Question about E-Machines T2792 PC Desktop
I was on the computer about 2 or 3 months ago and shut down. I hadnt used it since (have laptop) I went to turn it on and I noticed that the light on the front panel was flashing yellow. But I couldnt reboot nor unplugging did anything. I decided to take the side off and take a look. Vacumed the dust bunnies out. Plugged it back in and now the light is green and stays on, even if I unplug and leave it awhile. Is my motherboard fried???
  • E-Machines Master
  • 11,800 Answers
Yes.
Posted on Sep 10, 2010
My computer starts then shuts off i havent used it for about 2 years ?
It could be overheating. Do you hear fans running when it's on? If not, the CPU Fan may not be working. Also the Thermal Paste around the CPU and Heat Sink may have dried up or is not thick enough to keep the laptop cool, so it shuts down. You will have to take the laptop apart to fix either of the two things mentioned so far.
You might have a virus that is causing you to shut down. Try booting the system in Safe Mode and see if it stays on. Turn the laptop off, then turn it back on and immediately start hitting the F8 key repeatedly until you see SAFE MODE option. Select Safe Mode and let it boot up. Most times the virus can't operate in Safe Mode because it needs the Internet Connection. If it stays on you will need to run your virus scan.
Mar 26, 2012 | Acer Aspire 3690 Notebook
Compaq Evo N600c Laptop over 5 years old but has been working fine. About 2 months ago the screen went dark (bad lamp?) so been using an external monitor. Turned it on this morning and it started to boot...
Do you see any lights on the laptop that are on? If you see any lights and only a black screen, then more than likely your video chip on the motherboard has gone out. Some local shops might be able to replace the motherboard it might be cheaper than buying a new laptop. Good luck
Feb 25, 2011 | Compaq Evo N600C PC Notebook
2002 jeep liberty will just shut down while idling and stopped at stop lights and stop signs. will run while driving steady. any ideas?
HAVE IT SCAN TO CHECK FOR IDLE AIR CONTROL CODES.IF IDLE AIR CONTROL IS OKAY.YOU COULD HAVE BAD SPARK PLUGS AND WIRES.A LEAKING INTAKE GASKET OR MISSING VACUUM HOSES OR LINES AND A FAULTY FUEL INJECTOR WILL CAUSE CAR TO SHUT OFF WHILE COMING TO A STOP.
Feb 09, 2010 | 2002 Jeep Liberty
I bought HP Pavilion dv5 6 months ago and fan not working
Your cooling fan sounds to have went out,causing it to overheat and shut down.It also could be something in the fan stopping it from turning.Try cleaning it or blowing it out with it off.But it mostly sounds to have went out.
Aug 05, 2009 | Computers & Internet
No power
In my searching for another problem, I read a lot of postings about Toshiba laptop computers and faulty power plugs (at the spot where you plug in your AC adapter into the computer). It seems to be some kind of universal problem with Toshiba and I think there was even a recall a while back because of this. I do not know if this is your problem, but it certainly sounds similar.
Sep 28, 2008 | Toshiba Satellite A105 Notebook
Start > turn off computer does not work on XP
Some process running in the background is not letting the system shut down. Use task manager to kill unnecessary processes before pressing turn off. If it shut downs then try to locate the process using taskmanager which is causing this problem.
Let me know if it helps.
Apr 13, 2008 | Acer Aspire 3610 Notebook
Hard drive not mounting
If you still have the files on your pc and just use the drive as a backup, then there is nothing lost yet, and no need to recover, just return to retailer. But if there is any sign of life, check; Right Click My Computer>Properties>Device Manager>Hardware,see if your Drive is in the list, if not, on top right there is an icon for scan for new hardware. See if your PC can find your drive, if not return it.
Nov 03, 2006 | LaCie d2 Extreme 250GB External with...
E-Machines T2792 PC Desktop Logo
43 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
