Question about HP LaserJet 2300d Printer
Well in an HP 2300 if both trays 2/3 produce the error than it's definitely not the tray size switches.. but more than likely the top of paper sensor which sits on the power supply board is bad.. if not then it's definitely the engine controller board. Ist try the engine controller board because of cost and easier to perform the repair.. then if the problem has not been fixed then it's the power supply board in which the sensor is attached.. this should work.
  • 99 Answers
Mail me printerman007 at gmail.com
Posted on Sep 11, 2010
Hp2300 jams half way out of tray 1 and tray 2
1. Up to where paper traveled.. If its reached up to Fuser assembly & curl folds accrued under cartridge.. replace Teflon sleeve or Fuser assembly.
2. If paper traveled up to Fuser out(near 2-3 inch)...Clean/replace/flag Fuser out paper sensor
3. If paper traveled up to registration assembly:Clean registration sensors/flags.
4. Check pickup rollers.
Feb 20, 2013 | HP LaserJet 2300 Printer
When i print it defaults to tray manual feed. i
change paper size setting on printer preferences on your pc
Apr 21, 2010 | HP Office Equipment & Supplies
Can not print to Tray 2 on HP 3800 printer. Says Tray is empty
check the paper type and the paper size from the printer menu, if it is ok then you will try to check the paper sensor on tray 2
Jan 08, 2010 | HP LaserJet 3800n Printer
Hp laserjet 8150. i have a problem, tray 3 empty, always but have paper in tray 3
CAUSE: This error message indicates the paper present sensor flag in one of the trays does not detect paper in the tray. This could be caused by one of the following:
  • A broken sensor flag
  • The tray paper guides being set too close and restricting the paper from being pulled
  • The tray is not lifting
SOLUTION: Follow the steps below to determine the cause of a false TRAY X EMPTY message. Tray 2 empty
  1. Verify there is paper in the tray.
  2. Open the duplex unit access door just above Tray 2 on the front of the printer.
  3. Check the black-paper present flag by looking in through the duplex access door.
  4. Open and close Tray 2 and observe the tray lifting looking through the duplex unit access door.
The tray lifts but the error is still present
  1. Inspect the paper present flag on the PIU located just behind the pickup rollers. Ensure the flags are present and not damaged.
  2. Remove the tray guides from the tray and reseat them. Ensure the guides are seated correctly and are in the correct slot for the size paper in the tray. Add paper to the tray and try printing again.
  3. Try another known good tray, if available.
The tray does not lift and the error is still present
  1. Remove the tray, remove the paper in the tray, and inspect the lifting plate in the tray for damage. Ensure it will lift freely by hand.
  2. Try another known good tray if available.
Tray 3 empty
  2. Remove Tray 2.
  3. Open and close Tray 3 and verify it lifts by observing through the Tray 2 cavity.
  3. Try another known good tray if available.
Tray 4 empty
  2. Open Tray 4 and check for an extra **** of paper stored on the left side of the tray. This can cause the tray to stall while lifting and result in a tray empty message.
  3. Defeat the interlock in the vertical transfer unit (VTU). Open and close Tray 4 and watch the tray lift through the VTU door on the lower-right side of the printer.
    NOTE: Follow troubleshooting steps for Trays 2 and 3 when working with the 2 X 500 sheet-input tray.
  1. Check the tray guides to ensure the guides are seated corrected and are in the correct slots for the paper size in the tray.
  2. Inspect the paper present sensor for damage.
  3. Check for any broken plastic pieces in the tray that may be a broken sensor flag.
The tray does not lift and the error is still present Defeat the VTU interlock on the right side of Tray 4. Open and close Tray 4 and observe the tray lifting.
Nov 25, 2009 | HP LaserJet 8150n Printer
I get error code 41.3 and a message saying I have the wrong paper size. I have tried the paper handling menu, but nothing I do seems to help. When I have the printer use the open paper holder, it works,...
Generally there are a couple of tray elements that can affect a paper size error. Check to make sure the width and length support elements are located and locked properly. See if a small switch is located on the tray that designates the appropriate paper size being used. I have had users accidentally move the switch from standard to legal and prompt an error that would not be reset until the switch was moved to the correct position. My problem was with an HP 4350 but the two units may have the same switch element.
