Hello, i have a zenith surround sound system model# ZH-T202SF. i have the system working with the dvd player but i am trying to connect it so i can use it when i watch regular television as well. the only options on the remote are dvd, band, and usb. how do i hook it up to use it with regular television? Thanks, Logan
  • 84 Answers
SOURCE: Connect DVD Player to logitech X 540 Surround System
Bad connection on that one speaker, if you have tested the system with other equipment and it works thn you MUST have a bad connection INSIDE you DVD player. If your DVD had a whole channel out on your output amplifier I beleive then 2 speakers would not work so more than likely you have a bad solder joint inside system for DVD output
Posted on Feb 11, 2008
SOURCE: hooking up system
how do i hook my dvd player throught the surrond sysytem
Posted on Mar 23, 2008
  • 20 Answers
SOURCE: surround sound ok whilst playing dvd but not working for tv
On your Sagem TV you should have two RCA ouputs (red and white connection usually marked ouput) ) Connect these to the input on the surround system using the interlink cable.
You should then be able to hear the sound from the TV by changing the SOURCE on the home cinema remote.
Better still if you have a digital out on your TV use that instead.
Posted on Nov 25, 2008
swufabuda
  • 219 Answers
Does your tv have audio out RCA jacks?
Posted on Jan 23, 2009
lynchms
  • 93 Answers
SOURCE: can't get surround sound for tv shows
The coby dvd 988 has 2 rca audio input jacks, you need to have these connected to your TV AUDIO OUT jacks, these are usually colored red and white like right and left stereo jacks, be sure to set up the TV for AUDIO output through these connections, some tv`s require that the internal built in speakers are cancelled and the audio output jacks are enabled. Set the coby input signal to receive the port you pluged the tv signal into.
Posted on Feb 06, 2009
Have lenoxx ht 500 surround sound speakers & dvd but dvd is broken, need to purchase another dvd player but can't source lenoxx model, what other models can i connect surround sound to? or whe
If your surround sound receiver unit has rca audio inputs(red/white), you can hook up any brand of DVD player that has rca outputs. You would hook the yellow output from DVD player to yellow input on TV. Hook red/white output from DVD player to red/white input on surround receiver. Hope this helps.
Jan 03, 2012 | Audio Players & Recorders
I cannot get the surround sound to come on tv mode on my friends RCA DLP. Any suggestions? is this a t.v. issue? DVDs and Ipod connections are fine.
The tv must have a stand alone audio output that you would connect the audio composite cables to going to the aux or audio input of the surround sound system. You may need to switch the surround sound system to aux mode or av input 1 or 2 and etc. If you are connecting a cable box or satellite tv box to this television instead of connecting the audio composite cables between it and the tv, connec them between it and the stereo surround sound system.
May 05, 2010 | Zenith XBV441
I have a JVC DVD player that doesnt come with surround sound but i have surround sound speakers is there something I can buy so that I am able to use the speakers
If you have surround speakers with a surround system, then connect the Player to the surround system using for example RCA cables (White and Red).
If you have speakers only, connecting many speakers to a non-surround system won't give you surround.
In surround systems the sound is controlled, elaborated and distributed through the speakers by a circuit.
If you wnt surround sound the alternatives are :
  1. Connecting a surround system (eg.Home theater, receiver) to the player (amp+speakers)
  2. Upgrading the DVD to one with surround.
Let me know if you need more help.
bye.
G.
Jul 17, 2009 | JVC KD-DV7300 Car DVD Player
Tv built-in dvd player wont play thru surround sound
goto your menue setings and slect sround sound and set up to external sound system.
Jan 10, 2009 | Toshiba LCDTV/DVD Player 19HLV87
I have an old Zenith Digital Surround System the Receivver is a Model Z763B with a DVD Player/Recorder connected. When I play a DVD or VHS the sound can be heard through the TV and the Sound System,...
I have the same A/V receiver and in my setup there is an audio output (red and white able) coming from DVD player directly into Zenith Z763B. The video from DVD Player goes to TV input (yellow cable).
There might be alternatives to the setup mentioned above but I like to watch movie in a surround sound, rather than output from TV.
Jan 07, 2009 | Audio Players & Recorders
Umi freeview dvd tv combo to surround sound
I am not familiar with the manufacture and model of your TV set. This does appear to be a compatibility issue between the TV set and its DVD player, and the surround speaker system. The TV set may not be able to directly send the proper information to the speakers. I would consider to call the manufacture support people to have a definate answer.
Jerry G.
Dec 28, 2008 | Philips 17MD250V 17.1 in. LCD TV/DVD Combo
Feb 11, 2008 | Logitech X-540 Computer Speakers
Surround sound help
A few questions... What components are involved? How are they connected? Can you hear sound from the speakers for any other input device i.e. radio, cd, vhs, etc.? I suspect that there is an issue with the way the system is connected. I have the Surround sound output from my DVD player connected to the digital surround sound input on my reciever. I'm using digital coax cable (looks like a "normal" RCA cable), not the optical fiber connection. I had to buy a special cable for the digital surround sound. A normal RCA cable would not work. I don't know why. If you're using a similar connection, that could be your issue. make sure that the output and inputs you're using are compatible. A digital surround sound connection (in or out) can't be connected to an analog connector (in or out). Remember, Digital to Digital with a Digital capable cable; Analog to Analog with an Analog capable cable. If this is not your issue, post back here with more info and we'll see what we can figure out.
Sep 05, 2007 | Zenith XBS344 System
How do i hook this to tv or digital cable to get surround sound?
Sorry to say, Circuit City is right. These cheap home theatre in a box solutions are very very shady. They put the DVD player, preamp, and reciever all in one little box. Not very handy to adding options or plugs but very very cheap to produce. Ever notice why large home treaters have about 5 big black boxes and a DVD player? This little box is trying to be all of them. If this was a reciever combo(as zenith wants you to think) then you could do EVERYTHING you were thinking would just make sense. Unfortunately, you trusted Zenith instead of Circuit City(gah i hate saying that). At any rate, if you still have receipt, return it!!!! I will help you pick a system to suite your needs. I do all the things you want on a system i got for 500 bucks.
Jul 23, 2007 | Zenith DVT216 System
91 people viewed this question
 Grubhead
Grubhead
