Question about Gemini SA-600 II Turntable
I need the dustcover to this turntable - Gemini SA-600 II Turntable
Looking for gemini turntable xl 600 dustcover hinge?
Fixya is unable to suggest sources for Gemini dust cover hinges.
May 26, 2018 | Gemini Audio Players & Recorders
Is the dust cover on the Technics SL-B101 , the same as the Technics Sl- D303?
Charles,
It took me about an hour to find this info for you. Problem is that you'd be taking someone's word for it. The answer came from a turntable forum where another person asked what other dust covers fit the pictured turntable (model SL-B303) Several people responded and if you click on this link:
http://audiokarma.org/forums/index.php?threads/technics-sl-b303-dustcover-hinges.348163/ , look at the bottom right hand corner of every response on that page.(they are numbered) and you'll see that #1 has the question about the cover for the SL-B303. Scroll down to response #6.
This person says that the SL-B101 and the SL-D303 use the same cover.
Where did he get his info from? It's a risk but if you find another person that says the same thing, chances are it's the right answer. Wish TECHNICS had some sort of official release so that everyone could see what covers fit which turntables.
Good luck
Jun 22, 2017 | Technics Audio Players & Recorders
Finding dustcover cap for gear on quantum BU670CX -g8
You would need to contact the manufacturer of the reel for any chance of finding this part.
Sep 24, 2016 | Fishing
How to remove Platter on JVC L-A120 Turntable
Hi Jeff...
The platter on the JVC LA-10 does not come off as most turntable platters do. It is attached to the spindle with a Philips head screw.
Here are the steps:
Remove dust cover from turntable. Unscrew hinges and lift.
00.jpg" alt="Remove dustcover at hinges.">Remove dustcover at hinges.
  • Secure tonearm to prevent stylus damage.
    00.jpg" alt="Secure the tonearm.">Secure the tonearm.
  • Remove slipmat from platter.
    00.jpg" alt="Remove slipmat.">Remove slipmat.
  • Turn the turntable on its side and remove screws that hold the top to its base. Remove platter by unscrewing the bottom plate from the turntable. The spindle bearing is held in place with a Philips head screw. Loosen it and the platter will separate easily from the spindle.
    00.jpg" alt="Separate the spindle from the platter by loosening with a Philips head screwdriver.">Separate the spindle from the platter by loosening with a Philips head screwdriver.
  • Loop replacement band around the pulley cylinder in the motor. Replace platter and bottom plate. Tighten spindle screw. Test the new belt by turning the platter clockwise two or three rotations. Belt should fit snugly and turn with little resistance.
    00.jpg" alt="Test the replacement belt by turning the platter clockwise.">Test the replacement belt by turning the platter clockwise.
  • Feb 05, 2016 | JVC Audio Players & Recorders
    Does anyone know where I can but a hinge replacement hinge that holds dustcover on a Vestax bdt 2600 turntable?
    Vestax went out of business in 2014. I have found a website called Virtual Sounds Technology. They are the largest suppliers of their parts going. They say "if we don't have it, it either no longer exists or can only be pulled from a used unit".
    So your best option is to ask them!
    Mar 28, 2015 | Vestax Audio Players & Recorders
    Need needle for SL-D1 turntable
    You may want to try here: http://www.needledoctor.com/Online-Store/Panasonic-Technics
    Mar 02, 2015 | Panasonic Turntable Dust Cover Technics Sl...
    Dustcover will not stay up. how to adjust? where to find service manual?
    You will probably need a set of Allen Keys. One should fit in the bracket which will tighten up the hinge.
    Aug 22, 2013 | Numark TT100 Turntable
    I HAVE A PIONEER PL-30 TURNTABLE AND I NEED TO REMOVE THE 'PLATTER' IN ORDER TO REPLACE THE BELT. THERE IS NO CLIP TO REMOVE. HOW DO I GET THE 'PLATTER' OFF. AGAIN THERE IS NO CLIP FOR REMOVAL.
    Pull up on the platter with one hand after you remove the rubber mat. Then hit the center post with a rubber mallet while pulling up on the platter with on hand just hard enough to release the platter from the post. The platter should come off.
    Aug 06, 2013 | Pioneer Audio Players & Recorders
    Why Fry - 220 or 110 ????
    You should be fine with this. Here is the spec:
    Quartz lock large blue LCD display showing: speed, pitch & platter direction, locking platter reverse button, located in battle position, 3-speed design: 33, 45 & 78 RPM, 7 grams of anti-skate adjustment, adjustable pitch control+= 10 & pitch bend buttons, locking reverse button, hi-tech tone arm with height adjustment, feather-touch start/ stop control, strobe illuminator, pop-up target light, headshell, slipmat and dustcover included . 115V/230V switchable. 17.75"w x 6"h x 14"d. Weight:27lbs.
    Jul 18, 2010 | Gemini PT-2410 Turntable
    Hinges for dustcover of Technics SL1300 turntable
    See: http://djparts.net/technics-parts-replacement-dustcover-with-hinges.html
    Has a dustcover w/hinges... :o)
    Mar 06, 2008 | Audio Players & Recorders
    Gemini SA-600 II Turntable Logo
    Top Gemini Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Don Hart
    richie46
    Are you a Gemini Audio Player and Recorder Expert? Answer questions, earn points and help others
