Question about Garden
I'm trying to start for first time a 26cc Homelite hedge trimmer UT40502/UT 40903 I purchased few months ago. The thing just does'nt start and does'nt fire at all. I follow all the instructions and nothing happens. Spark plug works. I'm not new at this and in fact I own several gas operated machines. I must mention that the primming bulb is full of gas. Thank you for your help.
  • cafrumusa Sep 19, 2010
    It seems I'm getting really old, I have used that technic in my older machines and even in my old 73 Mercury Wagon. Thank you for reactivating my brains.
  • 857 Answers
HI put a little drop of petrol in the plug hole, replace plug and give it a pull. If it fires up for a moment, it is a fuel starvation problem. Check the carb, clean and make sure the nedel valve in the bottom of the carb is not sticking.
Posted on Sep 10, 2010
Starter rope is stuck, will not move when trying to start the trimmer
Smack the the f%%k out of the reel try to get some w/d oil on it then get a new coil reel when smacking watch for string whip
May 31, 2014 | Homelite Factory Reconditioned 26cc...
Homelite 21" hedge trimmer. Won't start. Has spark, compression, fuel (used a little starter fluid), checker spark arrestor and muffler (clear). I haven't torn it down to check the Woodruff key but it ran...
Abell, put a little drop of petrol in the plug hole, replace plug and give it a pull. If it fires up for a moment, it is a fuel starvation problem. Check the carb, clean and make sure the nedel valve in the bottom of the carb is not sticking. Good luck!
Aug 06, 2010 | Homelite Factory Reconditioned 26cc...
Homelite trimmer, gas, string - y is the string wrapping itself around the head of the trimmer?
The line on my new 26cc Homelite would also feed out by itself. That started me thinking the line was wound backwards. I wrapped the line in the opposite direction as was shown on the bump feed reel and now the dang thing works although the bump feed needs to be "bumped" pretty hard to work. Is it possible that the reel was manufactured with the (string direction) arrows pointing the wrong direction? The new 26cc unit is also underpowered compared to my older 25cc trimmer.
Jul 20, 2010 | Homelite Factory Reconditioned 26cc...
Homelite hedge trimmer , motor runs but blades do
Had the same problem: when I turn on the trimmer, the motor would hum but the blades won't move.
What I did:
1. Sprayed a ton of wd40 between the blades
2. Took a screwdriver and kinda wedged it between the blades to get them unstuck. Also removed some guck between the blades.
And it worked!
May 16, 2010 | Homelite Factory Reconditioned 26cc...
NEED Homelite UT40502 manual
Homelite UT40502 gas hedge trimmer, engine runs fine but
cutting blade will not move back and forth.
Sep 21, 2009 | Homelite Garden
Cutting blade doesn't move
a homelite is disposable, get a new one. You can pull it apart and see what broke and how much the new parts are. worst case, get the new one.
Apr 26, 2009 | Homelite Factory Reconditioned 26cc...
Oil ratio
you can use a 40:1 mix if it smokes then cut it back to 32:1 but a little more oil is better than not enough so start with the 40:1
Jan 17, 2009 | Homelite Factory Reconditioned 26cc...
Garden Logo
35 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
