Question about Toshiba TEC B-572 Printer
Receiving error "No Paper" but there are labels loaded
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Toshiba TEC Expert
  • 142 Answers
Have to callaibrate the sensors or you have a problem with the size of your label. The gag is in the sensor when printing starts or stops.
Use the tear option to try to correct this error or use a longer or shorter label.
Posted on Dec 09, 2013
2 Suggested Answers
Gort007
  • 1187 Answers
SOURCE: We have a Canon Image Class MF3240
The problem is on the computer, not on the printer.
"A4" is a paper size, just like "Letter" and "Legal".
You probably have your software application, such as Excel, Word, etc., set to paper size = A4.
Do this in your program on the computer:
[File]
[Page Setup]
[Size] "8 1/2 x 11"
... and print your document again.
Posted on Mar 19, 2010
Paper out error
Have you tried a full media calibration from the menu (removing 8" of label from the backing)? Also if a label has left any pieces behind on the rollers, strike plate, etc it can cause this problem. I use a solvent like Goo Gone to make it clean, but be careful not to wipe the sensors with it. Also I have seen this when my users miss a roller when loading the ribbon. Make it clean, load it carefully and usually it works.
Jul 25, 2012 | Zebra 170XiIIIPlus Thermal Label Printer
I am trying to print a label through the document feeder and keep receiving error messages on my Brother MFC9320CW AllInOne Printer .."Open the Top cover and pull out all 4 drum units completely and...
Try putting more than one sheet of labels in the paper tray. Even if you're printing one label, it helps the printer grab the paper without that error somehow. If you're already using more than one sheet, I don't know. Good luck either way!!! :)
Jan 18, 2011 | Office Equipment & Supplies
My new hp 2035n printer give an error when i try to print. the error says: load paper to tray 1
Instructions Things You'll Need:
  • Inkjet printer
  • Labels
  1. 1
    Prepare your printer. Make sure the power is on and the drivers are installed correctly on your computer.
  2. 2
    Wait for printer to stop. Make sure your printer is idle or ready or waiting for paper to be loaded. Don't load labels when your printer is already printing or running an operation.
  3. 3
    Prepare your labels. Make sure they are all facing the same way and are right side up. The label side should be face up. Many labels have an up and a down as well, look for a "this side up" or "load this way" indicator. Or take a look at the print preview before you print and make sure your labels will be fed correctly.
  4. 4
    Find the correct paper tray. Some printers have manual feeds and automatic feeds. Refer to your manual to find out which one you should use for labels. If you are going to use the manual feed, follow the manual's instructions. However, most printers will use the automatic feed, so read on.
  5. 5
    Align the paper guide. This is a moveable piece on the paper tray. There should be markers for the width of your paper. Standard pages are 8.5 inches. Move the marker so your labels will fit.
  6. 6
    Load your labels. Place your labels in the tray so it touches the immoveable side of the paper guide. Slide the paper guide over to touch the other side if it is not already close. Do not bend the labels by pushing in too far.
  7. 7
    Find the paper thickness lever. Try looking under the door that lets you change the cartridges. Or search around on the back or side. Check your manual, too.
  8. 8
    Set your paper thickness level. Usually you'll use the standard size. However, your printer may need to use a thicker setting. Check your manual.
  9. 9
    Change your media type. In your printer settings, find the media type option. You can access settings by clicking properties or settings on the print dialog right before you print. Select "labels."
Oct 02, 2010 | HP P2035N LaserJet Monochrome Printer
Error 0xb9000003
* Where exactly you are receiving this error, on the printer display or on in computer?
* When exactly you are receiving this error?
* Does the unit print a self test page? Steps are given below:
1. Load the paper tray with unused plain white paper.
2. Press Setup until Print Report appears on the display, then press OK.
3. Press OK again. The self-test report prints.
:) Dr Tony
Apr 17, 2010 | HP PSC 1610 All-In-One InkJet Printer
Zebra s4m error condtion paper out
Sounds like you will need to perform the calibration procedure.
when you access the menu system go to advanced menu, the password is 9999, use the keys to navigate to manual calibration and follow the instructions. when it states load backing this is refering to backing paper, so remove the labels from the backing and place in label path. hope this helps
Jan 16, 2009 | Zebra 105SL Thermal Label Printer
Error Code E014 Casio PCR-T470
Hi. When they run out of paper, you just load a new roll, and the machine will automatically continue. There is no need to clear the error. It will continue when it senses fresh paper in the receipt side.
Jan 11, 2009 | Casio Parts Cash Register PC Desktop
I am receiving Error Code E014 Receipt Paper for Casio PCR-T470 and do not have any paper to load. I was trying to program PLU #'s and accidently hit some key that printed a huge report and used up all my...
Printer ML2010 not responding
LED pattern Possible Problems and Solutions
Your system has some problems. If this problem occurs,
contact your service representative.
On Line/Error LED
lights red
• Paper jam occurs. To solve the problem, see “Clearing
Paper Jams” on page 5.6.
• The front cover is open. Close the front cover.
• Paper tray is empty. Load the paper in the Tray.
• The toner cartridge is out of toner. Remove the old toner
cartridge and install a new one. See “Installing the Toner
Cartridge” on page 2.4.
• You pressed the Cancel button while the printer is
receiving data.
• In Manual Feed mode, there is no paper in the manual
tray. Load paper into the manual tray.
• If the printer is receiving data, the On Line/Error LED
slowly blinks green.
• If the printer is printing the received data, the On Line/
Error LED blinks green fast.
Jul 15, 2008 | Samsung ML 2010 Laser Printer
Can't print faxes due to error messages
Please check rear door area for paper, can you use manual feed slot? Power off machine with all jams removed and paper loaded, then power on, can you tell us exact error message/lights that are shown in this state?
Oct 15, 2007 | Brother IntelliFax-2820 Laser Fax
Toshiba TEC B-572 Printer Logo
75 people viewed this question
Top Toshiba TEC Office Equipment & Supplies Experts
CheckitRight
CheckitRight
matt
matt
richie46
Are you a Toshiba TEC Office Equipment and Supply Expert? Answer questions, earn points and help others
