Question about Coleman Powermate Premium Plus 6250W Portable Generator
Coleman powermate PM0545007 need wiring diagram
CarlGehrke
  • 169 Answers
SOURCE: Hello I have a coleman
I can't get a wiring diagram or a manual without the model. type, and code off the engine.
What I can do is describe the usual wiring and see of that helps.
The ones I've worked on have a very simple wiring harness,
a black wire runs down into the front of the engine, this is the kill wire that attaches to the ignition module (coil), the other end of the kill wire connects to the center terminal of the on/off switch.
A white wire runs from the switch to the oil shutdown module, at the switch it's connected to the terminal that's closed when in the run position. The other switch terminal connects to a wire that runs to the frame ground. The gray wire from the oil sensor module connects to the oil sensor on the side of the engine.
That's pretty much all of the wiring there is for an engine that doesn't have electric start.
Rate me please,
Carl
Posted on Dec 03, 2008
SOURCE: Powermate
Here you go:
http://www.powermate.com/pdfs/2007/11/17/manual_pm0497002.pdf
Posted on Dec 14, 2008
sal_kh_sab
  • 98 Answers
SOURCE: My dog chewewd up the wires on my coleman
send me a large pic for the generator and i'll be more than glad to help u..
sal_kh_sab@yahoo.com
Posted on Oct 15, 2009
rwvanlue
  • 486 Answers
SOURCE: I have a Coleman Powermate 6250. Runs Great, No power to outlets!
Excite the genset.
with the gen engine running,
1) plug a 3/8 drill into an outlet,
(make sure the drill is set to the forward rotation)
2) hold the trigger in the run position
3) by hand, rotate the drill chuck with a quick flip of your wrist.
*** NOTE: BE PREPARED !!! this will excite the gen-set and the drill will start to run as normal.
Posted on Nov 23, 2009
  • 905 Answers
SOURCE: have a coleman powermate 6250 model
Fresh Fuel
Clean carburetor if stored with fuel in the tank and wasn't shut off
Clean fuel filter
Clean air filter
Proper oil level
Clean spark plug (just replace it, it is easier and faster)
Posted on Jun 12, 2010
I need a wiring diagram for my powermate 5700? Do to my dog chewing off the wires
you need 2 replace the dog...! (BEFORE THE WIRING job) ...that's a really tight spot they're in....
HE'LL SEE NEW WIRES AND SAY....
OH GOODY....I bet he'll like this ! that's what he gets for leaving me home alone ....i'll show HIM !
Mar 08, 2014 | Coleman Powermate Powermate 5000W...
Powermate PM0545007
With mine I add 'dry gas'. My local store carries Sta-Bil, yours will have something compatible (if not this one). Even if the gas is new, moisture can still be in the tank. Use as directed.
I use it in my snowblower, tractor, generator and cars.
Hope that cures your problem as it has mine.
Feb 03, 2013 | Coleman Powermate Premium Plus 6250W...
Need a wiring diagram/schematic for the power output end/recepticals for the coleman powermate 5000 model pc0545305.01 generator
Couldn't get you a wiring diagram but the contact info should get you to someone who can. The other links will get the manual and parts breakdowns.
Coleman Powermate Powermate 5000W Generator
http://www.powermate.com/contact.php
http://www.powermate.com/pdfs/2007/11/12/manual_pc0105000.pdf
http://www.powermate.com/pdfs/2007/11/12/parts_pc0105000.pdf
Oct 01, 2012 | Coleman Powermate Powermate 5000W...
Want to add electric start to my Coleman Powermate Generator. Model PM0545007. Serial 92842089. No problems with generator but tired of dealing with rope pull start...any help would be great appreciated!
To determine if an electric starter can be installed, begin with the model number and type of engine. The engine model number (not generator number) will clue you in on the availability of accessories. In order for a starter to work on your engine, there needs to be mounting holes drilled and taped onto the back of the block to mount the starter. Also necessary is a ring gear on the flywheel and a knock-out plate on the fan cover to allow the nose of the starter into the cover. For reference, find a dealer near you that has the same type of engine with a starter already installed so that you can see the differences. Good luck of upgrading.
May 25, 2011 | Coleman Powermate Premium Plus 6250W...
Have a coleman powermate 6250 model #pm0545007,won't start,what to look for?
Fresh Fuel
Clean fuel filter
Clean air filter
Proper oil level
May 20, 2010 | Coleman Powermate Premium Plus 6250W...
Coleman powermate pm0545007,ran out of gas, refilled, never so much as cough. won't start
How old is it hand about how many hours on the unit. Does it have a Briggs engine?
Sep 20, 2009 | Coleman Powermate Premium Plus 6250W...
Looking for a Pricesheet
google"coleman powermate". on the site look for manuals. the price list is the top manual. kinda small. you may have to increase magnification. mike
Nov 17, 2008 | Coleman Powermate Premium Plus 6250W...
Coleman6250 Generator PM0545007
I had the same problem. It turns out the on off switch for the engine was bad. To check if this is what is wrong with yours simply disconnect all of the wires at the on/off switch. If the engine starts and runs, then the switch was bad.
Oct 16, 2008 | Coleman Powermate Premium Plus 6250W...
Coleman Powermate Premium Plus 6250W Portable Generator Logo
172 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Shawn DuRee
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
