Question about Vacuums
I just bought a Danby Premiere air conditioner #317826. I need a newset of tubing, as it is messed up. I would really appreciate it, my name & address is Sammie Visage, Rt 1 box 171, Carter, OK 73627. When I visited my sister in TN, she showed me hers and I was impressed, so bought one. I live in Western OK in a town of 300, A Lowes store is 2 1/2 hours from us. So you can see why I would really appreciate your help. Thank you, Sammie Visage
Hello,i have a vacuum cleaner but their is no air pressure in it
Do you mean the suction is very low? Or really none at all?
If low, there can be a hair/dust ball clogging the tube way deep. If you can remove it and the vacuum cleaner has an 'blow air' out you could connect the tube and blow the junk out possibly. The clog could be inside the unit instead.
If no suction at all then it's probably a complete disconnected tube somewhere.
Oct 06, 2013 | Oreck UPR014T XL Pro 14 Upright Vaccum...
I bought a Danby microwave from Costco 10/12/10. It is dying. Manufactuer's warranty runs til 6/13/2012. What do I do next?
I would suggest that your first try might be to go back to Costco and see what their returns policy is. They MAY take it back and either replace it or send it off to the manufacturer for repair. Failing that, go to the Danby site: https://www.danby.com/warranty.php?ln=USE&tip=INF You may have to register first, but having done that you should be able to log a warranty call with them directly
Aug 30, 2011 | Vacuums
The air conditioner stopped draining condensate
You need to pull the cover off the indoor unit to see if the coils are frozen. If they are, you will need to let them thaw..you can set a fan in front of it to help the process. if the coils are not frozen, I would check the tube that runs from the drain pan- under the coils- to the outside. It may be blocked..Try running a clothes hanger in to unstop it. Or use some type of forced air to clear the tube from either end...Is the AC cooling?
Jul 09, 2011 | Vacuums
I just purchased a used portable air conditioner, a danby dpac120068. It is not producing any water when in dehumidify mode. Also, it seems as though the air conditioner is on even when in dehumidify...
The A/C will be on when dehumidifying... that's how it does that...
If it is not collecting water, it is probably because the humidity is too low in the house already...
I would give it more time....
heatman101
May 25, 2011 | Vacuums
I have a Kirby Heritage II Turbo and I need a user's manual, but can't find one anywhere. I have to replace the fill tube in the bag and can see the cable tie on top that holds it in place, but don't know...
Taping usually just causes a mess. The mini-emptor has coarse threads on it that the fill tube screws on to. Occasionally there is a cable tie on the bottom which is not really necessary. If you cut the tube near the bottom, you can get hold of it's wire frame and rip it out. After cleaning the threaded area on the mini-emptor, wet one end of the new fill tube with water and screw it well down. The bag top adapter can then be put on and secured with cable ties.
Feb 27, 2011 | Kirby Heritage II Vacuum
I took my Bissell Powersteamer Powerbrush Deep Cleaner apart and i don't know if I have the hoses connected correctly.
Here's a picture of the tubing on the PowerSteamer from an overhead view. I hope this helps you putting the machine back together. I know personally how challenging this repair can be, this picture really was my Bible when I was putting back together the machine for the first time. If you have a question about a particular tube, please feel free to add a comment to the repair page, and I'll be more then happy to answer any follow up question that you may have. If this was helpful to you, please be so kind and follow the Fixya model and rate the repair helpful by clicking the 4 thumbs up icons in the top right hand corner. This is greatly appreciated.
Here's the picture for you:
Chris Jones
GoVacuum.com
Apr 09, 2010 | Bissell 1697-7 Powersteamer Pro Deluxe...
Using the wand works fine, but using sweeper - no suction
Forgive me if I'm thinking of the wrong model, but I think the DC07 has a short length of clear plastic tubing between the floor head and the fixed vacuum pipe-work. This tube can split and let air in which, of course, reduces suction at the head. You need to inspect it very carefully, as the split is often where it's really difficult to see!
If this is the problem, a repair with tape is possible but rarely completely satisfactory. A new bit of tube is the best solution.
Apr 05, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Hoover aquamaster
sounds like you need to attach the air hose
with reservoir in place you clip on the lid with tubes attached, one of them goes down to the floor cleaning nozzle, the other tube should be about 20cm long with an end piece,
this is the air hose and it fits into a small hole under the reservoir on the motor housing (the heavy mains powered part that clips onto the big recovery drum that sits on floor)
it's mentioned briefly in the manual, here it is in pdf form http://www.box.net/shared/rnh39ffjcq
Nov 03, 2007 | Vacuums
Something stuck in my FilterQueen Vacuum
You should be using a broom or mop handle to clear the wand - metal tubing. If you still need help please contact the manufacture at 1-800-344-1840. I did and they were very helpfull, they also sent me a manual at no cost.
May 25, 2007 | Filter Queen Cheetah II Ash - MU305...
Vacuums Logo
234 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
