Question about Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k
User manual for bonaire airtech professional tire inflator
Wear can I buy this
Refer your inquiry to Bonaire
Aug 29, 2013 | Bonaire Cordless Inflation Machine
CORRECT TIRE PRESSURE FOR REAR TIRE
From the Clymer
TIRE INFLATION PRESSURE (COLD)
Front 28 rear 32 add 4 for riding double(from the Clymer manual).
Tire inflation pressure for factory equipped tires. Aftermarket tires may require different inflation pressure.
Jul 03, 2012 | 1995 Suzuki VS 800 Intruder
I have the Bonaire Inflation Machine Model NRC12S,I've had it for quite a while and can't find the manual. I can never get it to work on high pressor setting. I've charged it for 3 days,makes noise when...
Manual says:
Turn Power Supply switch to DC12V or Battery position
Turn Inflator to High Pressure position
Turn off when you reach the correct pressure according to the gauge
and
Charge battery up to 13 hours, do not completely run down the battery.
Sep 15, 2010 | Bonaire Cordless Inflation Machine
Dashboard symbol horseshoe shape w/!...meaning?
I dont know if you are refer to one signal light like this...
If this is right, is the Tire Pressure Monitor Sensor (TPMS) o Tire Pressure Monitor Systems (TPMS) are being used on more and more new vehicles. Low tires are potentially dangerous, especially if a vehicle is heavily loaded and traveling at highway speeds during hot weather. A low tire under these conditions is a blowout waiting to happen. The inflation pressure of the tires should be checked regularly, but many motorist do not check their tires. That is why Tire Pressure Monitor Systems are coming into use.
Tires are designed to operate within a certain pressure range. The recommended inflation pressure can usually be found in the vehicle owner's manual and on a decal that may be located in the glove box or door jam. The recommended inflation pressure is designed to give the best combination of ride comfort, load carrying capacity and rolling resistance.
NOTE: The maximum cold inflation pressure on the sidewall of a tire is NOT the recommended inflation pressure. It is a maximum limit for the tire only. The recommended inflation pressure for most passenger car tires is 32 to 34 psi (cold).
Hope helps (rated this).
Jan 11, 2010 | 2001 Volkswagen Beetle
VULCAN BONAIRE Users manual.
Try here http://www.bonaire.com.au/support/documentation/owner/default.aspx
Dec 31, 2009 | Heating & Cooling
After flat tire, tire pressure warning will not go out even after making sure pressure is at 44psi. How do I reset dash?
44PSI?? is that what your car recommends...
1. check and make sure that your tires are inflated to the correct pressure
2. turn the ignition switch to the ON position. If the low tire pressure warning light comes on, push and hold the tire pressure warning reset switch (think the switch is in the glovebox, but not sure) until the warning light turns off and then release the switch.
3. now press and hold the tire pressure warning reset switch until the low tire pressure warning light blinks three times.
Aug 14, 2009 | 2006 Hummer H3
Tire pressure light is on even though all tires are inflated prop
You can reset the TPMS system on your Toyota Highlander. There are instructions in the owner's manual on how to do so. However, resetting the system without checking the cold-air inflation of the tires is not necessarily solving the problem. The recommended tire pressure inflation sticker is located on the driver-side door frame. On the Highlander, it calls for 30 pounds per square inch (psi) of tire pressure per tire, including the full-sized spare. If the Highlander had a donut spare tire, it will not have a TPMS sensor and subsequently will not effect the TPMS system one way or the other. To reset the TPMS system in the Highlander, there is a reset button under the driver-side dashboard that needs to be held for a period of time (a few seconds) while the ignition key is in the "key-on/engine-off" mode. The TPMS warning light will blink rapidly for a few more seconds, and the system will reset itself. Refer to the manual for the exact procedure. If the TPMS warning light reoccurs, have the system or tires checked by a professional. Good luck and hope this helps, keep me posted. Be glad to help.
Jun 19, 2009 | 2004 Toyota Highlander
Air preassure in victory scooter
Most electric mobility scooters with inflatable tires require a tire pressure of 30-35 psi (be sure to check the manual of your scooter for the correct tire pressure). Do not allow the tires to become under-inflated or over-inflated. Under-inflated tires could make the scooter unstable and over-inflated tires can burst under pressure. Also, you should manually inspect the tires periodically to make sure they haven't taken any serious damage that could lead to a flat.
Jun 15, 2009 | Pride Mobility Victory 3 Wheel Electric...
Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k Logo
1,116 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
