Question about Alltrade Tools & Hardware - Others
My Alltrade #481017 206 pcs Rotary Tool will not start. When I turn it on nothing happens. Worked the last time I used it some time ago. Any suggestions?
snakehead
  • 1074 Answers
SOURCE: tv will not turn on
your tv needs to be repair again power supply problem or circuit.good luck.
Posted on Apr 04, 2007
SOURCE: Tv won't turn on
I had a similar problem when there was a power outage or the lights went briefly out. I unplugged the TV and left it for a few days/weeks and then plugged it in and the TV worked. I think newer TVs should be treated like a home computer and put them on surge protectors.
Posted on Jul 08, 2008
SOURCE: Motorola, M25, orange-Won't play
Likely not new but worth the try. Had reviewed various other POSTS, and suggestion to take out battery and let sit for a while. Often cures unknown ills. Took out the new battery that did not work, let it sit overnight, put battery in again next morning and it booted up. This was done after, changing three batteries, after taking in/out the SD card (no real reason, but figured why not) and, after a subtle BANG on each of the corners of the unit......
Posted on Nov 07, 2008
SOURCE: weed wacker worked fine a week ago. tried to start it up today and nothing happens. I followed step by step instructions and still got nothing. Only had it a year and only used it three times.
I have a two month old red max weedwacker that just decided to start shutting off when i give it gas. I hold idle no problem. Aircleaner=good, spark=checked, primer=good, dumped fuel and got same problem, I am upset because when redmax hit the scene with the backpacks they were solid. I just replaced a magneto on a year old red max blower and I am waiting on a crankshaft for a redmax set of gas shears: I hit a fence and in the past with other companies shears that was not a major problem. The redmax shears crankshaft broke and sheared two bolts of hardened steel on an irregular, recessed angle in the aluminum housing. After shelling out 450 bucks i am not the happy camper. I went old school and bought electric little wonders--know what: I forgot what a pleasure they were: light and no fumes. Any helpon the whip would be greatly appreciated. TOM 39 accounts long island ny
Posted on Jul 11, 2009
  • 56 Answers
SOURCE: 2003 Chevy Impala periodically won't start
Try under the dash, attached to colum is a switch that the rod goes into from your ignition key switch, that may need to be adjusted tword your steering wheel just a touch, they go out of alignmnet from time to time
Posted on Sep 15, 2009
Using craftsanrtary tool model#572.610520 and it went dead is it fixable?
Probably not. They're not built for very heavy use - it's really easy to burn out the motor.
You might try a Black & Decker RTX tool next time - they seem to last very well.
Aug 13, 2014 | Tools & Hardware - Others
Should I be lubricating my dremel (395) tool?
Just a comment-Based on experience, I would go with BOTH their suggestions and order brushes and bearings. That squeal is definitely the bearing; it is a sleeve bearing; RPMs too high for a ball bearing to last and the sleeve bearing has a solid lubricant cast into it.
Dec 16, 2009 | Dremel 395 Variable Speed Multipro Rotary...
Will not turn on
With the power cord getting hot it sounds like there is something up with the power supply section. Perhaps a faulty transformer or something.
Sep 18, 2009 | Aiwa PX-E860 Turntable
My camera won't turn on either....
Either the lens is out of alignment, or the CCD or worse has gone defective. Either way it sounds like it may be worth it to just purchase a new camera. You do always have the option of repair as well.
Thanks,
Lee
Jul 11, 2009 | Vivitar ViviCam 3935 Digital Camera
Ball bearings fell out of the area where the ''chuck'' is attache
Call Alltrade Tools customer service so they can provide you with a replacement drill. Call 1-800-423-3598, give them your model number for a replacement.
Per "Ask Carl" of Alltrade
Nov 18, 2008 | kawasaki 19.2V 4 Piece Cordless Tool Kit
Printer wont print
may be if u can try to tell me the name of the product i can help u out
Sep 04, 2008 | HP DeskJet 710c InkJet Printer
Tv will not turn on
Apr 04, 2007 | Toshiba 37HLX95 37 in. LCD TV/DVD Combo
Tools & Hardware - Others Logo
Top Alltrade Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you an Alltrade Tool and Hardware - Other Expert? Answer questions, earn points and help others
