Question about Sony Alpha DSLR-A100 Digital Camera
My Sony A100 gives me an error message Camera error 0x32 What is it and can it be fixed?
Sony DSLR-A100 eroor 0x58
Well, the good news is that there's probably no fault with the camera itself. It could be something as simple as the CF card being pushed in the wrong way. A look through the user manual will likely help you get to the bottom of your issue:
Sony Alpha DSLR A100 manual
Aug 13, 2014 | Sony Alpha DSLR-A100 Digital Camera
Error code when using the built in flash
try to remove first the battery for an hour., to reset all the save setting's.
Let me know here again.,,
micro
Jul 29, 2008 | Sony Alpha DSLR-A100 Digital Camera
Does the error happen each and every time you take a snapshot, or only with some? As you are letting us know, have a look around the user manual to see if it can be of any help:
Sony a100 error 56
The Error code indicates the Self diagnostic message of the Camera. This message can be clearly identified by the help of a Sony Authorized service technician. The
Error code 56 indicates an issue which can be resolved by the help of a service technician. This error code may be an issue with the Shutter mechanism. Try resetting the Camera by selecting the Reset Default option in the Setup Menu 3 option. Also, try removing and reinserting the battery after 1 minute. If not resolved, get the unit serviced.
Thanks.
Oct 21, 2010 | Sony Alpha DSLR-A100 Digital Camera
Error code ox5b Sony dsrl-a100
Thanks ... but found a person who help me for free.
Jun 10, 2009 | Sony Alpha DSLR-A100 Digital Camera
Sony a100 keeps locking up and giving an error cod = 0x57
Try turning the camera off, take the battery out, reinsert it. If that doesn't work, the manual says to contact your local Sony dealer. You might also want to try taking the lens off, making sure nothing is hindering its communication to the camera body. Try using another lens if you have one.
Jan 10, 2009 | Sony Alpha DSLR-A100 Digital Camera
Sony Alpha 100 gives error message when attempting to take pic.
Hi! I just had the same problem with my Sony A100, when I tried two different CF cards. I was getting the same error message as reported above: "Unable to use card" then "Format?" then that format fails. Thinking the camera is broken, I checked online camera repair sites and also called Sony directly. Sony's flat rate, and that of PrecisionCamera is $228 to fix CF card failure. Then my daughter said, "the CF card in my room works fine in the camera" - and lo and behold - it does. The CF card that works is brand PQI and is marked Hi-Speed 60 2Gb. The cards that do NOT work are marked SanDisk Ultra II 1.0Gb and SanDisk 128 Mb. So my advice is, before you give up on the camera as broken, try a number of different CF cards first.
The second cause of CF failure is if someone has pushed a CF card in the wrong way. That can bend one or more of the tiny metal contact pins in the CF socket in the camera. Look carefully to see that all the pins are straight up. [I don't know how one can straighten these pins, or if the whole socket would need to be replaced...but at least you can determine the cause of the CF failure.]
Best regards - Michael
Jan 07, 2009 | Sony Alpha DSLR-A100 Digital Camera
Sony DSLR-A100, error code 0x5b
Same here. My camera gives me the same error code unless I shoot with the largest aperture/smallest F-number.
Mar 28, 2008 | Sony Alpha DSLR-A100 Digital Camera
Sony Alpha 100 won't acknowledge memory card
I would suggest that you give the camera to Sony service to have a look at it. The regular shop would not have the proper test facilities to properly diagnose any in depth problems with this type of camera unless they were an authorized contracted service rep. The problem may be involved.
Jerry G.
Feb 23, 2008 | Sony Alpha DSLR-A100 Digital Camera
ERROR CODE 0x5b
This error message is an indication that a problem may have occurred with the aperture assembly in the camera. To resolve this issue, service will be required.
Feb 03, 2008 | Sony Alpha DSLR-A100 Digital Camera
Sony Alpha DSLR-A100 Digital Camera Logo
99 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