Nov 03, 2009 | HP LaserJet 4100n Printer
Hp P4515n - Paper Handling for tray-2 only, gives
I just ran into this same issue with an HP LaserJet P4015n. Worked with HP and the resolution ended up being the following.
Hopefully this will work with the P4515n printer as well.
1. Open EWS page (printer page) in Internet Explorer.
2. Log into printer as administrator
2. Click on Settings tab, Configure device, System Setup
3. You will find Tray Behavior
4. Change tray 2 model to Standard Tray.
This should give you the standard options for the Tray 2 size or default to the size detected.
Aug 20, 2009 | HP P4515n LaserJet Printer
Error message keeps appearing "paper jam in tray 2" although there is definitely no paper jam.
If you did not get ALL the jammed sheet out, there is still a small piece of paper in there somewhere, probably covering a sensor or micro switch. Get a torch and look carefully. If you don't find anything you may need to disassemble the printer to find it.
May 02, 2009 | HP LaserJet 2300dn Printer
Konica 7115 copier
not familiar with that machine, but
most of these problems are simple, usually customer errors
1-some have sensors in the bak of the machine where the tray slides in, remove ray and look for paper in the back
2-is there any slides or something to adjust to say it is 8.5x11?
3-switch trays is it recording the correct size- if yes the sensors are ok
4-take alook at the other tray it is probably set for a different size paper, try switching it to letter and see if there is a difference in the way the trays are
4- it could be set wrong in the menu
5-bad sensors
Jun 20, 2008 | Office Equipment & Supplies
Xerox Phaser 7700 displays error 7-276
Here is the documentation on that error
07-276 TRAY 3 PAPER SIZE SENSOR BROKEN (TTM)
EXPLANATION
An abnormal AD value was detected from the Tray 3 Paper Size Sensor.
Refer to BSD: CH7.4 CH7.13A
Procedure
Set Tray 3 in the machine.
Between Tray Module PWB J548-11 (3T: J548-11 , TT: J548-11) (+) GND (-)
Is the voltage the same as that in the Tray 3 Paper Size Sensor Output Table inscribed in BSD: CH7.4?
Yes No
Between Tray 3 Paper Size Sensor J820-2 (3T: J820-2 TT: J820-2 ) (+) GND (-)
Is the voltage the same as that in the Tray 3 Size Sensor Output Table inscribed in BSD: CH7.4?
Yes No
Between Tray 3 Paper Size Sensor J820-1 (3T: J820-1 TT: J820-1 ) (+)J820-3 (3T: J820-3 TT: J820-3) (-)
Is the voltage +5VDC?
Yes No
Using the wire network from Chapter 7, check the +5VDC circuits to Tray 3 Paper Size Sensor J820-1
(3T: J820-1 TT: J820-1 ).
(WN 7.3.6 +5VDC-2)
Check for malfunctioning paper guide, poor contact caused by bending in the projection that pushes the switch, and
if there is no problem, change the Tray 3 Paper Size Sensor. (PL16.1)
Check for cut wires, poor connections between Tray 3 Paper Size Sensor J820-2 (3T: J820-2 TT: J820-2 ) and Tray Module
PWB J548-11 (3T: J548-11, TT: J548-11)
Change the following parts successively:
TRAY MODULE PWB (PL16.9)
MCU PWB (PL13.1)
ESS PWB (PL13.1 ).
Apr 26, 2008 | Office Equipment & Supplies
Tray 1- load plain letter
Linda,
On printer check media/paper type tray 2 or 3 is plain and tray 2/3 is set for letter paper size too, via printer control panel. Also check under paper handling other options for tray 1, also on tray 2 and 3, I think there is a blue little round switch on left should be set as letter not custom.
Some paper types cannot be feed from anywhere else but tray1/bypass ie labels/laminate/card stock.
Check print driver on pc has tray 3 option installed and is not set as default to print to manual bypass/tray 1
light flashing cause printer wants paper type/size that it "thinks" it hasn't got in tray 2/3
If that dont cover it...post back
Soulvisitor :-)
Dec 18, 2007 | HP LaserJet 4100n Printer
HP LaserJet 2300d Printer Logo
97 people viewed this question
Seeker5211
Seeker5211
