Question about Craftsman 20 Hp 42" Deck Lawn Tractor
I have a 48" 20hp vtwin. The mower deck seemed to seize and the engine pulled down until I hit the deck button and shut it off. That sounds like the clutch. Can it be repaired?
  • 183 Answers
Clutches typically have to be replaced instead of repaired. But I see very few clutch issues. Check very closely the pulleys on the deck. I strongly suspect you will find one of the pulleys has a bearing that has locked up. WITH THE MOWER OFF, try to turn each of the pulleys on the deck, it will be easier to check if the deck belt is off. All pulleys should turn smoothly. If any of them feel gritty or notchy or wobbly, replace them. With the mower off, the clutch should also rotate freely. The pulleys on top of the blade spindle have a brake on them, you may have to pull the brake back to check those. Any of these pulleys can lock up after they get hot and will shut down the belt rotation. Replace the offending pulley or spindle, and REPLACE THE BELT. While the engine was still turning and the pulley wasn't, it will damage the belt very quickly.
Parts should be readily available at www.searspartsdirect.com or at your local repair shop.
Good luck.
Posted on Sep 12, 2010
Craftsman Model Number: 917.377151 motor shuts down when blades engaged
The engaging of the mowdeck is cause an excessive demand of your engine. From that, we can assume your problem is in the deck. Since the power drive is all about belts and it threw the belts, from your information I can only deduce that either an object (stick-wood-rock) has wedge into a position that has stopped rotation of the blades. Also, each blade has a pulley/spindle. These have bearings which must be free to rotate.
A bearing failure or seizing can also cause the problem you report.
Follow safety rules in your manual to insure the engine cannot start. Attempt to rotate each blade to check for free rotation. If the do not you most likely will need to remove the mower deck and check further. An obstruction or seized spindle should be easy to determine and sit repair is easily possible.
Sep 03, 2016 | Craftsman Garden
Mowers shuts off when I engage the pto switch, I jumped all of the safety switches,put new pto switch on, belt and pulleys are fine! Please help
Craftsman Garden Tractor 917.28746 Engine shuts off when ...
www.shopyourway.com > Manage My Life > Questions
Craftsman Garden Tractor 917.28746 Engine shuts off when engaging mower deck. 917.28746 ... Then start the tractor and pull the pto button out. If the engine ...
Why does my engine die when the blade is engaged ... - iFixit
https://www.ifixit.com/.../Why+does+my+engine+die+when+the+bl...
iFixitI have an older Murray riding lawn mower, whenever I engage the mower the engine dies, otherwise it runs .... My dr feild brush mower ... cuts off when I engage theblades. ... My Huskee only shut off once I put it in drive with the blade engage.
Riding Lawn Mower Problem - Dies when PTO engaged - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Apr 28, 2008 - When I pull the switch to engage the PTO, the engine bogs down real ...off I can keep the engine running with the mower engaged then it is fine ... Riding mower cuts out
May 18, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
Craftsman Mower deck (clutch) Won't engage
Jul 1, 2006
More results from forums2.gardenweb.com
Dec 29, 2015 | Garden
Mower starts and runs fine but when button pulled out to engage blades the engine stops hope you can help Paul
your mower deck maybe seized or the safety switch malfunction check if you can turn your deck by hand if yes then find safety switch for deck hope this helps
Mar 30, 2015 | Garden
How do I put my troy bilt mustang xp in neutral so I can push it manualy
On the rear of the engine deck you will see a wire that extends through a small hole. There is one on each side. Pull both out until you can hook the end on the side of the hole. This will allow you to push it freely by hand.
Jun 30, 2014 | Troy Bilt 25HP VTwin Hydrostatic 50" Zero...
Need to put a new belt on the rear of the Troy-Bilt LTX 1842
First buy proper belt... Next note how old belt is warped around the pulleys, take a picture or draw a diagram... Remove all covers off deck pulleys, and guards to expose belt completely... Pull and stretch belt off one of the idler pulleys, once one is off the rest will slide off... Reverse procedure for installation... Note: grease all nipple fittings, bearing and shafts to avoid seizing of bearings or bushings.
Nov 17, 2013 | Troy Bilt 25HP VTwin Hydrostatic 50" Zero...
42 murray mower deck TROUBLESHOOTINGmanual
It sound like pto or safety switch may be shorted. Hope this helps.
Jul 31, 2013 | Garden
Pullcord wont pull out to srart engin
ok. 1. you are not pulling hard enough,or the turning of the motor is jammed or seized. look under mower deck for an object jammed w/the blade and deck.
Apr 24, 2012 | Yard Man YardMan 11A41K3001 21Inch 173cc...
Mower blades froze up
Have you greased the bearings on the mower deck recently? Is there something jamming the blades?
Remove the deck and see if you can move the blades by hand. If you insist on not removing the deck to do this ... make sure the belt that drives the deck is not on the drive shaft of the motor to prevent accidental starting of the motor and instant mangling of your hand. If you can move all the blades, look for a faulty or worn out pulley on the deck. If the blades are frozen in their bearings, get replacement towers at your John Deere dealer or from a FixYa.com advertiser. If one is faulty or rusted ... replace them all ... as they are probably at or near the same condition. Do this job one time and do it correctly.
Thanks for your support.
Thanks for your interest in FixYa.com
Please evaluate this response.
Thanks
Good luck with your repair.
Jul 05, 2010 | John Deere 24HP VTwin Hydrostatic 48"...
NO function at all from mower deck
check if there is 12 v dc going to electric clutch when switch is engaged,if not it is a brake somewhere or the switch has partially blown ,also i have found on my own lawnmower that if the battery decharged slightly that the coil for the clutch just wouldnt pull in,bad connections can cause havic on low voltage thus i would also check this
Jun 29, 2010 | Husqvarna 23HP VTwin Hydrostatic 48" Cut...
2007 Husqvarna Riding mower blade will not engage when switch pulled out. Fuse blows & mower dies! Help!
Sounds like you electric blade clutch is bad. I just had the same thing happen to my exmark mower. I was cutting grass and the engine just shut down. It would not crank over. Checked the fuses and replaced one blown fuse. The engine wanted to crank over but it was locked up. I looked the engine over and seen that the bearing in the electric clutch seized up causing the clutch to melt.
Apr 25, 2010 | Husqvarna 23 Hp 48" Deck Yard Tractor
Craftsman 20 Hp 42" Deck Lawn Tractor Logo
81 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
