Question about HP ProCurve 2424M (J4093A) 24x10/100 Mbps Networking Switch
I would like to reinitialize the entire switch (hard reset) so that I can reconfigure it.
    Sergeant:
  • 378 Answers
Http://h17007.www1.hp.com/us/en/support/converter/index.aspx
Connect to the switch and get to the CLI # prompt. Issue the "erase startup-config" command and follow the prompts.
Posted on Apr 25, 2011
Errorcode: 101: Could not load template godswar
Hello there!
Errors are hard to pick, but depending of the connectivity, and video driver, that speed up, the FPS, and process, help, other than those, may be, reinitialize any data file, of reset the game.
just hints
Carl
Mar 11, 2014 | IGG GodsWar Online
Wifi password
If you are using a router ( and of course have physical access to your router) reinitialize (reset it to factory default) and reconfigure your network. If password was provided by some Internet provider, contact your provider.
Nov 06, 2013 | D-Link Computers & Internet
Four got my password need help
when logging in to your router configuration the default username is admin and leave the password field blank and click log in. the last resort is to hard reset your router and reconfigure it.
Note: hard reset is located at the back of your router you will see a tiny hole and labeled reset. This is advisable only for those who knows how to reconfigure the router because by hard resetting the router it will go back to the factory settings/default.
Sep 09, 2011 | Computers & Internet
We are using WGR614 V8 Netgear Router it was working fine but one day after putting power switch on front panel of Router Power indicator LED and wireless LED are not glowing but Test LED, internet LED and...
no it never needs a hard ware repair... doing a hard reset for the router will help... press and hold the reset button on the router for 10 to secs using a paper clip or any safety pin.... reconfigure the router when reset is done completely...
Dec 13, 2010 | NetGear WGR614 Wireless Router
Green blinking light
needs to be reinitialized press menu 8970 to reset
Oct 15, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Wireless side of 4port linksys router not working hard wired switch ports working unable to ping router using dhcp if i configure a static ip on my pc i can then ping 192.168.1.1
try a factury reset on the switch by holding the reset button and pluging in the power at the same time and holding for 5 seconds- reconfigure router as required.
Sep 30, 2009 | Linksys Wireless-G WRT54G Router
My pelco 16 cameras reset each one minutes
You need to do a INITIALIZATION/REINITIALIZATION PROCEDURE See below for details Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
If you are installing the DVR, follow the steps below to initialize
the unit as part of the installation instructions in the Installation/
Operation Manual. This procedure erases all data on the hard disk
drive and is necessary to ensure that there is no data that could cause
improper operation when you try to use it. With a clean hard drive, the
DVR can correctly index recorded video with the correct time and date.
Once the DVR is initialized, you should not reinitialize the DVR
again unless you are having trouble finding and playing back video,
and there is no other solution. If you have to reinitialize the DVR, make
sure the time and date are correct before beginning the procedure.
WARNING: When you initialize or reinitialize the DVR:
• The hard disk drive is erased.
• The password and all menu settings return to their default
conditions.
To initialize or reinitialize the DVR:
1. Press and hold the Function button. The Function Key List
appears. Keep holding the Function button.
2. Press and release the 0 button, and then release the Function
button. Enter the password if requested. The Setup Menu
appears.
3. Using the front panel buttons, enter 1220.
4. A screen appears and asks if you want to continue. Use the
Search (<</>>) buttons to highlight Yes or No to erase the
hard disk drive, and then press the Play/Pause button.
PASSWORD
The default password is 0000. If you change the password, and
then forget it, you can get into the system by using 2002.
Aug 25, 2009 | Pelco DX1000
Lexmark 4800 series reset printer to factory wireless settings
i have a lexmark printer its plugged in but dont have a icon to make it print
Oct 07, 2008 | Office Equipment & Supplies
Can't log into my router
No there is not a way to just change the password on these devices. If you have changed the password from the default and either forgot it ,or fat fingered it upon entry then you will need to do a hard reset which resets everything. However the config's on these are so simple it shouldn't take longer than 10 min to reconfigure it, especially if you have good documentation!
MilToN
CNA, CNE, MCSE, CCNA, Network +
Nov 26, 2007 | Arris SBG1000 Wireless Cable Modem Gateway...
HP ProCurve 2424M (J4093A) 24x10/100 Mbps Networking Switch Logo
116 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
