Question about Maytag Neptune MDE5500AY Electric Dryer
My dryer is not heating but everything else seems to be operating normally. Is it the heating element
  • Maytag Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Sounds like your problem may be with the heating coil. Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape or with an ohm meter to test the thermostat/thermistor. (Should have/show continuity)
If the coil heats up then replace the thermostat/thermistor.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
Please rate me
Posted on Sep 11, 2010
My whirlpool dryer 3394996 is about 10 years old or more and it wont heat up everything else seems to b normal
This is either a heating element (most likely and easy to replace) or it is one of your heat sensors. Should be three of them. Still very easy to replace and I would do all three at the same time rather than just the bad one. You can tell if it is the element by looking for a break in the wire on the element or pull it off and hook it direct to current to see if it heats(glows).
Nov 10, 2015 | Whirlpool Dryers
Dryer runs but doesn't heat.
The high and Low thermostatic limit switches must be in working order for the heating element to get power to operate. High limit opens in the event of a overheat condition to cut off the heating element. The low limit cuts on and off to control normal operation of the heating element for a more or less constant heat for drying.
Mar 18, 2014 | Kenmore Elite HE4 Electric Dryer
No heat
If everything else seems to work... try checking and resetting the dryer controls to a setting you do not normally use i.e. if you normally set it for hot try the warm or Permanent Press setting. Try something other than the normal setting as this will help indicate if it is the controller or the heating element.
Feb 02, 2011 | Maytag Neptune MDE5500AY Electric Dryer
CLOTHES DRYER HEATING ELEMENT
The heating element is SUPPOSED to cycle on and off. That is normal. There is an Internal Bias Thermostat and a Hi-Limit Thermostat that help regulate the internal operating temperature of the dryer. However, if you are experiencing longer dry times, or poor drying efficiency, the following link can give you some things to check before you assume there is a malfunction with your dryer:
http://www.fixya.com/support/r3578821-dryer_takes_too_long_to_dry
The number one cause of dryer heat related problems is poor exhaust ventilation. If not vented properly, a dryer will not dry efficiently, will actually take longer than required to dry, and will cause the heating circuits to overheat to the point of failure. The dryer will actually seem hotter than usual in many cases and the heating element will appear to glow brighter as the heating circuits begin to overheat. This is also the source of many fire hazards if not resolved. Read through the link provided and review some of the potential causes.
If you have any questions, please post back with your MODEL NUMBER and let me know. I hope you find this information is helpful.
NOTE: If you thoroughly check everything and still have problems let me know. The problem could be related to a thermostat beginning to fail.
Mar 15, 2010 | Kenmore 64742 Electric Dryer
My heating element stays on for about 15 sec at a time-is this normal?
Is is normal for the heating element to cycle on and off. The element is usually protected by an operating (or hi-limit) thermostat that helps regulate the internal operating temperature. The element is not supposed to stay on continuously or you could end up with a scorched clothing, or a fire hazard. As your clothes get dryer, the heating element should cycle less. As long as you are not having any problems with dryer performance, you shouldn't have anything to worry about.
However, if your dryer is heating, but you are experiencing longer dry times or poor drying efficiency, the following link can give you some things to check before you assume there is a malfunction with your dryer:
The number one cause of dryer heat related problems is poor exhaust ventilation. If not vented properly, a dryer will not dry efficiently, will actually take longer than required to dry, and will cause the heating circuits to overheat to the point of failure. The dryer will actually seem hotter than usual in many cases as the heating circuits begin to overheat. This is also the source of many fire hazards if not resolved. Read through the link provided and review some of the potential causes.
NOTE: If you thoroughly check everything and still have problems let me know. The problem could be related to a thermostat failure.
Mar 12, 2010 | Dryers
My frigid air dryer turns on and tumbles but will not heat up. We are doing renos and the duct(ing) is not connected to the dryer vent. Is that the cause? thanks.
No probably not the reason for not heating, what comes to mind first is check for proper 220/240 voltage is getting to the dryer, a dryer will run and seem to operate normally evn with getting only 110/115 volts but that is not enough power to energize the heating element to heat the air blowing into the dryer,or you may have a failed dryer heating element. Good luck !
Nov 30, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Dryer won t heat 100 74732400 model
dryer element. Common problem easy repair.
Jun 07, 2009 | Kenmore 74732 Gas Dryer
Everything seems fine but will not heat up I checked continuity, on every thing and it seems fine and I did the more less more less and all codes came up fine took the heating element out and it seems fine...
First things first...Are you sure that you have 220 volts to the dryer? Just because the motor runs doesn't neccesarily mean you have the proper voltage. Also check the connections where the cord comes in to see if they are tight and intact.
Apr 06, 2009 | Kenmore 63942 Dryer
Problem with my Kenmore 62622 Electric Dryer
It could be the elements inside dryer, one or more could be bad, the different settings causes the dryer to do different things, so whatever your setting on ultra dry may not be operating at full force. Hope this helps.
Sep 06, 2007 | Kenmore 62622 Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
42 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
