Which wire on the woofer is the postive - Audio Players & Recorders
    Champion:
  • 271 Answers
Hi, On the woofer the red connection or the larger connection is the positive. styluscity@gmail.com
Posted on Sep 13, 2010
Car dies when postive cable is left on
Check the postive wire to the starter and to the fuse box there is a fusable link in there that is burnt or a wire that is burnt in half causing a short.
Nov 28, 2012 | 1999 Ford Contour
Alternator wiring connetion fo 82 rabbit
One wire should go to the battery and one should go to the starter.
Dec 24, 2011 | Cars & Trucks
Is the black wire negitive and white wire postive
The Black wire is the Hot or positive wire and the White wire is the nuetral or negative wire.
The green wire gets hooked to the frame or any metal part of the dishwasher...usually there is a green screw inside the little box where the wires hook up
Heatman101
Apr 15, 2010 | Bosch SHU9925UC Built-in Dishwasher
What is a suitable gale gold woofer replacement?
Really does not matter the point is you can rebuild the woofer for less then replacing with a new one but to each his own on this. But as long as its the same size anything would do for this monitor speaker.
I do not mean to sound generic but its true a woofer is a woofer it is what it is sure there are brands out there but they all work basically the same.
All your doing is buying the name.
Thanks please do click the thumbs above to give me a postive rating for my efforts today,
Feb 13, 2010 | Gale Gold Monitor Speaker
How do you hook the wires into the back of the speaker so that the voice coils will function corectly
Without knowing what voice coils you have on your sub and what ohm load you are trying to get your amp to, there is no way to tell you the exact way you will need to wire your solobaric. Heres a great link that will show you all the different variations you can use and the resulting ohm loads: http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=1&I=12
Sep 28, 2009 | Kicker S15L7 Car Subwoofer
Speaker errror message
The usual fix for "Speaker err" message is to simply unplug the sub-woofer power cord to reset the speaker diagram, plug it back in and remember to "match the negatives to negative, positives to positives" and never try to replace the original speakers with anything but equivilent speakers, adding on more speakers can cause the "Speaker err" message and an inoperative system.
Jan 21, 2008 | Audio Players & Recorders
Subwoofer
Hi yeahonda,
Your Kicker L7 Ohms may be too low for the MA Audio Mono block amp. The MA Audio Amp is probably 2 Ohm Stable. The kicker will either be 2 ohm or 4 ohm Dual voice coil.   To eliminate the low ohms as a possible threat to causing the map to go into Protect, Wire the kicker Voice Coils in Series.  This adds the ohms, so that you either have 4 or 8 ohms.
I am using the following codes to show wiring. VC1+ stands for the Kicker  Subs Voice Coil #1 Postive post. AO+ is the MA audio Amp output positive.
AO+ to VC1+
VC1- to VC2+
VC2- to AO-
This shopuld give you 4 or 8 ohm depending on the 15" L7 setup.  Crutchfield does not carry the Kicker  L7 in 15" They do  have the L5 in 15".
If you know how to read a Volt Ohm Meter, set it to OHMs 20 and measure across VC1+ to VC1- and you should see between 1.5 and 5 ohms..  Do the Same with VC2+ to VC2-.  you should see the same voltage. Also read from the Voice coil metal housing to VC1+ , VC1-, VC2+, and VC2-. and you should not read any ohmage to the case. The meter should say OL, or -1.
Good luck.
Oct 15, 2007 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
60 people viewed this question
 Grubhead
Grubhead
