Question about ASUS Eee PC 1000H Laptop
Hi! i hope i could have answers for this. I forgot to turn it off and it was just open from evening till morning. When i start to open it, it started but later it died. Now, it has no power and it is not even charging. Thank you..
    Guru:
  • 689 Answers
When you shut down you will have 4 options make sure you didnt enable "standby" which can put the pc into a dormant mode whereby the lid can be shut but it is still on.Switch it off correctly then restart to see if this really was your problem
Posted on Sep 10, 2010
My perguote 208year will not start until 34 turn over have to put foot on excelarater in mornings to start after that no probplem start right away till next morning same problem.
get ignition coil checked. If it is EFI DO NOT press on Accelerator when starting it.
Could have a leak in fuel and it evaporates over night
if carby fuel may be leaking out over night as vapour. In mornng you are fuel pump refilling fuel into carby until it starts again.
Mar 12, 2016 | Cars & Trucks
2003 110,000 miles pulled in driveway everything fine. Went to start the next morning nothing. Tried to jump start no. Pulled battery as battery light was on and checked good at Auto Store. Monitor and...
Check your car's ground to make sure it's getting contact, This is the black wire from your battery, follow it till it connects to your frame. may need cleaned for better contact. If this don't work check your positive connection on your starter "the big nut" Because if even in your coil pac it would turn over just not fire, Good luck to you hope this help's.
Apr 02, 2011 | 2003 Chevrolet TrailBlazer
Hi my washing machine door wont open, feels like the lock has broke ??
hi have you tried turning machine off at plug for a min then power back on put on a cycle press start. wait till it starts to fill and press stop and hold down the reset button till it beeps and wait till door unlocks. Or a quick way to open the door is unclip the foot kick stopper at bottom front of machine and pull the emergency door open which is a thing peace of hanging plastic. if none of this works try starting a cycle then press stop soon as it starts to fill and turn off on machine not at plug. hope this helps.
Sep 20, 2010 | Hotpoint Ultima WF860 Front Load Washer
Hi i have a m reg vauxhall cav 1.9 turbo diesel im haveing trouble starting in the morning and i have changed the following, battery and the glow plugs. engine is turning over for about 8 mins on and off...
if you have changed the glow plugs and it still plays up try changing the leads that run to each glow plug if that doesnt help theres a pre heat box relay which is for the glow plugs should be somwhere near inner wing check it is clicking over after you turn the ignition to start position youll get the pre heat light on the dash once that goes listen ans you should here the box click .hope i could help
Dec 23, 2009 | 1996 Volkswagen Jetta
On the master glo website it tells me - as a standard factory settings rule - that to open the lock i have to turn 3 times to the right to start - is that three full turns ?? could you explain how to open...
Let me see if I can help. I started out to write you an explanation when I found this video for you to watch...It explains better than I ever could.
CLICK BELOW and when you get to the site, scroll down the page on the right, till you get to " Combo Lock Training Tool " listed under " MASTER LOCK SERVICES " Click on Combo Lock Training Tool and a video will download that you can watch.
Hope This Helps,
RSMITH972278
P.S. PLEASE RATE MY ASSISTANCE
http://www.masterlock.com/residential/schoolcampus/glo.shtml
Nov 25, 2009 | Locks & Locksmithing
1999 dodge durango will not start
sensor on backside of throttle body two hex screws gently remove as you can break brass fitting spray with throttle body cleaner till it comes clean open throttle all the way spray butterflies till they are clean imediately drive five miles as it takes ecu that far to relearn sensor five miles no less
Jan 17, 2009 | 1999 Dodge Durango
Reset and unlock
try this. switch off your phone and turn it on. while phone is starting up. press the * key + answer key(green) + 3 key together till the welcome tone play.
BE SURE YOU BACK-UP ALL YOUR FILES SPECIALLY PHONE BOOK FOR THEY WILL BE DELETED..
HOPE THIS WILL HELP YOU..
Nov 13, 2008 | Nokia N70 Cellular Phone
Wwasher will not start
Likely someone forgot to connect the motor controller during manufacturing and this is not a user-serviceable system - let the service folks fix it - especially considering they may have to replace the entire machine under warranty.
Feb 18, 2008 | Whirlpool Duet GHW9150P Front Load Washer
ASUS Eee PC 1000H Laptop Logo
59 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
