Question about Office Depot Ativa DQ60M Shredder
Large white gear on a Ativa DQ83M paper shredder is broken. Can it be replaced? If so, where can I purchase a new gear?
exspert
  • 55 Answers
SOURCE: Shredder won't turn on
ok " if the ready light did not come on it's telling you that there is no power sound like the plug in transformer is no good .
you can check that transformer , with a multimeter, see if you have the right voltage.
Posted on Jan 27, 2008
  • 333 Answers
SOURCE: Shreader Malfunction
If the gears are stripped it will cost more to buy them and pay for the shipping if it is not under warranty. You also have to think if the gears are stripped what caused this to happen. It probably put a lot of stree on the motor also. So you may not have a loy of time left on your motor. I hope this will help you.
Posted on Nov 25, 2008
SOURCE: XF50D motor won't turn shredder blades
Call ATIVIA # 877 777 4357 fax 866 765 0063 and they can help you. I GONNA GET BACK MY $$$$$$$$ .
Posted on Jan 12, 2009
  • 35 Answers
SOURCE: Broken teeth on drive gear wheels Taros paper shredder Taros 31.8
New gears are $88.50 plus freight. You won't find any used gears because these usually break first. I can help.
Posted on Feb 23, 2009
splintellz1
  • 37 Answers
SOURCE: Need Ativa X1800 Shredder Parts
Hey check out this link they service all types of shredders hopefully they should be able to service yours.
http://www.factory-express.com/blog/2005/10/paper-shredder-parts.html
Posted on Jul 03, 2009
Ativa shredder
Most likely it will be a broken gear, you will need to disassemble the unit to replace the gear if you have the replacement ready. Try searching web for ativa spares and order gear for you model, otherwise you might need to disassemble the unit to remove old/broken gear and use it as sample when purchasing the replacement. If you know what you are doing the replacing gear task start to finish should not take more than 20minutes however it might take considerably longer depending on your technical knowledge and skills. Good luck
Oct 05, 2013 | Office Equipment & Supplies
I have an Ativa MD 460 shredder, it is misaligned with paper. Can you help?
ativa md460 misaligned Questions & Answers - Fixya
www.fixya.com > Forum > Tags
Find solutions to your ativa md460 misaligned question. Get free help, tips ... I have an Ativa MD 460c paper shredder that reads misalignment. What do I do?
Just purchased ativa MD 460C and it will not work. misaligned
www.fixya.com/support/t9496803-just_purchased_ativa_md_460c
Jun 16, 2011 - Look for a curve in the lip on the back of the shredder and align it with the ... I have an Ativa MD 460c paper shredder that reads misalignment.
Ativa MD460 paper shredder: misalignment light is on - Fixya
www.fixya.com/.../t7580117-ativa_md460_paper_shredder_misalignme...
Jan 1, 2011 - I have a Ativa MD 1000 that I just bought. It ran for a few minutes the first time I used it an then stopped. I turned it off and unplugged it in case it had ...
Office Depot Ativa DQ60M Shredder Misaligned - Questions ...
www.fixya.com > ... > Office Depot Ativa DQ60M Shredder
just purchased ativa MD 460C and it will not work. misaligned is highlighted. can u help... I have an Ativa MD 460c paper shredder that reads misalignment.
Jun 07, 2011 | Office Depot Office Equipment & Supplies
I have a Ativa DQ60M Paper Shredder and it is very clogged with paper and it looks like some of the blades are slightly bent. Can it be sent in for repair or warranty?
Take away info: 3-year warranty on cutter.
Office Depot item #405935: Ativa DQ83M Diamond-Cut Shredder (mine show model ...Mn. It has a 1-year warranty for product, BUT ALSO a 3-year warranty for the "cutting cylinders". Call 1-877-777-HELP; www.ativaproducts.com .
I called 12-29-2010. Rep had difficulty finding product, put me on hold, found it. Said prod only has 1-yr w (per Office Depot online, this is all that is given as to info); but I said, no, 3-yr on cutter. I held again, rep researched and agreed. I took a case number and tried rep's troubleshooting suggestion: I put 3-in-1 oil (veg oil suggested by rep too) on the jammed shredded paper (machine still would go in reverse BTW); I let it soak 5 mins, removed paper, tried shredding, and paper jammed again. No replacement parts are avl. I called again, gave case number. Rep suggested I oil the cutter now that paper was removed. I said cutters are oiled from removing paper. I was put on hold, only a short while.
Good outcome thus far: I was given fax number and instructions to receive gift card in 6-8 weeks upon their receipt of my fax (to 1-888-561-0785) of case number, name (first and last), mailing address, and copy of the receipt.
What I learned: Do the maintenance oiling monthly or more if needed! Try to buy a shredder that is beyond my shred needs, e.g., a 10-sheet cutter but use it only up to 8 pages. Try to buy a shredder that has replacement parts.
The price of the Ativa in 2008 was $40 ($30 instant savings taken at the register), and it didn't get daily or regular use.
Good product support on this Ativa product. Glad I saved my manual and receipt!!
Dec 22, 2010 | Office Depot Ativa DQ60M Shredder
DQ83M ATIVA SHREDDER ...LIGHT IS ON BUT DOES NOT SHREDD
The RUN green light is on but no motor is operating for any function of the Ativa DQ 83Mn Shredder. What can be inop?
Sep 17, 2010 | Office Depot Ativa DQ60M Shredder
Ativa X1000 paper shredder that doesn't turn on
took the shredder section apart, cleaned out the gears of paper and a broken mount (plastic piece), and hand turned the electric motor to free it up. After assembly, the ready light works and so does the FWD/REV directions for shredding.
Nov 10, 2009 | Office Depot Ativa DQ60M Shredder
Jan 19, 2009 | Intimus 385 se Shredder
Main drive gear is damaged on and Ativa shedder
If you main gear drive is broken you probably had a paper jam, so your shredder blade gear will break soon. By the time you purchase the part and pay for the shipping it would cost just about the same as gettin a new one. Then you will not have to wotty about anything esle breaking after you get this part because of the stress you put on the motor and other gears. I hope this helps you.
Nov 25, 2008 | Office Depot Ativa DQ60M Shredder
Sep 26, 2008 | Office Depot Ativa DQ60M Shredder
On the right side of the waste basket(as you face it) is a tab that pushes a button on the shredder when it is in place. The tab is not making contact with the button. Push the side of the basket where the tab is when you have paper to shred in it. If it begins to shred, you may have to bend the basket inward so that the tab makes contact. I have had this problem.
Aug 24, 2008 | Office Depot Ativa DQ60M Shredder
Office Depot Ativa  DQ60M Shredder Logo
Top Office Depot Office Equipment & Supplies Experts
Anthony Karuku
quennie732
Stan Marciniak
Stan Marciniak
Level 1 Expert
Are you an Office Depot Office Equipment and Supply Expert? Answer questions, earn points and help others
