A couple of times I have tried to start my vue and it just turns over like it's not getting fuel. I have noticed the fuel gage also does not go up when I'm having this problem. Then with no pattern or other reason it will start. Could it be a fuel sensor? I did notice the last time I filled up the gas gage moved very slowly to the full mark, it took at least a couple of miles down the road before it read full. Thanks
I bought a 2003 Vue used last week - it has 68K miles on it. Drove fine for 6 days, and then just died at an intersection; all gauges went to zero. Engine cranks but doesn't turn over. I took it back to the dealer where I got it; they diagnosed a defective fusebox (the one under the dash) - not the fuses, the box itself. They said it's losing voltage across the box itself. They called the local Saturn dealer who told them they have seen it happen before with other Vues. They've ordered a new fusebox which they say will fix the problem. Has anyone else had the fusebox checked?
I have a 2005 vue that is acting the same way. no one can find out whats causing it. It just started doing this. Has there been a recall on this problem?
I have a 2002 Vue and after four great years it suddenly has a problem where it won't start. It sounds like it is trying to turn over but nothing happens I either have to wait or keep trying it. It always eventually starts but it seems to be happening more and more. The Saturn dealership can't find anything wrong with it but it happens almost daily. If I take a short trip and stop it won't start. Usually happens after short trips. Can someone help diagnose this? (By the way it started after they replaced the body control module).
just put engine in 2002 saturn vue 3.0 liter has good fuel pressure to throttle body but will not crank i can pour gas into throttle body and it will run but not on its own wht could be the problem
Comment by Guest, posted on Jun 15, 2008
my 2002 6 cy awd will not start on times when i wait for about10minutes then it starts but now i will not at all just whines over but will not start.
Best Solution
posted on May 14, 2008
lawyer - usenet poster
Rank: Apprentice Rating: 0%, 0 votes
could be a dirty fuel filter, been usign cheap gas? On the flip side, it could also be computer related. Best to bring it in to have it checked out, heck, you got that big warranty now.
-- marx404
Was this solution helpful? Show your Appreciation by rating it:
