Question about Kenmore 73503 Stainless Steel Bottom Freezer Refrigerator
At what temperature should the fridge be set to so that things dont freeze
  • Kenmore Master
  • 43,501 Answers
34 or higher will keep you from freeinb\g
Posted on Sep 11, 2010
Top of fridge freezing with temperature on lowest setting
You need a new thermostat but there are some things you can check in the link. 1 is the warmest setting.
Most refrigerator temperature settings are controlled with a dial or slider. They are sometimes labeled 1 through 5 or 1 through 9. If you are not sure what to set it to, then set it somewhere in the middle. If the dial is numbered 1 to 5 set it on 3, if the dial is numbered 1 to 9, then set at 4. USUALLY the higher the number on the temp control dial, the colder the temperature your refrigerator will get. If your drinks and food are not as cold as you like, set the temperature dial up one number higher. If it is at 3 and you want your food colder, set it to 4 and test 12-24 hours later to see if your food is at the temperature you want.
Why Is My Refrigerator Too Cold
Dec 18, 2016 | Refrigerators
Da99 samsung fridge freezer
As for freezer, lower the letter and allow 24 hours for temp to adjust. Lower again and wait, until desired temp achieved.
Do the same thing for refrigerator. If freezing not working most efficiently, this can and usually does affect the refrigerator.
Go to http://www.buzzle.com/articles/refrigerator-temperature-settings.html for more info.
Mar 02, 2014 | Refrigerators
I have a double door fridge, at the bottom is the deep freeze and top the fridge, the fridge is not working at all no matter what temp i set it on, but the deepfreeze is working, what could be the...
If the deep freeze is working it only means that your problem is on the thermo switch on the the fridge section. Try to check the temperature setting panel if its possible open it and look for the thermo sensors that switches the temperature in the fridge.
Nov 08, 2010 | Bosch KGU66920 Side by Side Refrigerator
Fridge is freezing things
You may have a defective temperature control. How old is the unit? Or you may have a defective thermostat.
Jan 29, 2010 | Refrigerators
Hi my fridge freezes every thing even at it's
your thermostat is bad, what it does it sense the temperature set buy the control setting, once it goes bad it does not recognize the temperature hot or coold and the unit keep running and freezes everything. thermostat work like the therometer switch, when it reach certain temperature it cut off.
Jul 16, 2009 | Dometic Refrigerators
Fridge is freezing things when temperature guage is on
check damper control or refrigerator door (ajar)
Apr 07, 2009 | Refrigerators
Kenmore Side by Side Refrigerator too cold
On a fridge freezer only the fridge temperature is monitored. In a cold location the fridge might not even need cooling and the freezer would get too warm but the thing won't care.
If the fridge sensor sees it as too warm then it will keep the motor running and the first thing to get really cold is the freezer.
Remember the freezing part is not temperature controlled ion a fridgefreezer.
Apr 28, 2017 | Refrigerators
Hoover frost free fridge is freezing every thing in fridge department
Sounds like a defective refrigerator control. Refrigerator temperature is what turns the whole system on and off. First check the settings. a starting point is midway on the scale for both the refrigerator and freezer controls. If you already have the refrigerator temperature set at its minimum setting then it is that control which is causing the problem.
May 28, 2008 | Hoover Refrigerators
I don't know how to set the temperature setting on my Hotpoint RLAV21 fridge. The dial goes from 0 to 4. For fridges I have had in the past the higher the number the colder the fridge but I've got my...
You should have 2 dials one is the thermostat when you set it all the way one direction it will shut you refrigerator off. Turn it back to about the middle if there are no numbers. The other dial is the air damper between the freezer and the refrigerator. The fan circulates the air through refrigerator by this damper. If you open this open to much your food in the refrigeration section will freeze. Close it back to about 2 that will give you a colder freezer and should be about right for the refrigeration section.
May 17, 2008 | Hotpoint Refrigerators
Kenmore 73503 Stainless Steel Bottom Freezer Refrigerator Logo
85 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
