Question about Peg Perego John Deere Gator HPX Ride on Toy
Our kids John Deere Gator won't run despite the battery full charged. Before I replace the expensive battery, is there anything else we should look at? It's about 3 yrs old.
    Genius:
  • Peg Perego Master
  • 1,508 Answers
First of all check for at least 12 volts from the battery and the charger, you can test this using a multimeter, if the battery doesn't show any volts, lift up one side of the blue plastic housing on the top and verify that both the positive and negative wires are plugged in
Posted on Jun 13, 2012
momsjustknow
  • 149 Answers
SOURCE: peg perego john deere gator 4x2
Here are the printable instructions from the Perego website.
http://www.pegperego.com/pegcatalogue/toys/downloads/Gator_Work_FIUS0301G24.pdf
From what I can tell, there are levers on both sides of the grill that you press to flip the grill down to the ground. You can then get to the battery to pull it out and charge it.
Hope this helps!
Good Luck! from Moms Just Know
Posted on Nov 03, 2008
  • 60 Answers
SOURCE: old john deere gator and battery new charger still will not move
Could be several things.  Your battery could be bad. After not being charged for a while, they do go bad- often. You may want to try a new battery along with your new charger.  You could also have a switch /connection problem. If you get a new battery and it still doesnt work, you may want to check the switches and wiring. It is not uncommon for the switch to go bad especially if it had been stored outside.
Posted on Mar 11, 2009
mikeramesar
  • 37 Answers
SOURCE: cannot find out how to get to the battery for a
Where the front bully bar is, there is an indent in the middle , enough for your phillips head screw driver to get into, you must undo that screw and there will be a tab on either side of that panel to pull and the front bummer assembly will hinge out towards you, you can then unplug the battery and connect your charger..
Good luck!!
Posted on Dec 27, 2009
  • 19 Answers
SOURCE: john deere gator 1999 4x6 overheating.replaced
bleed air out of cooling system contact dealer for instructoins
Posted on Aug 17, 2010
Samir3050
  • 70 Answers
SOURCE: Our son's peg perego john deere gator stopped
It is most likely the Gearbox, it is easy to find and easy to replace. It is right under the gear shifter and is a "harness" with wires that will need replaced, if you call the tech support for Peg Perego they are very helpful and will get you on the right track. Your old battery is most likely fine, but keep it until you fix the gearbox switch. Afterward (when gator is again operational) I would imagine you could return the new battery since you really should not need it. Peg Perego support is 1800-728-2108 and you can also look for parts at www.mypegperegoparts.com
Posted on Mar 01, 2011
Bought new battery for the john deere gator ride on toy but only runs for a short time then battery needs recharging
Hi, How long does it run? Typically you should get at least 45 min of run time out a fully charged battery. If it's slowing gradually and dying in just a few minutes its the battery. If it's goign full speed and then stopping suddenly, it's probably the thermal breaker located in the shift mechanism.
Aug 25, 2014 | Peg Perego John Deere Gator HPX Ride on...
Our john deere gator won't run
how do you know that the battery is charged? it could be that the charger isn't working. I would check the charger with a multimeter and verify that its putting out enough volts to charge the battery, it should be putting out between 13.8 and 14.6 volts
Apr 29, 2012 | Peg Perego John Deere Gator HPX
Gator lacks power when running in our front yard grass.
sounds to me like you have a bad motor, yes both wheels should turn
Dec 30, 2011 | Peg Perego John Deere Gator HPX Ride on...
I havent used by feber car for 5yers n i lost the adaptor to charge it so if i get a new gharger will it be fine to use it or should i remove the battrey n re-charge the battery? n where can i get the...
KidsWheels features a full line of Kids battery powered electric ride on vehicles, cars, pocket bikes, Kids battery powered electric toy cars, Kids cars, Kids ride on trucks, Kids ride toy Quads, Pedal Cars, Big Toy Ride Ons, Big Wheel, Jeeps, Peg Perego Battery Powered John Deere Gator, Honda Minimoto, Winther Tricycles, Peg Perego Vespa, Peg Perego battery powered John Deere Worksite Gator, Peg Perego Gaucho Super Power S Series, Peg Perego Gaucho Super Power S Series, Peg Perego Ranger RZR, Orange County Choppers, Power Wheels Ninja, Peg Perego Gaucho 4.0, Lightning PAC, Power Wheels MX3, Peg Perego John Deere Power Lift Gator, peg Perego Polaris 800 Twin, Power Wheels Nascar Ride On Jeff Gordon L7822, and more..
KidsWheels Ride On Toy Store
519 North Bell Blvd.
Cedar Park, TX 78613
800-396-9680 512-257-2399 Fax 512-257-0093
Store Hours:
10AM - 5 PM CST Monday - Friday
10AM - 4PM CST Saturday
Closed on Sunday
http://www.kidswheels.combenluis_1.jpgbenluis_0.jpg
Jan 17, 2011 | Toys
Peg Perego John Deere Gator HPX Ride on Toy Logo
1,515 people viewed this question
Top Peg Perego Toys Experts
Adam Fjeld
Adam Fjeld
Gary
Gary
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
