Question about Canon DR 3060 Path-Through Scanner
The scanner works but makes a grinding noise that is getting worse
  • 490 Answers
Normally Canon scanners work well for long time, Change the pickup rollers for every 250,000 pages and check other rollers for every 500,000 pages. In case you have been scanning documents with quite a good amount of dust, you may need to check at an earlier interval. Replace any worn out roller. Check if the small bearings at the end of each roller is perfect. Clean thoroughly all the rollers, dont use solvents. S. Mohan, Chenna, India
Posted on Sep 11, 2010
  • 78 Answers
Grinding noise will generally mean a frozen roller or a roller that is having a hard time moving. Clean or replace bushings and rollers to get rid of grinding noise.
Posted on Aug 12, 2014
3 Suggested Answers
Chunney
  • 12 Answers
SOURCE: scanner making grinding noise
Please open and apply oil on roller rod as some rust have accumulated on it prohibiting it move.
Posted on Apr 03, 2008
printerman40
  • 170 Answers
SOURCE: Grinding noise
There is usually a slide type button somewhere around the outside of the scanner and it usually has a lock & unlock sybol on it. You may want to make sure that it is slid totally in the unlock position because it could be getting caught inside once in a while if the button is say half way between lock and unlock... Hope this helps...
Posted on Sep 24, 2008
I have a grinding noise in my front left and the vehicle pulls really bad to the left
you most likely need to have your front brakes replace post haste. the grinding noise,does it get worse when you apply the brakes? the grinding noise will be a bad brake rotor and will also make you car pull hard one way or other depending on which brake is worse. recommend highly that you have those brakes looked at. the more you drive it, the worse the problem will be.thank you for choosing fixya.com and please rate my solution thank you!
Dec 30, 2010 | 2004 Ford Explorer
Rumbling & grinding under front end
Watch out! You might have a loose wheel! Check those wheel nuts. If not, a loose brake caliper, or last if not least, a bad wheel bearing. Don't drive it until you find out what the heck is wrong! Could be dangerous.
Jul 06, 2009 | 1999 Chevrolet Cavalier
04 cavalier makes grinding noise in front end turn the wheel to the right grinding gets worse turn the wheel to the left grinding stops. it sounds worse at 40mph and above. what would cause this?
3 things to check:
Worn disc brake pads, grinding against the rotor.
Wheel bearing
cv joint.
You posted grinding gets worse turning to the right, the problem is the driver side wheel, but it would be best to have both wheeles checked.
Jun 19, 2009 | 2004 Chevrolet Cavalier
Kenmore Elite 137889, grinding noise
If the noise is like a shaking of rattling , like coins being shaked , then it is an object trapped inside the tub.
If instead the noise is a loud grinding , that may get louder on high speed, then it is usually a bad drum bearing.
The drum bearing is replaced by accessing the bottom side of the washer, and is a not a simple repair.
May 05, 2009 | Kenmore 13789 / 13782 Dishwasher
Grinding noise
The most common problem is that the pulley breaks, you might be able to see it through the glass. looks where the belt goes, and see if the pulley is broken.
also, some people forget to unlock the locking mechanism when the unit gets moved, the locking switch is on the side.
Apr 09, 2009 | Epson Office Equipment & Supplies
Grinding noise in cartridge for hp laserjet 1200 series printer. I replced cartridge and still hear noise sometime worse and then not so loud.
I have the same problem and I know what is causing my problem. It's not in the cartridge. You're laser scanner is going to go bad. I had the problem 3 months ago. I would only make the grinding noise when it powered up. Printing was okay. I don't use the printer that much. Then about a week ago I notice only the bottom diagnostic light was on. I unplug the power and powered it back up. The grinding noise got louder and wouldn't stop. I unplugged the printer an replugged. Same thing.
I was bored (christmas day) and decided to open my printer to see what the root cause problem was. I removed several screws and once I got all the printer naked (removed all the plastic outside). I plugged it in an tried to listen where the problem was. I notice a vibration at the laser scanner (top black piece). I unplugged the printer. I unplugged the power source to the laser scanner. Replugged the power and saw all the gears move with no noise. Powered off. Replugged laser scanner. Powered on. Noise back. Defective laser scanner. The laser scanner has a ribbon cable, and four purple wires going to it, oh yeah there is a big yellow warning label, so you can't miss it. I hope this helps.
Nov 26, 2008 | HP LaserJet 1200 Printer
Grinding noise
Sep 24, 2008 | Panasonic KV-S2026C Pass-Through Scanner
Scanner making grinding noise
Jan 01, 2008 | Canon CanoScan LiDE 30 Flatbed Scanner
Canon DR 3060 Path-Through Scanner Logo
345 people viewed this question
old marine
old marine
