Question about Philips 190B6CB/27 19" LCD
Hello! What does "Security flag off" mean? I started to get this message on my monitor and I don`t know how to fix it.. Thank you! Ana T
  • Louis Ebert Sep 15, 2010
    ana topala, tell me brand name of the filter capacitors on the units power-supply board inside your unit. 12fixlouie
What does australian flag mean
It has to do with their British heritage, their geologically southern location, and also the territories. The following page really describes it in great detail:
Australian Flag The Flag Meaning
Jul 14, 2014 | Computers & Internet
Security code forgot
What is most likely to happen since you do not know your security code is you will need to set your phone back to default settings, which means you will lose all of your personal data, including but not limited to: messages, linked online accounts, contacts etc.
Please search google for your devices unique hard reset instructions.
Thank you,
Dish Guy
Apr 22, 2014 | Nokia 7230 Cell Phone
How do i fix if my computer scan is out of range
I am assuming you are talking about your monitor. What this message means is that your monitor can't handle the resolution your video card is set to. Re-start your computer and as soon as the first screen goes by (you know the one with all numbers and stuff) start hitting the F8 key. This will start the computer in safe mode which uses a very low resolution (usually 640 x 480). Once you see the display set the resolution to 800x600 which any display can handle. Re-boot and log in again and change the resolution to something higher. Test different settings. If you set one that is too high and you can't see the screen again don't touch anything as the screen will revert back to the previous setting if you do not confirm.
Hope this helps. If it does don't forget to give me a thumbs up.
Aug 29, 2011 | Dell P780 17" CRT Monitor
I can't start my 2008 Jeep Grand Cherokee with either key fob. Once I got a "Service Security Key" message. Another time I got the "Key not programmed - Damaged key" message. What...
Hi Hal,
Did you ever get this resolved? Looks like you didn't get any feedback here! I'm having the same issue sporadically. I turn the key and nothing. Usually if I keep trying it will eventually start cranking and start. Usually within 10 - 15 tries. happened last night. After it started, I got the "Service Security Key" message. I looked in the manual and it does say what that means. Don't know if it is programming (probably not because the fob works 97% of teh time) or maybe just a dying battery. If you can share anything you might have founf out I'd appreciate it! thanks!
Brian
Jul 04, 2011 | 2008 Jeep Cherokee Grand
I am getting security Flag Off pop-up on my LCD screen
One (or more) of the buttons on the monitor is dead. You can probably confirm this by pressing them and you will realise some might now work or be intermittent. You need to open the monitor (just a few easy screws). Unplug the row of buttons from the wire plug at the end. This will solve your problem. If under warranty get it fixed if you could be bothered or if you know electronics check the buttons and replace them on their circuit board. Note this action will no doubt void warranty but it works.
Apr 24, 2011 | Philips 190B6CB/27 19" LCD
Need help with a new video card I install in my dell precition 360 don have video
Hello there,
This is the supported Graphics Cards the computer you have can use
Graphics Support . . . . . . . . . . . . . . . . . . . . . . nVIDIA® Quadro 4 280 NVS 64MB DDR, AGP 8X, available in single or dual VGA and single or dual DVI
nVIDIA QuadroFX 500, 128MB DDR, AGP 8X, dual monitor (VGA and DVI or two VGA)
ATIæ Fire GLô X1, AGP 8X, 128MB, dual monitor (VGA and/or DVI)
3Dlabsæ Wildcat4ù 7110, AGP 8X, 256MB DDR, Dual monitor (VGA and/or DVI)(Desktop chassis only)
let me know the Model of the Video Card you are trying to install and we can start fixing the problem
Thank you don't forget to Rate
Jan 25, 2011 | Dell Computers & Internet
Acer security manegement
dont take it seriosly. Search about this problem on google. Thank you
Jun 02, 2010 | Computers & Internet
Hello; My Omron HEM 712C shows message: EE Can
'EE' means cuff is underinflating. Re wrap cuff with varying amounts of pressure and restart [wait 2 minutes between readings].
Dec 15, 2009 | Omron Hem 712CLCN2 Cuff Blood Pressure...
Monitor failure
Vic,
Try to send the photo of your monitor esp view from behind and side view of may be I could provide you more help.
As for your notice no power does not meant the the fuse only blow.There might be other component shorted. Or if you have the technical background surely it will help you much.
Thank you for reply.
jemmy
Apr 20, 2008 | Computers & Internet
Philips 190B6CB/27 19" LCD Logo
293 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
