Question about Kenmore Washing Machines
My Kenmore frontload washer Model 417 sometimes sticks in the fill cycle and will not advance.It will stay that way for hours just running water.If I advance the knob just a bit it will continue as normal.It does not always do this.Seems to happen most when I use the light load setting but has happened in others.It is a small problem but has cost me a shirt and countless gallons of water.I would appreciate any help you may have.
  • 905 Answers
Your water level sensor, or perhaps the selector switch itself, is faulting on you.
Next time it sticks on a medium load, see if you can move it to a light load. If it sticks on a light load, goto medium load. In both cases, if the washer comes back to life (starts to agitate or resumes filling), then your selector switch is out.
If rotating the selector switch doesn't seem to do anything, then your pressure switch / level switch is faulty.
Selector switch and pressure switch are both located in the compartment where the controls are mounted.
Posted on Sep 10, 2010
The washing cycle stops at the final spin. The
If this machine is a Kenmore 417 Sourse (WCI) built washer with a font load,check tech sheet.I had the same problem on a Frigidaire frontload and it was the door latch/lock assembly.These machines can be tricky sometimes.Use tech sheet and make sure lock assembly ohms out ok.
Mar 04, 2010 | Kenmore HE2 Plus Front Load Washer
Our Kenmore Model 110 - 82980120, Stock 29801, 118 G is giving a problem with the Automatic Process. It does not move by itself. It stays at the same place it is kept. If Kept at Wash it stays there, if...
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Jan 21, 2010 | Kenmore Washing Machines
Kenmore HE3t Frontloader Fills Up With Water After Cycle
inlet valves have possibly gotten dirt in them and need replaced . quick fix , is turn the water valves off behind the machine
Nov 07, 2017 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Kenmore washing machine will not fill with water.
The drain hose might be too low. Make sure the drain hose is at least three feet above the floor.
Jun 01, 2009 | Kenmore Washing Machines
Washer wont stop filling
There is probably a plastic tube running from the tub to a pressure switch which controls the water level cutoff on control panel. One can locate this by taking the backcover off and looking at the water level switch and following the tube to the connection on the tub. Tube must fit on level switch tightly for it to work properly.
Apr 27, 2009 | Kenmore 46462 Front Load Washer
Washer does not fill quickly for rinse cyle
check your water pressure if its good check the valve on the back of the washer to see if anything is stopping it up . you may have to replace the water valve
Mar 29, 2009 | GE WBSE2090A Top Load Washer
Front load kenmore washer model 417 will not enter any wash cycle. It will do the rinse and spin cycle but not a wash
will it fill with water? if not listen by the water hose when you press start to wash and see if you hear a faint buzz/humming sound. If so you need to replace the water inlet valve. cheers
Mar 25, 2009 | Washing Machines
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Won't spin or agitate - will pump water water out
This is caused by either a bad door switch or a speed control unit. There is no way to test the door switch but it is the cheapest to replace. Try that first then the speed control. The door lock switch hopefully does it. (even if it locks it can still be bad there is another switch inside.)
Sep 18, 2008 | Kenmore 44102 Front Load Washer
Washing Machines Logo
73 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
