It will work fine some times after being unplugged fo a while. Usually, the green light works, but it will not respond to the buttons or remote. When this happens nothing works. I have to unplug it to make the green light go off
  • ethnaln Sep 10, 2010
    It is a DIGITAL RESEARCH model WT322 p n 6702502231
    It was purchased 1/24/2008 with American Expressed card.
    I tried to contact Digital Research with no results.
    I am an electrician with some electronic tech and computer build and repair experience.
    Since the warranty is over, I may as well open the case and have a look.
    Thanks for now. I may be bothering you for more assistance.
  • 10,594 Answers
I need model number and brand info of your tv to understand what could be possible cause of problem.
Thanks.
Posted on Sep 10, 2010
  • Shahid Electronics
    Shahid Electronics Sep 10, 2010
    OK, it seems system processor problem mounted on main board of WT322 tv that stopped working for some reason like low voltage supply from power supply board or itself got worn out.
    Visual check by local tv repair shop is needed to fix the issue.
    Main board is not available for this model, in case system control chip is bad because main board will be replaced. Click Shop Jimmy link and call them for main board stock inquiry if they might provide you.
    Thanks.
    Not bothering me at all, I'm here to help you out.
    Please check dried up/ leaky capacitors in power supply output section and replace them to get correct and stable voltage supplies that might fix your tv problem.
    Thanks.
Rca tv vcr combo model #T 13072 when I press the power button the power light blinks 4 times, tv does not respond. I have tried unplugging it for a few hours to see if it would reset but didnt work..
There is no power button on the remote, you have TV and VCR only to turn on this set. I need to find out how to do a factory reset. I was using a roku TV device on it, and was working fine, and now nothing. I tested the TV by putting in a cassette, and hooking it up to my satellite service, works fine doing that. But now no roku, and the roku was also tested and works fine.
Mar 10, 2012 | RCA Televison & Video
62HM15 Toshiba DLP TV won't respond to remote or control panel
Blinking is a trouble code. Try unpluging for a longer time then hold power button in when pluging back in to try and reset.
Mar 15, 2010 | Toshiba 62HM15 62" Television
When turned on, no picture, sound or response. LED is OK
I had a similar problem with my HANNSLounge 32", the screen switched on with green light but none of the front panel buttons worked (screen is black apart from showing the input source in the top left).
After powering off numerous times I tried starting up with a blank SD card in the reader and the tv cycled between red green and blue screens and then reset itself. (Some sort of firmware restore?) After which point I had a working screen again! (Will have to see how long it lasts for!)
Feb 12, 2009 | Hannspree HANNslounge 32 in. LCD HDTV 32
Television response.
Try to locate the line of sight sensor on your TV that does not respond to the remote. The lack of response indicates that the sensor on the TV needs to be cleaned. It does not take much (dust, wax, cleaner residue) to block the signal.
Jan 13, 2009 | Televison & Video
Tv wont turn on
take your tv to technician who can check your power supply, if your power is coming on and off, than a problem is not as big. firstly let him check a ht of a supply constantly, your supply is cutting.
Nov 03, 2008 | Panasonic CT-32SC13 32" TV
Printer will not respond
Canon S330 Turn off printer
Hold down Resume button and press Power button.
Keep holding down Power button and let Resume button go.
Press Resume button 2 times then let BOTH buttons go.
Green lights will flash and then stop blinking.
When green lights are solid, press the Resume button 4 times.
Press the Power button and the printer should turn off, if not, press the Power button once more.
Your printer should respond as normal
Jul 22, 2008 | Canon S 330 InkJet Printer
Tv wont turn on
TV STARTS UP AND GOES BLANK SOUND NO PICTURE
May 16, 2008 | Philips 32PF5321 32 in. HD-Ready LCD...
Volume not responding on Direct TV remote
http://www.directv.com/learn/pdf/System_Manuals/RCA/RCA_DRD221RD.pdf
See Page 15.
Worked like a charm! Good luck!
Jan 31, 2008 | RCA DIRECTV Satellite Remote Control
Tv wont turn on
I had the same problem and took it apart. Before the repair there was no "click" when I pushed the button, a clue to the problem. The on-off button on the front pushes a weakly made angle piece of plastic inside which had broken. The plastic piece in turn is supposed to push an internal switch which is offset to one side.
I used epoxy (Araldite) to repair the broken plastic angle piece, but it still looks weak to me so I switch the tv off at the wall and leave the on-off button alone (though it does work now).
Opening the case requires some knowledge and care, and can be dangerous. It may void the warranty so be careful or give it to a qualified repair person.
Hope this helps!
Dec 12, 2007 | Televison & Video
Tv wont turn on
stephster, check to see if you have a reset button on the back of tv good luck-hope this works for you
Nov 05, 2007 | Panasonic CT-36HL43 36" TV
Televison & Video Logo
61 people viewed this question
Top Televison & Video Experts
Electro Med Services...
