Question about AEG Santo 7085 KG Side by Side Refrigerator
I have an AEG side by side fridge freezer model no. S756281KG3. It seems to be on all the time and the frame surround of the fridge compartment running down the middle of the appliance is getting very warm to the touch. It just seems like its overworking. There is no problem with the seals and I have set the working temperature slightly warmer so it wont have to work too hard. I'mnot sure what to do, Its a very big item and will cost a fortune for an engineer to come out and look at it. I have read somewhere about making sure that the condenser coils are clean, but I dont relly know where they are. The back of the fridge is sheet aluminium, not like old ones I used to remember.
  • AEG Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
The frame that is hot may house the coils and if you have the fridge in a very tight space there is not enough air to cool it properly...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Sep 11, 2010
Good day. I have an AEG double door fridge freezer and the filter light is flashing. After replacing the filter, how do I reset it to stop the light flashing?
The model number is important if you look up the model number example "ABC1234XY01 user manual" Google those words and it should be in there how to reset the water filter light without your specific model number I can't tell you. There's just too many different model numbers to guess on the instructions for that model the model number should be found inside the fresh food compartment around the door
Appliance 911 Sea Breeze
Sep 07, 2016 | AEG Refrigerators
S75400kg fridge not cooling
Suggest you try completely defrosting and restarting.
Feb 18, 2012 | AEG Refrigerators
I Have a side by side fridge freezer approx 3/1/2 years old the freezer is fine but the top half of the fridge isnt cold yet the bottom crisper etc is
Check to ensure that the freezer fan motor is operable (you may need to open the freezer door and activate a button inside the freezer door frame in order to make the fan operate). If the fan works, then you may have an issue with the damper assembly (located in the fresh food compartment at the top left side). It will either be a "manual" or "electronic" concept. Adjust the temperature settings for both the freezer and fresh food compartments at the "half-way mark". You should also have a vent or two at the bottom left side of the fresh food compartment (check to see how far they are openend or closed and adjust accordingly). If the aforementioned doesn't help, contact an appliance service company.
Feb 17, 2010 | Samsung RS2556 Side by Side Refrigerator
The fridge does not seem to be cold enough and the fan inside does not seem to be working - could this be the problem
On most refrigerators you get your cold air from the "freezer" compartment. If the freezer fan motor is inoperable, this will prevent the proper amount of cold air to flow into the "fresh food" compartment. Make certain that the fan motor does not work with the freezer button within the door frame activated. On some models, with the door open, the fan motor will not operate. Open the freezer door and activate the freezer button for several seconds to determine whether the fan is properly working or not. If not, contact an appliance service company.
Feb 16, 2010 | Liebherr Refrigerators
Horizontal fridge freezer - Freezer over-heating
The door frame has a heater to stop ice forming around frame. This is normal. You don't notice it when freezer is cold. The freezer should start working again.
Nov 01, 2009 | Freezers
Warm refrigerator compartment
There is a fan that blows the cold air down from the freezer to the fridge compartment. It is usually called a freezer fan. Most of them are behind the plastic lining in the freezer. I just noticed that your fridge is a side by side. I have never wored on a side by side but I imagine there is fan in them as well.
Jul 06, 2009 | GE GSH25KGRWW Side by Side Refrigerator
Freezer cold /refrigator warm . we have a side by side unit a couple of years old the freezer seems to work fine but the refrigator is warm .It don,t seem to make any funny noises and the back is clean
When the compressor is running, if the fan by the compressor and the fan inside the freezer are both running, and there is no frost on the back wall of the freezer (if there was frost would indicate a defrost issue) then check the air dampener. It is located at the very top left back side of the fresh food section. If it is not opening up, no air will flow from the freezer compartment (where all the cooling takes place) into the refrigerator section.
Jul 04, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
AEG Santo fridge not cooling but freezer is working.
The compressor is obviously still good or the freezer wouldn't work.I'm sure you checked the settings,but turn the freezer all the way up (hot)after it is cool so the unit doesn't come on for the freezer,then turn the refrigerator controls all the way down to the coolest setting.listen for the compressor to start,and/or the fans to run.If the compressor starts,and no fan there may be a problem with the fan.(this is a general test I'm not familiar with your specific unit which may not have a fan,but most newer units do).If the compressor doesn't start after a short time the thermostat/control for the refrigerator section is broken,and needs replaced.
Mar 16, 2009 | Refrigerators
FRIDGE NOT WORKING
Most side by side and other models of refrigerator freezer combinations are of one basic design. The freezer section does the cooling for both compartments. The refrigerator section gets it cold air from the freezer compartment. Therefore check for frost on the back wall of the freezer compartment. If frost is present there you have a defrost problem and it is cutting off the air that cools the refrigerator section.
I think this problem may already be resolved in some manor because of the date of post. Posts should expire after an unreasonable time period.
Mar 19, 2008 | Smeg FA561X Side by Side Refrigerator
AEG Santo 7085 KG Side by Side Refrigerator Logo
151 people viewed this question
Top AEG Refrigerators Experts
ashburton
Ian Jones
David Jewell
Are you an AEG Refrigerator Expert? Answer questions, earn points and help others
