Question about John Deere Two Safety Warning Lights For All Tractors
Blades on f935 won't engage. the lever will move but the blades won't lock in. My husband says that the brake is on but I can't get it to go off or unlock what do I do?
  • 5 Answers
SOURCE: John Deere LA110 mower blades got disengaged
does it engage manually with a lever, or is it electronic with a push pull switch? if electronic, check the wire that goes to the electric clutch, it might have come off when unplugging it. do all this with the engine off
Posted on Jun 27, 2009
SOURCE: I have a john deere L120 riding mower with about
have a john deere zero turn that will not turn all the way over
Posted on Aug 16, 2009
  • 146 Answers
SOURCE: serviced my riding lawnmower runs great. but when
Probably the seat safety switch. If it's not activated (from your weight on the seat) the engine is killed when you put it in gear, or engage the blades. Lift up the seat and check the switch - wires on tight? switch tightly mounted? You can take the switch out and tape it in the pushed-in position to test things. If that doesn't let the mower run, the switch itself is probably bad, but it could also be a connector that knocked loose when you serviced the mower. Check wires and connectors. Good luck!
Posted on Jun 08, 2010
wireguy212
  • 1627 Answers
SOURCE: engaging the blades / PTO
There is either a yellow toggle switch or a yellow knob type switch on the dash panel that will engage your deck unless some of the safety switches are stopping it from working due to an adjustment problem or a defective switch,let me know if you need more help.
Posted on Jul 15, 2010
wireguy212
  • 1627 Answers
SOURCE: problem with John Deere L120 tractor
Park brake switch is the most likely culprit,any other would cause the tractor to not turn over in the crank position.
Posted on Jul 29, 2010
Why won't blade engagement lever move?
The cable is rusted,not allowing it to move,or there is something jamming the mechanical parts on the deck.
Oct 19, 2014 | Garden
How do I determine why the blades will not engage on my mower
With the mower turned off and the deck at its lowest setting, check the top of the deck for any debris like rocks or sticks. Then watch the top of the deck while you move the engage lever. If nothing is moving, you either need to adjust the cable, reattach the cable, or install a new cable. If you see the lever with the pulley on it moving, when the engage lever is locked on, check the tightness of the belt. If it's loose, that is your problem and it could be a stretched belt.
Sep 18, 2014 | Craftsman Garden
Blades won'e engage
Your belt may be on wrong or slipping.
May 23, 2013 | Craftsman Garden
John deere f935 blades engage but will not lock into egaged position
If you want to solve your problem, click on the link I attach.
Best Manuals
Apr 25, 2012 | John Deere Garden
John Deere L110 blade brakes wont stop blades from spinning
Are the brake pads on brake levers good? May need replace levers.
Apr 01, 2012 | Garden
I have a Husqvarna CTH 171. When i engage the blades they
http://weborder.husqvarna.com/order_static/doc/HO/HO2005/HO2005_5321938-34.pdf
This is the owners manual if you do not have one.
There is a brake on the pulley, make sure that is not hanging up.
Please let me know what you find.
Feb 08, 2010 | Husqvarna 23 Hp 48" Deck Yard Tractor
I have a 18.5 hp 42" electric start craftsman mower. when i went to engage the blades the lever was harder to move than usual and once it was engaged nothing happened. blades not turning! please help.
When you move the lever and engage the blades you are also engaging the belt that drives the blades and sits on top of the mowing deck. Chances are that belt either came off one or more rollers, or broke. The only way to check it out is to get down and look on the top of the mowing deck. Get back and let me know what you find.
Jun 08, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
John Deere Two Safety Warning Lights For All  Tractors Logo
145 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
