Question about Dacor ER36D Stainless Steel Island Trim Kitchen Range
Display shows F1 - Dacor ER36D Stainless Steel Island Trim Kitchen Range
    Genius:
  • 1,417 Answers
The F1 code is an error code indicating that there is a loose of wire from it position or an over flow of liquid substance in the sensor /panel reading error i.e F1
what you need to do to fix up this problem is to unscrew the range with bass tools then clean up all form of liquid around the lens ,panel and also the wires and fix up the loose wire if any please do this with care in other to avoid more damage on it and while doing this DO NOT USE WATER or AND LIQUID substance in cleaning use only clean rag to do this service then allow it to dry up for some time then couple it back to it position with this the problem of f1 code is solve.
Thank you and thanks for using fixay.
Posted on Sep 11, 2010
No display on screen and external display
What is your laptop brand and model? No display on either? Does the computer seem like it is up and running, but just no display? Did you reboot when you put the external monitor on the laptop? Maybe you need to hit the FN function key and the corresponding F1 thru F12 key that toggles the display. The correct key will have CRT/LCD on it or it might show the icon of a display. Press and Hold the FN key then hit the correct F1 thru F12 key to show the display.
If all fails, it sounds like your video card in the laptop is bad.
Apr 02, 2012 | Computers & Internet
Top half of my monitor screen shows at the bottom
Try plugging an external monitor to your laptop and see how it displays on it. It can be any kind of monitor even the old fat crt's as long as it has a vga cable that will connect to your laptops vga port.
If the display does not immediately show up, then you will have to hit the FN (Function key)+(F1 thru F12) to show the image. Press and Hold the FN key then hit the correct F1 thru F12 key. The correct F1 thru F12 key will have either CRT/LCD written on it or it will have a display icon on it.
If the image displays correctly on your external monitor, then you will need to replace your lcd screen.
Mar 25, 2012 | Computers & Internet
Display panel shows F1 Fault... how do I fix this
F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information.
Oct 01, 2010 | Maytag MGR5750 Gas Kitchen Range
Electric Range.-oven stopped working. Error Code F1 show on electronic display
Hello there:
Here is the 2 most common f1 codes for this oven and what the problem is and what repair procedures that should be taken
F1 Defective touch pad or membrane Replace touch pad or membrane (this problem is usually the touch pad) F1 Watchdog on board Replace touch pad or clock assembly (also called the ERC)
Dec 13, 2009 | Jenn-Air JGR8850 Gas Kitchen Range
The water filter display on my whirlpool fridge showed F1% but the replacement whirlpool fridge filter that I ordered off the internet doesn't fit, so I put the old one back in and reset the display from...
hi neil.i think you do mate from what i can rember doing that when i was servicing these type of frigerators.give it a trye and see what happens.what model is it.?stef
Jun 09, 2009 | Refrigerators
Top burner is stuck on and F1 showed on the display
Hi Krista,
Unfortunately, F1 is a fault code for a failed electronic control... it'll have to be replaced. The reason the burner is on is that the relay controlling it has welded closed allowing power to the burner full time.
If you choose to repair this yourself, could you provide the model number? That way, I could pull up schematics and stuff I need to further help you.
SG
Apr 05, 2009 | Kenmore Ovens
Display shows f1
Hello jrill42
Welcome,
Display shows , F1
this means your Circuit board is defective / Replace control board
You need a tech to do this work .
Please remember to leave a solved rating before you sign out!
Thank You Huum
Feb 06, 2009 | Frigidaire FEF352 Electric Kitchen Range
Display
This is an error code, the error E1-F1 indicates that the Electronic Range Control/Clock has been blown. You have to get it replaced.
Sgt 48
Jun 04, 2008 | Whirlpool GR399LXHS Electric Kitchen Range
How do I reset the radio alarm preset on Timex (T307S) Clock Radio
if the radio alarm is still showing the nonexistent 98.5, you would need to reset the radio alarm. Press and hold button 1 (top left hand side) until the display starts blinking. Then press the preset button for 98.1. It should then display 98.1 on your radio alarm. good luck this is the most difficult set of instructions I've seen yet
Sep 11, 2007 | Timex (T307S) Clock Radio
Dacor ER36D Stainless Steel Island Trim Kitchen Range Logo
83 people viewed this question
Top Dacor Kitchen Ranges Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
