Question about Toshiba Tecra M3 Notebook
I have a toshiba m3 laptop, it was going then it froze, so i turned it off, now it wont start up, ac power and the on LEDs light up, if i remove and replace the battery the battery light goes momentarily and there is a buzzing sound i suspect from the cpu or fan, the harddrive spins but the cpu fan doesn't then if i unplug the ac the cpu fan starts for about 20 seconds, no screen changes or anything i don't know what has happened hasn't been over heated or any thing just won't go anymore
  • 2,567 Answers
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
4. The motherboard could be defective & needs to be replaced
Posted on Sep 18, 2010
Easynote tj74 wont turn on
Your not getting power? When you plug the laptop in does the Battery charge light come on? Are you getting power to the laptop? Do you have a multimeter to verify voltage from th AC outlet to the AC jack? Or ,the power gets to the laptop and push the on/off button you get no response? Or, you push the on/off button and the laptop starts then shut down? No lights, no leds blink. Remove battery, Try another cord/charger. Has it been dropped or damaged that would jar loose a connection, or pulled by the cord resulting in a damaged AC jack?
Nov 19, 2012 | Computers & Internet
Toshiba satellite 1005 s157 laptop powers on and then turns off
it could be your ac converter in your laptop.. best bet would be to check the memory, take both the batteries out and try restart it without batteries.. if non of this works i believe it might be your ac con...
success
Jun 18, 2012 | Toshiba Satellite Computers & Internet
Laptop froze now wont restart
remove the laptop battery and turn it on now check the led indications
May 09, 2012 | Toshiba Satellite Computers & Internet
My cursor froze and it wont't move
Try to force your machine to power down (off) by pressing and holding the power button for several seconds (up to 10). If no success, disconnect any AC power and remove the battery. {It can not run without a source of power.} After it has powered down, do what is necessary to restart it. The problem should be gone for the moment. If you had to remove the battery to get the machine to turn off, go into your operating system options and configure the power button to "shut down" a running machine when it is pressed and held down.
Feb 13, 2012 | Toshiba Computers & Internet
My laptop wont start up... There is power going to the machine but it wont boot up... Model is: Toshiba Compaq -#cq60-410sa? Can you help?
One of the possibilities, that the NB does not power ON is due to improper turning off of the laptop or if it was left idle and was not shutdown and just left connected to the ac adapter. Here is one of the simple troubleshooting step you may try. Turn OFF the laptop, remove the power sources (ac adapter and battery). Without power sources, hold power button 10 secs. Put back the power sources, and power ON the NB. If the laptop will not boot by doing this, take it to the nearest repair center to have it check for possible motherboard issue.
Hope this works.
Mar 15, 2011 | Toshiba Computers & Internet
My daughters Toshiba satellite l505d will not boot up correctly. It starts but then nothing happens. What do I need to do. Have already taken battery out and restarted. Any help would be helpful.
Try the following.
1. Remove battery and plug in the AC Adapter and check if it works
If yes - Battery is defective
If no - Motherboard Problem/AC adapter
2. Check the AC adapter LED indicator if its lighted or not(double check by a multitester)
If lighted - it works properly
if not - replace
3. Try to reinstall WINDOWS operating system by the use of the installer CD
4. Reformat your computer and install necessary drivers and applications
Thanks. Cheers!
Apr 15, 2010 | Toshiba Satellite L505-S5966 Notebook
Laptop Toshiba Satellite A200 Model No. PSAF6A-02C01N fail boot
Try removing / swapping / reseating the memory.
Try booting with one stick only, if the top slot doesn't work, try booting the bottom slot. Try both sticks.
Let me know what happens.
Apr 04, 2010 | Toshiba Satellite A200-0ET00X Notebook
My Toshiba wont turn on. I tried holding the power
Hi there, Your ac adapter is damaged & that's why power does not transfer in your notebook. The capacitor of adapter is burned & that's why the noise started. Thanks & waiting for your feedback.
Feb 19, 2010 | Toshiba Satellite A60 Notebook
Toshiba A-135 laptop froze up, dark screen, will not boot
Try this -
1. Remove any USB devices such as ipod, printers etc etc
2. Remove the ac adapter and the battery
3. Press and hold the power button for 30 seconds.
4. Put the ac adapter back in but not the battery
5. Dont plug in any other devices and turn the computer on.
Jan 19, 2009 | Computers & Internet
Toshiba Tecra M3 Notebook Logo
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
