Question about Panasonic KX-FPG391 Plain Paper Thermal transfer Fax
How do I reprint the last fax received? Initially, fax was received and stored in memory (guessing it sensed some sore of jam in the paper). When I hit "print" it made noises and attempted to load the paper, but it was somehow jammed (and I never got the fax, but machine thinks it printed). Display is back to normal and not sure if/how I can reprint the last fax received. Model: Panasonic KX-FPG391
SOURCE: Reprint last incoming fax
i'm afraid you are out of luck. Once an attempt is made printing and no error message about the ink cartridge condition is apparent. Then that's it, it is deemed successful.
Posted on Sep 05, 2007
checkitright
  • 1362 Answers
SOURCE: reprint last fax receivedCanon fax 730i
here is the manual
http://www.retrevo.com/s/canon+730+manual
good luck
Posted on Dec 21, 2007
FixinFax
  • 3085 Answers
SOURCE: Transmit Error
To eliminate a machine problem, make a copy of something; you are using the scanner to verify if the mechanics are OK.
To eliminate a phone line problem, take the fax to another house or office and try there it again.
Posted on Oct 30, 2009
FixinFax
  • 3085 Answers
SOURCE: Describe your panasonic kx-fhd331 reprint fax
It is gone out of memory. You cannot recover it.
However, try unplugging the power cord for 10 seconds.
Posted on Nov 04, 2009
FixinFax
  • 3085 Answers
SOURCE: how do i reprint the last fax
Not possible.
Posted on Apr 06, 2010
Reprint last fax?
you cant reprint.if your fax paper jamed or your machine had an error you can reprint.when you get a fax automaticallay your memory will be clean
Nov 19, 2013 | Brother IntelliFax-2820 Laser Fax
How do I unjam a fax machine 1010
to clear document jam:
1 Open the front panel.
2 Carefully remove the jammed document.
3 Close the front panel firmly until it clicks
into place.
If the fax paper jams while you are receiving or printing, Remove jammed paper and press
Cancel appears in the message.
if the paper is jammed in the printing area
1 Remove the jammed paper by pulling it out
smoothly in the direction of the arrow as
shown.
If the paper tears when it is being removed
check to ensure that no small pieces have
been left inside the machine.
2 Press Cancel.
3 If this was a fax, reprint the fax. For more
information, see reprinting faxes on
page 29.
if the paper is jammed in the paper feed
area
1 Remove the jammed paper as shown.
removed check to ensure that no small
pieces have been left inside the machine.
2 Reload new paper with the print side
facing toward you.
3 Press Cancel when finished.
May 04, 2012 | HP 1010 Plain Paper Inkjet Fax
Need to print a fax in memory, machine was turned off and unplugged
It may be too late to print the faxes if your printer was unplugged. But you can try:
reprint the faxes in memory
Your HP OfficeJet can store a limited number of fax pages in its memory, with
the number of pages depending on the model you purchased. When your
HP OfficeJet runs out of memory to store faxes, it will not receive any more fax
calls until the stored faxes are printed.
Reprint Faxes in Memory enables you to reprint a fax stored in memory. For
example, if your print cartridge runs out of ink or paper becomes jammed when
printing a fax. This option prints all faxes in memory; press Cancel to stop
printing faxes you do not need.
1 Press Menu.
2 Press 2, then press 3.
This selects the Fax Functions menu, then selects the Reprint Faxes in
Memory
option. The faxes are printed from memory.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 23, 2011 | HP OfficeJet 6110 All-In-One InkJet...
Can you retreive a sent fax from memory
The fax element of the Printer contains a memory feature for storing faxes in the event of a printing problem. This feature is useful for protecting yourself against missing faxes if your printer runs out of paper. In order to retrieve missed faxes, the feature must be switched on when the faxes arrive. You can reprint faxes stored in the device's memory from the main control panel. You should allow approximately 5 minutes for this task, or longer if many faxes are stored in the memory.
Instructions:
Load paper in the input tray.
Press the "Setup" button on the front of the printer.
Select "Tools," then "Reprint Faxes From Memory."
Press "Cancel" to stop printing. Faxes are printed in reverse order; the most recent fax is the last to print.
Dec 03, 2010 | HP Office Equipment & Supplies
Reprint a fax
Sorry, once a fax is printed, it is gone from memory.
May 31, 2010 | Samsung SF360 Plain Paper Inkjet Fax
Incoming faxes stuck in memory, how do I print them. Prior to this the faxes were coming through, but half printing then jamming, so press start and that peice of paper would come out then the next go in...
This answer maybe a little late for you but for anyone else tring to print fax stored in memory:
1. Press Menu - Fax Functions will display
2. Press 2 - Print report will display
3. Press Enter - Last Transact will display
4. Press 7 - Reprint Faxes will display printed the pages
5. Press Enter
This will print all faxes in memory. Press Stop when you have printed the pages you need.
You can print fax log (Press 2 after step 3) to see what is in memory
Oct 01, 2009 | HP 1020 Plain Paper Thermal transfer Fax
Reprint Last FAX on RICOH Aficio MP 3350
Once the fax was received and printed you can't do nothing.
It is not stored in the machine.
Please call the sender to send you the fax again.
Good luck and please rate me, thanks.
Dec 30, 2008 | Ricoh FAX2210L Plain Paper Laser
Aug 25, 2007 | Sharp UX B20 Plain Paper Inkjet Fax
Panasonic KX-FPG391 Plain Paper Thermal transfer Fax Logo
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
