Question about Coleman Pressure Washer PW0881800
What type of oil should be used with the pw0881801
What type of oil does the yamaha golf buggy use ?
Mike, Yamalube 4-cycle oil or quality SAE 10w-30 motor oil, is the oil for use in your cart. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
https://www.yamahagolfcar.com/ownersmanualdownload
what kind of oil 2 use
What Type Oil and Amount is used in Yamaha G22 Max Gas Golf Cart
What type of oil does Yamaha golf cart take
Aug 07, 2016 | Golf
What type of oil to use on a empisal d 270 and how put the oil
sewing machine oil ( from a supermarket or sewing shop)and just a few drops in the oil holes
Jun 20, 2016 | Sewing Machines
What type of oil does a 2002 jaguar x-type take? I was never given a manual.
The car takes 5w-30 semi synthetic oil. However, if you have never put synthetic oil in the car I would recommend using regular oil. I would also advise you check with your local jaguar dealer. The reason for this is if your car is not use to that kind of oil from day one it could cause seal leaks.
Jun 15, 2011 | 2002 Jaguar X-Type
Which oil type should i use for 1996 mercedes-benz c-class
1996 Mercedes Benz C Class
Engine Oil Type/Weight/Capacity
Application:
Oil for use in temperatures above 23 degrees
Note :
5 4/5 Quarts with filter change
945
Application:
Note :
Valvoline SynPower Full Synthetic
20W-50 Motor Oil
Hope helps (remember comment and rated this).
Jun 24, 2010 | 1996 Mercedes-Benz C-Class
What oil type to use when changing engine oil in a c50 boulevard?
Standard oil to use id SAE10W30 or SAE 10W40.
If you are still in doubt go to your local motorcycle dealer and ask the question as the normally are willing to tell you the oil type for your particular bike. Good enough?
May 21, 2010 | Motorcycles
I CANT HAVE THE FACTORY OIL TYPE IN MY COUNTRY, CAN I USE ANOTHER TYPE? AND WHAT IS THE TECHNICAL NAME ? MY COMPRESSOR IS GA30 ATLAS COPCO TYPE.
Most air compressors will run fine using 30 weight non detergent oil.
You could drop the manufacturer a e-mail.
Your compressor shouldnt use a lot of oil ... maybe you are in need of some repair? New rings or bearings or seals?
Feb 23, 2010 | Air Tools & Compressors
I have KYMCO S 200 and need to know what needs serviceing at 300 miles. What type of oil to use in engine and gearbox and what type filter if needed.
At 300 miles the only thing you might want to do is check the gearbox oil level and then lube and adjust the chain. Check with the dealer on the filter type. As to what type of oil, use 10w40 motor oil in the gear box. Don't use any synthetic oils, oil marked "EC", or oil with "special" additives. Stick with the major brands; Pennzoil, Quaker State, Mobil or Shell. If in a hot area like Texas or New Mexico go with 20w50.
Please rate my answer. Thanks!
Oct 27, 2009 | Kymco People S 200 Motorcycles
I need to change my oil what type of oil do I use?
Look in the owners manual that's in the glove box, that will show what type of oil to use.
In case you don't have one
Moderate climate----- 5w/30
Hot climate----10w/30
Oct 01, 2009 | 2007 Chevrolet Tahoe
What type of oil I use
The Remington manual for model 111409-01 states: "This Pole Saw requires lubrication only to prevent rust on the guide bar and saw chain. The saw chain provided is pre-lubricated at the factory. With each use of the Pole Saw apply a small amount of lubricating oil directly to the saw chain (see Figure 8). The oil will distribute itself around the chain and guide bar groove during use?preventing rust. We recommend using SAE #30 motor oil for lubrication and rust prevention."
Aug 08, 2009 | Remington Polesaw Wizard
When changing the oil, how many quarts and what type of oil is used?
Most engines have it stamped in block ,beside oil fill hole example 3600ml..read on oil bottle should say 936 ml on quart bottle.Most suzukis over 750cc use 3.9 quarts of oil. DO NOT USE SYNTHETIC OILS..will cause clutch slippage ..Also look under seat,most bikes have a sticker with oil capacity,filter type,spark plug type
Jul 25, 2009 | 1998 Suzuki VZ 800 Marauder
Coleman Pressure Washer PW0881800 Logo
73 people viewed this question
Top Coleman Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Coleman Garden Expert? Answer questions, earn points and help others
