Question about Honda Pressure Washer PSI 3000
11 hp honda pressure washer engine won't start. No spark at the pkug, bought a new coil and still no spark. This sysem only has a coil off the fly wheel and the spark plug. I even changed spark plug. Use the unit the other day, shut it down and on restart it won't start. Also, I disconnected the kill switch and the il lvel sensor so nothing was going to ground.
    Problem Solver:
  • 18 Answers
If you replaced the coil,check the wire and boot,check with meter for continuity.could be loose connection to spark plug
Posted on Sep 20, 2010
Honda 5 HP OHC Engine
did mice chew threw the wires to the coil over the winter pull the cover and look
Apr 07, 2012 | ALL POWER AMERICA LLC AllPower America...
Have a honda 11 horse on a north star power washer that has no spark,yes the switch is on.
Cause of no spark can be determined by process of elimination. Good to have a new sparkplug on hand to eliminate plug as fault. So start by replacing plug with new or test plug on mower /edger etc. for spark. If plug ok, then temporarily remove the wire connected to oil alert system (oil alert will ground coil if oil low or dirty). With oil alert unpluged, and no spark suspect sparkplug boot or coil. The sparkplug boot threads on to the spartplug wire and is what actually fits-on to the spark plug. You can test the coil by removing the boot and inserting piece of paperclip wire, or small screw into end of the coil wire and hold close to engine ground while pulling rope. If still no spark suspect coil. If spark, replace the boot. Good luck with repair.
Jul 04, 2011 | Northstar Garden
I have proplem start the engine i check the spark from the coil to sparkply and i find out no spark so i order the coil and i steal have a problem , the kill switch is working ok. Thanks for any...
Have you put a new sparkplug in. Also check that the oil level is full. If still no go, check the spacing between the coil and flywheel.
Nov 08, 2010 | Honda 8 HP Engine
Honda engine will not start,,,new plug, new gas, new oil
Karcher Model G2650 OH with Honda 6.0 HP, GC 190 Engine. Engine won't start. New gas, has spark. Seems to flood instantly. Much gas in cylinder. Spark plug wet. Choke pulled out, power on. Oil OK. released pressure in line. Where can I down load a Honda Engine manual! Thank you !
Jul 06, 2010 | Karcher 2500 PSI Pressure Washer
New Karcher pressure washer won't start
replace the fuel carburetor filter and, or, your fuel tank filter
Aug 31, 2009 | Karcher 2500 PSI Pressure Washer
11 HP Honda engine won't start.
Ypu could try a canned spray called AERO START which is a chloriform based accelerant. Spray into air intake and start engine. If it doesnt start with this solution then there is a serious problem.
Ensure the spark plug is actually sparking .
Remove it from the socket and place near an earthpoint while still connected and turn motor over. If it sparks then tick that box.
Ensure the spark is strong rub sand paper over the element of the plug to make it bright and shiny
check the lead is in good condition replace if nescessary. A bad lead especially carbon fibre crack inside and become leaky causing poor spark or no spark. If this appears OK then tick that box!
Place a spray of Aerostart inside cylinder and replace plug start engine again. if it fails to respond it will need to be seen by a mechanic
Jul 22, 2009 | Garden
Won't start, new coil, weak spark,
if i remember correctly these have electronic ignition the module may need replacing but beforedoing any thing drastic try disconecting the oil alert wire that sometimes gives a bit of pain youdoit
Jul 20, 2009 | Honda 8 HP Engine
Honda Pressure Washer HP 5 not starting
You can try spraying some carburetor cleaner into the carb. If it starts for a minute, your carburetor need cleaning. When you added new gas did you remove the old gas first? Is the air filter clean?
Jul 18, 2009 | Honda 8 HP Engine
Honda GX340 11 Hp ..Runs fine until it gets hot , Cuts off and
FIRST...check the engine oil level. Some Honda engines have an oil sensor that shuts off the spark if the oil is low. This would also explain it shutting down when it get hot. Check the manual to see how to tell if the oil level is correct. Also, the oil should be brown and transparent, not black. It may need changing. Post again if this doesn't help :-)
Jun 01, 2009 | Honda Pressure Washer PSI 3000
Gas pressure washer will not start
I have a 5hp honda power washer sat for 2 years it will only run if I spray gas in the carb as soon as I stop spraying the engine stops I have took off carb and cleaned it
May 31, 2009 | Karcher 2500 PSI Pressure Washer
Honda Pressure Washer PSI 3000 Logo
1,391 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
