Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
My john deere gx 345 garden tractor sensor light for the engine temperature comes on after about 10 minutes of running. Tractor does not smoke or seem to be hot. If I keep using it the sensor go off and then intermittantly go off. (not flashing, just random). John Deere dealer ordered new sensor and they say it is easy to install. How do I install it?
wilsodfarm
  • 986 Answers
SOURCE: 3020 carburetor ? john deere gas tractor, 3020
those carbs are real simple you will not have any problem
Posted on Jul 29, 2009
mowerman1857
  • 389 Answers
SOURCE: pto spis all the time on my 1989 john deere 420
Are the blades turning? If they are not, this is normal. The PTO is an electro magnetic clutch that engages when you apply electricity via the PTO switch. When it is disengaged, the bearings and top portion of the clutch will turn because it is coupled to the engine. If the blades ARE turning then you have a bad clutch and will need to repair or replace it
Posted on Sep 18, 2009
SOURCE: have a john deere lawn tractor. Blade will not
Check both belts on deck. Check if the clutch is clicking in. If not it will most likely need a new pto switch.
Sam
Posted on Jan 08, 2010
  • 394 Answers
SOURCE: Our new to us john deere 345 tractor won't keep running
You may try blowing backwards from behind the fuel filter into the gas line. Not to much air pressure though. Make sure the gas cap is off.
Posted on Mar 13, 2010
  • 52 Answers
SOURCE: John Deere 445 Garden Tractor, starts immediately,
could be bad gas, but it sounds like a choke problem. did it sit over the winter with less than a half tank of gas in it. try putting some rubbing alcohol in the fuel or draining the tank and disconnecting the gas line so you can drain the gas out of the carb. also check the gap of the spark plug and make sure that is correct. when was the last time there was fresh oil put in. also check the air filter, it could be full of dirt.
Posted on Apr 18, 2010
Testimonial: "Thanks for the ideas. I will try your suggestions. Tractor used for snow blowing during the winter and gas did not stay in it long. Good ideas!"
Why does 345 john deere run hour then stop?
Mine doing the same. Must have something in the tank. Took gas line apart for it enter filter and blew in to it. Works fine now.
Sep 04, 2014 | John Deere Tractor Starter 285 345 2243...
Do you have a wiring diagram for the starter on a John Deere 285 garden tractor? The old starter was removed and no wires were labeled.
Generally starters ground through the engine, so that only leaves the positive wire. That one comes from the starting solinoid. Starting solinoid gets power from the battery. Anyway these wires are the biggest ones on the machine including the negative/ground wire from the battery.
I hope this helps.
Jul 30, 2011 | John Deere Tractor Starter 285 345 2243...
John lawn 345 lawn tractor runs for about 30 minutes and then dies.
something is either heating or plugging up and causing fuel starvation.
Apr 04, 2011 | John Deere Garden
Hello my name is John. I have a 345 John Deere lawn tractor. The problem is that it starts idles rough won't idle up and does not run strong enough to move the mower. It just chugs and puffs white smoke...
345's have a habit of the choke sticking at the carb.Another problem they have is the fuel pump diaphram will crack and allow your engine to fill up with fuel,to much fuel in crankcase will end up past the rings when not running and smoke pretty bad when fired up.
Jun 20, 2010 | John Deere 420,1020,2010,2020,2510,2520...
John Deere 345 Water cool Seems not to be Firing
Time delay module on the left upper side of engine.It has a couple of yellow wires,1 red,1 black,1 orange.These will fail,replace it.
Apr 21, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Mar 13, 2010 | John Deere A,b,g Tractor Carburetor Float...
My John Deere 345 dies for no apparent reason
You have dirt in the fuel tank and it sucks the dirt up on the filter that is attached to the pump. After the machine stalls, the dirt falls off and it will restart and run for a few min.
Oct 02, 2009 | Garden
John deere stx38 wont move transmission locked up?
Engine OFF, raise drive wheels and check if transmission is locked
Jul 14, 2009 | John Deere Garden
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
137 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
