Help" link at the top of the page and look under the "Special Features" section on the following page for "Dryer Belt Diagrams". Magic Chef uses diagram F. I hope you find this information helpful. Let me know if you have any questions.
Oct 26, 2008 | Magic Chef CYE4000AWW Electric Dryer
Ge dryer
you need to remove the front panel and kickplate (if you have one) This will allow you to detach the front of the top of the dryer and you can prop the top up while you replace the belt around the drum, down to the drive belt. Here's a link for your make and model. It shows an exploded view of the parts of your dryer. http://www.partselect.com/MultiModels.aspx?ModelNum=dde7100&searchTerm=&RefineSearch=0. This can help you figure out what parts you might need and how things go back together. Good luck!
Jul 14, 2008 | GE DBSR453EBWW Electric Dryer
Dryer belt replacement
Here's a URL to a website showing an exploded view of the parts in your washer, and I noticed that one of those drawings shows the proper belt path for installation: --> http://www.partselect.com/MultiModels.aspx?ModelNum=CDE6000&searchTerm=&RefineSearch=0 Hope this helps! :)
Aug 02, 2007 | Crosley CDE6000 Electric Dryer
Asko T721 Electric Dryer Logo
277 people viewed this question
Top Asko Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Asko Dryer Expert? Answer questions, earn points and help others
