Question about Lexmark Wheelwriter 6 Series II Typewriter
My IBM Wheelwriter 6 does dot print after changing the ribbon
Kindly adjust the governor wheel upstream.
Posted on Sep 11, 2010
Ribbon will work in one Wheelwriter 6, no print output in another one
Your print solenoid probably has a broken cap. There are some companies that sell the "kit" with instructions on how to replace the cap.
Jan 16, 2014 | IBM Wheelwriter 6 Typewriter
IBM Wheelwriter 6 - Ribbon doesn't lift high enough for the key that's pressed to print on paper. Ribbon advances OK.
If theribbon dosen't lift at all see if the black gear on the R. side of the printer will move, if not w3iggle it and it should free up they get tooth for tooth with the motor gear. If it only lifts partually thereis an adjustment on the roll that works with the black gear. BE SURE TO CHECK THGAT BTHE PLATEN IS FULLY SEATED IN THE VSIDE FRAMES THEY DO GET LOOSE!
DickyO
Jun 30, 2012 | IBM Wheelwriter 6 Typewriter
IBM Wheelwriter 6-Letters striking paper above
Put in a multi part form and type if the carbons come out OK the the ribbon isn't lifting, Wiggle the big black gear on the R. side of the carrier back and forth. They do get tooth for tooth when they get old. If the print on the copies id bad or not there you need a print solenoid cap. We sell them for 20,00 including instructiond and shipping.
DickyO
Cleveland Business Machines
216-241-0027
Feb 18, 2010 | IBM Office Equipment & Supplies
Characters do not print.
The print solenoid plunger has a plastic cap on the end of the plunger it is probably broken. They are available but you need a bit of mechanical ability to install.
DickyO
Mar 18, 2009 | IBM Office Equipment & Supplies
IBM Wheelwriter 6 - cannot print
The print solenoid, just inside the L. printer side frame has a plastic cap on the plunger it is probably broken, they are available but a little tricky to install.
DickyO
Mar 15, 2009 | IBM Wheelwriter 30 Typewriter
The plastic cap on the print solenoid plunger is probably broken they are available but a little tricky to install.
DickyO
Mar 14, 2009 | IBM Wheelwriter 30 Typewriter
Put new ribbon cartridge in ibm wheelwriter 3 not printing now
If the ribbon is lifting up you probably have a cracked print solenoid plunger cap. They are available but a little tricky to install.
DickyO
Feb 10, 2009 | IBM Wheelwriter 30 Typewriter
IBM Wheelwriter 6 prints only top portion of characters
The platen is probably not all the way in. Be sure the black latches are lined up with the side frames and press firmly down on the platen.
hope this helps
DickyO
Feb 25, 2008 | Lexmark Wheelwriter 3 Typewriter
Typewriter not printing
There is a plastic cap on the end of the print solenoid plunger that nis probably broken the part is available about 10.00 but a little tricky to replace.
dickto
Nov 27, 2007 | Lexmark Wheelwriter 6 Series II Typewriter
Lexmark Wheelwriter 6 Series II Typewriter Logo
74 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
