Question about Microsoft Xbox 360 Console
3 red lights on the ring of lights... I understand that 2 red lights means a heating problem, so what does three mean? The console just freezes, or sometimes goes to a black screen. I just push the power button off and on again and then I have all green lights, but this is the third time this has happened.
  • 4,102 Answers
Hi, the problem you are having is all related to the dreaded rrod problem, now 3 red lights means hardware failure now this could mean the cpu or gpu chip has over heated and the solder holding it onto the circuit board has cracked and this is whats causing you the problem. now if you look on the date on the xbox it will tell you if you have any warranty left as this problem is covered by xbox warranty for 3 years so if you are within this time period you need to contact xbox and they will then collect and send you out another repaired xbox, but their is no guarantee on how long the other xbox will last and it will not be covered by any warranty.
Their isnt much you can do yourself to repair the problem your having, their are people out their like me who do the repairs on these and 9 out of 10 of the times they can be fixed but you do get some that are scrap when they have the 3 red lights.
its up to you you could either sell it and put the money towards a new one or pay to have it repaired, check your warranty first and let me know what you want to do as i may be able to assist you further ok.
plz rate this solution as i have a whole page of unrated posts, thanks
Posted on Sep 10, 2010
Testimonial: "Well that sucks, but thanks for being honest with me! I'll check in to it, I'm pretty sure I'm still covered... but I'll be sure to ask further!"
    Problem Solver:
  • 16 Answers
Thanks for your question. To fix the 3 red lights what you will need to do is stop the heat getting to the GPU and the CPU and to do this you can use a good Xbox 360 Repair guide or of course you can send it in. The repair guide gives you ways to fix the problem yourself, easy and fast. good luck
Posted on Sep 11, 2010
    Problem Solver:
  • 6 Answers
With this error I would call Microsoft support center.
Posted on Sep 19, 2010
What's the difference between a xbox 360 over heating and the rrod
There are 4 different kinds of RROD on a xbox 360. When the ring of light shows 1 red light, it means there is a minor hardware issue. If it shows 2 red lights, it means it over heated. If it shows 3, it has a major hardware failure and 4 red lights means that you dont have your A/V cables plugged in. Hope this helps.
Aug 04, 2010 | Microsoft Xbox 360 Console
WHAT DOES THE THREE RED FASHING ;LIGHTS MEAN?
your system needs an x-clamp replacement. cause cpu or gpu has to be reflowed. this is your cause. i have been fixing this problem for over 2 years
Jun 07, 2010 | Microsoft Xbox 360 Console
Red rings
Depending on how many you have it means different things:
1 red light - scaler chip E74
2 red lights - overheating
3 red lights GPU and CPU have burnt out
4 red lights - the AV cable is not in correctly
You can fix all of these errors yourself or you can send it in to have it repaired
Dec 23, 2009 | Microsoft Xbox 360 Console
My xbox has the red ring of death,how do i fix it?
If you get Red Ring of Death you need to first check how may red rings are you getting and do you see any error message on screen with red ring or the console does not start at all
When there is a general hardware failure. While this can be caused by any part(or lack thereof) on the 360, the general cause is from excessive heat, which stresses the solder joints on the CPU and GPU
What Do The Red Light Errors Mean?
  • 1 light means you have had general hardware failure. If you to send it in to get it repaired, without a warranty would cost. Not to mention it can take up to a month for you to get your system back.
  • 2 lights mean your console is over heating---TURN IT OFF NOW TO AVOID SERIOUSLY DAMAGING YOUR SYSTEM!
  • 3 lights also mean general hardware failure.
  • 4 lights simply mean there is a problem with the AV cable. Check the connection and replace if necessary.
basically when you get a RRoD you can try cleaning the connection point of your AV cable but if it does not work please send it to MS Support for repairs, i had 3 Red light problem and with error message E74 i send it Microsoft Support as my console was under warranty
Nov 19, 2009 | Microsoft Xbox 360 Console
Green light doesn,t come on on front stays red
first solution was right in most respects but it matter how many of the lighta on the power button are on 1 or 2 lights may be fixable by making sure all of your components are firmly attached if there are three or four lights it is a critical hardware failure most likely caused by over heating . if you are still under warranty (red ring of death warranty is 3 years) then you can send it to microsoft and they will fix it . if you are not under warranty they will charge around $180
Jul 08, 2009 | Microsoft Xbox 360 Console
Xbox 360 flashes three red lights and want do anything
Hi, click on the link below to help with your ring of death issue. this link will direct you to a site that has a step by step guide on fixing this issue. it is repairable.
CLICK HERE
May 14, 2009 | Microsoft Xbox 360 Console
Three red rings flashing
if it is red(or darker orange) you have the three rings of death most of the time that means to send your x-box back to the manufacturer. but call Microsoft first.
Apr 26, 2009 | Microsoft Xbox 360 Console
I have 2 red rings on my xbox 360 but i dont understand what they mean...
The 2 flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. The main thing that causes the 2 red lights to start flashing is because of overheating and as the motherboard within the console takes more heat it actually warps and bends until the solders become loose.
Once this happens you will receive the 2 red lights. Even before you get the 2 red lights you may have noticed your games freezing and this is caused in the same way, by overheating. As the chips take more heat they shut off to prevent lasting damage, although they can only do this a number of times until you get the Xbox 360 2 Red Lights.
To fix the problem you need to stop the level of heat the motherboard takes and you can do this in a number of ways, but it will involve opening up your Xbox and working on it. In addition, you could always send your Xbox back to Microsoft as they are offering free repair for this error, you will just need to wait 3-4 weeks that's all.
There is one more option available in the form of DIY Video Guide, that will explain you step by step approach to fix red ring of death within one hour without any technical knowledge.
Jan 13, 2009 | Microsoft Xbox 360 Console
Xbox 360 2 rings
One red light signifies a major hardware failure or system error[4] , depending on which hardware failure or system error it is depends on how the problem can be fixed but in some cases there is no easy recovery and the console must be repaired or replaced. Two means the console is overheating and must be switched off and left to cool. Three, the infamous 'Red Ring of Death', means a general hardware failure and the console must be sent to Microsoft for repairs. All four red lights simply means that the console cannot detect its AV cable.
Nov 23, 2008 | Microsoft Xbox 360 Console
I have 1 red light on my xbox 360
ok one red light means a fault be warned this is also called the 3 rings of death if u get 2 flashes or rings it will over heat or freeze ,and if u have 3 xbox is dead ,
one means fault is it over heating,in a confined space ,
here is a site so u can see whats goin on with your xbox
http://editorials.teamxbox.com/xbox/1651/The-Red-Ring-of-Death/p1/
Jul 04, 2008 | Video Game Consoles & Games
Microsoft Xbox 360 Console Logo
63 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
