Question about Watches
I put a new battery in my fossil kaleido and now it doesn't flash the team emblem in the background
SOURCE: It now won't flash!!!
It sounds like the reset button on the inside was not pushed. There is a small reset button on the inside. Bring it back to a Fossil Store so that they can open the back and take it off. When you bring the watch back, tell the associate that you would like them to try resetting the watch from the inside.
Posted on Jun 13, 2009
SOURCE: Fossil Kaleido Watch LI22248 replacement
The Li2248 is the original kaleido watch and takes a single flat round inexpensive CR2016 battery. It is worth replacing it as they usually last for many many years, unlike the newer Kaleido two watches that take two batteries that together only last about a year. Walmart will usually let you borrow their tool to remove the watch. This one is very easy to remove with the tool. Walmart will likely not remove it for you since they did not sell it to you but I have been to many Walmarts in many states to readily loan the tool for you to use at the counter. IT is a special adjustable wrench that will set in the indentations on the back of the watch and then rotate counterclockwise to unscrew the back off. Once inside, you do need a very tiny screwdriver to LOOSEN, do not remove, the screw that holds the bracket against the battery. Once the screw is lightly loosened the bracket slides out and away from the screw and you can then easily remover the old and place in the new battery. You then retighten the tiny screw and then screw the back of the watch back onto its case by hand at first and then with the watch tool to tighten it. There is little chance of damaging the watch or loosing your waterproofing if you can get access to the watch wrench.
I have just opened a blog site devoted to answering questions about Fossil and gametime sports watches especially the sport logo watches. The blog site is sport logo watches blog at http://sportlogowatches.storeblogs.com/ I am putting together a pictorial on how to replace the batteries in the Kaleido II watches but this is quite a bit more challenging than yours. Good Luck!
Posted on Sep 30, 2009
  • 2501 Answers
SOURCE: fossil watch
Your description of the problem is not clear but if it is not running properly and is within the warranty period, then take it back.
If it is outside its warranty period then a watch repairer will sort it out for you.
Posted on Dec 27, 2009
  • 51 Answers
SOURCE: i replaced both batteries. the background will
check batterys are not faulty, but i think you need to AC the movement,ok. refit both batterys then onthe movement itself there should be two letters AC or AR or sometimes AS and close to these letters a small area no bigger than 3mm in diameter you need to place one prong of a pair of tweezers on this area and the other prong on the movement itself make sure its the metal part of the movement do this at the same time like tapping two fingers together on a desk but remember you may need to do this a couple of times
Posted on Mar 26, 2010
SOURCE: I have a Fossil Texans Kaleido watch that does not
man i have the same problem with the same watch did you ever find out what it was???
Posted on Jan 22, 2011
Bg-2147
Google (fossil)(BG2147)(manual) without parens for instructions.
Feb 19, 2014 | Fossil Kaleido Brown Kaleido BG2147 Watch...
Fossil AM-3539 The watch has 2 batterys. one operates the changing face the other the watch movement. I replaced both batteries and now the face doesn't change. How do I re-set it?
Please note that many Fossil kaleido watches, especially the sports variety actually have THREE batteries. Two run the animation and one runs the time. The time one lasts much longer, usually a few years, but is smaller and buried a little deeper so you could overlook it if not paying attention. The two kaleido batteries are very visible and usually placed side to side. Pay attention though as for some of the watches those two batteries are set in the same way ( both positive sides up) while others, especially the sports variety have one battery positive side up and the other negative side up. It is important to replace them the same way or the watch will not work
Aug 12, 2011 | Watches
I replaced both batteries. the background will flash it has a college emblem in background, but the hands wont move. second hand wont move.
Mar 26, 2010 | Fossil Kaleido Green Kaleido BG2146 Watch...
Fossil Kaleido Watch LI22248 replacement batteries???
Depending on the age of the watch it could have a ECR series battery over the top of the 377 powering the movement or it could have 2 377's in the circuit board over 1 377 in the movement.
I always recommend taking Fossil watches to a certified repair shop that can re-seal the watch so you dont void your 12 year warranty and the watch remains water resistant and resistant to small particles.
Sep 01, 2009 | Fossil Sport Auburn University LI2248...
I have an alabama watch and in the middle it is supposed to blink an alabama roll tide A but i do not know how to make it blink or have a solid A like I used to be able too.
Your batteries are dying my friend, take it to pretty much anywhere that sells watches to have the battery replaced. there is a main battery for the watch itself and 2 smaller batteries that control the screen or face changing. I think even your local walmart can change the batteries for you.
Stay classy
B.
Mar 29, 2009 | Fossil College Kaleido Alabama Kaleido II...
Need links for fossil kaleido Ll2097
Fossil will provide you with links at no charge if the model is not too old and they have the parts.
The 800 number is in your owners manual.
Feb 19, 2009 | Fossil NCAA Kaleido Washington Kaleido...
Fossil watch
Jul 26, 2008 | Fossil CH2332 Wrist Watch
Watches Logo
62 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
