Question about Kenmore Progressive Bagless Upright with Inteli-Clean SystemVacuum
Kenmore bagless 116.36932502 the interior filter port fills up very quickly-withih minutes of initial startup-- and has to be removed and cleaned constantly. Debris backs up into the interior of the main filter as well, the main canister never gets full. New problem with old machine!
SOURCE: model 116 hose clog?
http://geeksquad.fixya.com/ThreadView.aspx?prdid=109459&thid=699656
Model 116 hose clog?
Posted by rfrazelle on Jun 23, 2008
My old canister model 116 followed with numbers 2839580 marked Kenmore 3.9 with power-mate, worked fine until the bag got overly full. I have changed the bag, cleaned the filter, and removed a nasty hair/fur/dust clog :-p from the lower metal tube of the power mate. It now has very weak suction and won't pick up anything. I suspect a clog in the grey plastic flexible tubing attached to the canister but cannot get it apart. Advice?
RJ
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Kenmore 22313 Bagged Canister Vacuum. The best way to find a clog in an electric hose is to use a steel ball or a large marble to place inside the hose and to let it so threw as far as it can to determine where the hose clog is. Once you have determined where the hose clog is then you can use a small end of a broom handle of take an old wire coat hanger and place a hook on the end and try to pull the clog out of the electric hose – the electric hose is very expensive so try not to damage the hose in any way, shape or form. Or another way is that id you have another canister vacuum you can try to pull the clog apart by using two vacuums turned on and running. If you are successful then run the round marble or steel ball thru the hose again and the clog should be cleared.
http://www.sears.com/ Customer Service 1-800-4-MY-HOME 1-800-469-4663
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jun 24, 2008
  • 31 Answers
SOURCE: Smoke coming out of my Kenmore Canister Vacuum Model 22550300C
Sounds like a motor err. Could be repaired by a professional but it never be as good as a new one. Also they you might not find anyone to repair it because the replacement motor might cost more than a new vacuum /considering it's age the motor will be hard to find and that makes it more expensive to repair./
I suggest you to buy a new vacuum.
Posted on Feb 16, 2009
  • 382 Answers
SOURCE: How to replace Kenmore canister vacuum filter.
I believe it faces toward the housing
Posted on Dec 19, 2009
  • 144 Answers
SOURCE: kenmore canister vacuum will not turn on
No, the only effect of not cleaning them would be decreased air flow and consequently . The time between changing filters depends on how much the vacuum cleaner is used. Common failures are damaged cords and a damaged or failed power switch
Posted on Mar 30, 2010
heatman101
  • 43501 Answers
SOURCE: My kenmore quick clean vacuum cleaner has no
The hose or hoses are plugged...take all the hoses apart and stretch them out... run a stiff wire through them or something like a broom handle...you will find that they are full of dust and dirt inside...
heatman101
Posted on Apr 25, 2010
Poor wand suction
your cyclone assembly may need to be striped down and cleaned also remove the exhurst filter located under the bin.
Oct 15, 2013 | Dyson DC17 Animal Bagless Upright Cyclonic...
Hi my dirt devil vision vacuum is having problems. I turn it on and its sounds like its working, but it is not cleaning. Is there a quick fix?
Check there is no blockage in hose. If bagless check filter they clog up quickly I personally dislike bagless vacumns
Dec 18, 2009 | Dirt Devil M088905 Vision Bagless Upright...
It keeps shutting off every two minutes or so. Its only 7 months old and seldom used.
If this is a bagless vacuum then you might have some filters that need cleaning or you have a clogged airduct in the machine that will not allow it to breath cooler. The motor is overheating and shutting down because it can't breath.
Nov 26, 2009 | Kenmore Vacuums
Filter cleaning
The fact is that the "bagless bandwagon" is powered by some excellent marketing that conceals what is often poor technology. In your case, the filter blocks because it's doing the job that a bag would do in a bagged machine (catching the dust), and then the machine overheats because the flow of cooling air to the motor is restricted. The only solution (for this machine) is to keep buying new filters - the only permanent solution is to buy a different vacuum cleaner. And my advice is to buy one with a bag!
Nov 03, 2009 | Dirt Devil M0105 Bagless Vacuum
Handimate doesnt spin!
try ajusting the height if the beater bar also check the belt and motor
somtimes **** gets stuck in the end bearings and add resistance to the beater bar slowing it down remove beater bar abd check assemby for thread and **** build up
Aug 03, 2009 | Kenmore Progressive Bagless Upright with...
I need to take apart my Kenmore Progressive Bagless Upright with Inteli-Clean System
What problem are you trying to fix? The is no belt so you don't need to remove the bottom plate. If you are trying to remove the main hose, remove 4 screws on the back and remove the plate. There are 2 more screws under that.
Jul 29, 2009 | Kenmore Progressive Bagless Upright with...
Kenmore progressive bagless no suction however brush runs well .
remove all the filters and clean themon the bottom you have what is called an intake hose.you will see it as it comes up from the bottom and up on the backside.it connects to a fitting take the screw out and pull the hose away from the back.take a coat hanger and bend the end so its round then work it down through the intake hose,you should be able to push the clog out through the bottom
Mar 20, 2009 | Kenmore Progressive Bagless Upright with...
Suction always seems very poor
you have to have something clog somewhere
Feb 09, 2009 | Eureka 5892AVZ Bagless Upright Cyclonic...
Cleaning my bagless vacuum
Hi Anne,
It does not say to get the filter wet but;;;;;;;;;;;;;;;;; I have had mine for 2 years. When I do a thourgh cleaning of the filter. I actually fill the inside of the filter up with water then hose the outside and let air dry. Another great thing to do is always have 2 filters. Let the one dry out and pop in a new one.
Good luck...
I have only had 2 filters.. and they clean out great with water..
Deb
Nov 17, 2008 | Hoover U6630-900 WindTunnel Bagless...
Kenmore Progressive 36932 Upright Vacuum
It's located inside the vacuum kind of behind the where the dirt is collected. You can open and clean but this is probably not necessary. You probably vacuum very fine dust that is hard to remove from the system.
Try replacing or cleaning all filters and letting the vaccum run for a few minutes without moving. Agitator off of course.
Jun 21, 2008 | Kenmore Progressive Bagless Upright with...
Kenmore Progressive Bagless Upright with Inteli-Clean SystemVacuum Logo
274 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
