Question about Nakajima AE-800 Typewriter
Nak800,after typing for awhile,keyboard freezes,green light still on,have to switch of and on to reset
  • Nakajima Master
  • 3,594 Answers
Try puting a little WD40 on the shafts that the carrier slides on.
DickyO
Posted on Sep 11, 2010
1 have a 6 year-old Mitsubishi model WS-48511 series 1080 rear projection TV that now won't turn on. A few days ago we shut the TV off, and now when i plug it in the blinking green power light...
This is called the blinking green light of death-----only one of two things can cause this problem.
First: remove front speaker grill (IT PULLS OFF) AND remove inspection plate behind it; look for the two bundles of wires coming down and to the right from the front keyboard of the set.
Unplug both plugs you find (different and marked so you cannot mix them up-----the idea is to take the front keyboard out of circuit-----set will still function with remote as receiver is behind front screen)
Try (after 70 seconds) to turn on with remote
If it comes on---defective reset button on front keyboard----use set only with remote or remove and remove actual reset switch---it is located behind and part of frame for screen----entire front screen would have to be removed to get at it.
Second: if disconnection of the front keyboard does not help, the DM unit is bad.
As you look from back of set it is large metal box at extreme left side.
The blinking light is the unit trying to "Boot" up-----these have a problem where caps and a few other parts in that unit fail-----kits on the net are available----Mitsubishi no longer sells or services these units but PTS Electronics does repair them.
Let me know if you have questions and try disconnection of the front keyboard FIRST.
REGARDS, SD TECH
Jan 20, 2012 | Mitsubishi WS-55613 55" Rear Projection...
Hp pavillion m7680n win xp freezes
The problem seems to be with RAM. Remove your RAM after switching the PC off and clean the contacts array carefully with a dry cloth, rub a little if required with a slightly coarse cloth. Put it back, hopefully will solve your problem.
Jan 14, 2012 | HP Pavilion m7680n PC Desktop
Recharger doesn't recharge
mcdevito75 here, The batteries in the mouse could be going bad, old.
Jun 29, 2010 | Logitech MX1000 Laser Cordless...
Green light of "hell"
Try reinitializing the set press menu 8970
Oct 13, 2009 | Mitsubishi WS-65615 65" TV
Blinking green light
Did he try to disconnect the front keyboard on this set?
ONLY 1 or 2 things can cause this problem----First thing to do is remove front speaker grill--it pulls out and secured with plastic pegs--behind it you will find an inspection plate---Notice the one or two pairs of wires coming from the front keyboard2.gif of the set---remove the inspection plate and follow the wires to the right--you can unplug both plugs(most have two and they are marked with letters and different sizes so you cannot get them wrong)
The idea here is to remove the front keyboard2.gif with its reset button etc from the circuit---You will still be able to try to turn the set on with the remote---these sets have a Receiver(large metal box to the left as you look from the back) and if the power goes out the green light will blink for about 70 seconds and then go out---it is the Receiver booting up.
If disconnecting the keyboard2.gif allows the set to turn on--you have a bad reset switch and two choices---either operate the set only with the remote or to remove the front screen and get at the reset switch (it is tiny) and remove and or replace it.
If disconnecting the keyboard does not restore the set to operation---the receiver is bad---there are 4 or more caps and some pico fuses that can fail in that unit---Mitsubishi no longer sells or repairs these--if it is bad and not the caps there is a company you can send the unit to and have it repaired--if you need to know their name let me know---you can call them and get a quote for repairing the receiver.
Did he try to disconnect the front keyboard of this set? it has the reset switch on it---------and the switch can cause this problem!
SD TECH
Oct 06, 2009 | Mitsubishi WS-65513 65" Rear Projection...
Rapid flashing green light but no power. I've reset - no effect, unplugged set for a couple hours and several days - nothing. Continual rapid flashing green light when plugged in. Also, when I plug the set...
1.) Most of these sets have a receiver built into the back(large metal box on left side as you look from the back.)
2.) Two possible reasons for green light constantly blinking(it is the receiver booting up if the set is disconnected from power---light should blink for about 70 seconds and go out).
3.) First reason: The recessed micro switch on the keyboard marked reset may be bad--does not happen a lot but it does happen. Easy way to see if this is the problem is to remove front speaker grill---and inspection plate behind it---from the keyboard you should see one or two groups of wires(they come from the keyboard) follow them to the right and unplug both(they are different and marked with letters). This takes the keyboard out of the circuit---you should still be able to turn the set on with your remote(remote receiver is behind the screen.) IF SET NOW WORKS YOU HAVE TWO CHOICES--USE IT ONLY WITH THE REMOTE OR HAVE SOMEONE REMOVE THE FRONT KEYBOARD AND UNSOLDER THE RESET SWITCH--the switch can be replaced without replacing the keyboard(it is a small circuit board with all the micro switches on it.)
4.) If disconnecting the keyboard does not fix the trouble---you have a problem in the "Receiver"----it happens on these sets and usually is repairable--Mitsubishi no longer sells this part and it was very expensive when they did---if disconnecting the keyboard does not cure the problem---let me know and I can give you options for getting the receiver repaired.
5.) Let me know if you have questions and if you need more advice reply to this post here.
I do this here for free so if this information helps you take a minute to give me a vote here---I am here to help people.
REGARDS, SD TECH
Sep 16, 2009 | Mitsubishi WS-65611 65" Rear Projection...
Ws-55511 replaced all 7 caps in the dm, still wont power on
I have seen this only 2 times----you may be able to unsolder and remove the reset micro switch---you have to remove the whole screen to get at it---the micro switch board may not be available---the switches can be tested with a ohmmeter set to high end and of course should not have a reading across them--I bet the reset switch is bad--you can remove it and put the keyboard back---most of the Mitsubishi sets use the same type of switches--Only other thing is leave the keyboard disconnected and just use the remote.
Glad you found the problem.
Regards, SD TECH
Sep 14, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Keyboard does not type brand new batteries
look for a little hole on the keyboard, the button is the size of a pin head, it is for resetting the keyboard after you put in a new battery. when you find the reset switch the keyboard light will work and the startup bar will show it has found a new device.
rodgandysr567
Mar 03, 2009 | Microsoft Wireless Laser Mouse 6000 v2.0
Microsoft wireless laser keyboard 6000 v2 - keys suddenly stopped/not working
i had the same problem, i checked the batteries with a DMM and the measured 1.4v i replaced the batteries with new and i still had the same problem. anyway i ended up taking the keyboard apart and found where the antenna is connected to a push on type connector alongside the pcb board inside the keyboard, the connection was slightly corroded. i cleaned it up and it is working fine know, even with the old batteries.
Aug 07, 2008 | Computers & Internet
Nakajima AE-800 Typewriter Logo
Top Nakajima Office Equipment & Supplies Experts
James Cagle
James Cagle
Daniel Thibodeau
Level 1 Expert
Jim Keysor
Are you a Nakajima Office Equipment and Supply Expert? Answer questions, earn points and help others
