Question about Maytag Neptune MDE5500AY Electric Dryer
My Neptune all of a sudden has stopped blowing hot air , I have had all the setting correct.
  • Maytag Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Sep 12, 2010
Blowing cold air
This model dryer has two heating elements, one for the top and one for the bottom, I suspect that the bottom element is burned out. If you want to attempt it yourself then I can send you a service manual that will walk you step by step through the whole dryer.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Dec 11, 2013 | Maytag Neptune MCE8000AY Electric Dryer
Altima blowing hot air AC
Go to Midas,they do great A.C.work,your Freon may have leaked out,they can test for a charge of 19.95..
Jul 01, 2012 | Nissan Altima Cars & Trucks
Our Neptune only blows super hot air. Which may sound good but it is ruining the clothes. It will not blow cooler air at all. Seems like this problem started more than a month ago. Is there an easy fix...
Clean the lint out of all air passages including the exhaust hose to the outside. Wash the lint filter in hot water and detergent to clean away fabric softener deposits which block air flow. Make sure that nothing is obstructing the air intake for the machine. If the problem continues, the heater thermostat may need to be replaced. Hope this helps!
Jul 18, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Naytag Neptune Gas dryer is not generating hot air, why?
if it not making hot air it could be 2 reasons one the gas is not get to the ignitor to make heat or the ignitor is is out on the dryer. if it the gas check for any leaks in the lines and also check to make sure that the gas is not to high or to low that will cause it to blow it self out. if its the ignitor if you can get to it take out and test it or just replace it they normally dont cost too much
Nov 09, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Air conditioner blows hot air inadvertantly.
possibl ac compressor clutch problem,cooling fan at rad not working so ac goes into high press mode and turns off(so it doesn,t blow system apart,built in safety)not enough r134 in system(low charge)
Sep 19, 2009 | 1997 Chrysler Concorde
Air conditioning blowing only highest setting but HOT air
Sounds like your freon has leaked out and your heater blower resistor is burned out. Deffinitly take this to the dealer.
May 20, 2009 | 2001 Honda Odyssey
2000 Chrysler Town & Country , no heat, blower fan working fine
Probably one of two things. First make sure that your coolant level is full. If the coolant is not flowing properly you won't get heat. If you begin to get heat while driving, but only when you are excelerating, this is your problem. If that is not it you may need to change the thermostat. This is noot hard as long as it is easy to get to and it should be easy.
Jan 12, 2009 | 1988 Oldsmobile Firenza
Maytag Neptune MDE5500AY Electric Dryer Logo
52 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
