Question about ViewSonic VX924 19" LCD Monitor
My monitor won't wake up until I have waited while it flicks on and off
  • 11,361 Answers
More likely to be bad caps as shown here (replace them in a set.
http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VX924/
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Posted on Sep 11, 2010
Monitor won't wake from sleep!!!!!!!
Sounds like you may have a bad connector. Make sure it fits snugly in the pc and the back of the monitor. If you still get no input try a different connector
Mar 31, 2017 | ViewSonic Computers & Internet
Monitor won,t wake up from sleep mode
Open monitor and look at power supply board for capacitors which are "balooning" or deformed in any way. These look like cylindars on the board. These tend to dry out and make what you are describing occur. Replacing them usually fixes about 80% of the problem you are describing. Those parts run about $0.25 to $0.75 each.. well worth trying, right?
Jan 20, 2014 | HP 2009M Monitor
Won't stop cycling through brightness settings
sounds like it might need a cleaning. are the buttons hard to push or are any of them giving you a different feeling then the rest?
Aug 13, 2017 | Samsung SyncMaster 2233SW Monitor
Sony Vaio won't wake
There are a lot of issues with drivers based on Windows 8 at the moment. I've also been playing a lot with it lately and have the same issue with my Dell laptop, Intel chipset. My only recommendation is to put Windows 7 back on and wait until late-October when all the manufacturers start releasing compatible drivers.
Jul 19, 2012 | Sony VAIO VGN-P688E/G PC Notebook
I just added a LCD monitor to my eMachines ET1331G desktop computer. Everything worked fine until I left it on for a day. The computer went into sleep mode and now I can't get it to wake up. I've trie
You should be able to just press the main system unit power button to wake up your 'sleeping' computer which will then resume your Windows desktop and bring you back to the Login panel if you have a password set for your account.
Dec 29, 2011 | eMachines D Computers & Internet
I have a dell dimension 4600 computer. I usually put the computer in sleep mode when I am not using it. Usually I press the ESC button and the computer wakes up. All of a sudden, the monitor won't...
Plug the monitor into another computer to determine if the monitor is damaged or working properly. You can also plug another monitor into your computer to determine the same thing.
May 21, 2011 | Dell Dimension 4600 PC Desktop
Compac keyboard 1/4 moon key on model 5137, once I hit it, monitor went to sleep. I cannot wake it up. I have no password. I have unplugged and replugged entire system, I have tried every combo of keys...
Try holding in the power button on the computer for 30 seconds. wait 5 seconds then tap the power button again once and wait. also check that the monitors cables are securely connected to the computer.
Aug 25, 2010 | Compaq Keyboard
Acer X223W monito won;t wake up after sleep.
I have a dual monitor system, both are the x223w. Same problem but only on the second monitor. Backlight shuts off.On/off light stays blue. I have to turn off the monitor and turn it back on. I returned it and Acer could not find any problem so I got it back. No problem for awhile and now a few times over the past couple days. Not good...
Aug 10, 2009 | Acer 22" X223w LCD Monitor
Dell E173FP Monitor requires unplugging/plugging back in to wake
Perhaps your computer is hibernating instead of going into standby which takes a little longer to wake up from. While you are playing plugs and cables it give it enough time to come out of hibernation.
When the computer is in this mode the USB ports turn off which disables keyboard and mouse so the only way to wake up the computer is to press the power button on the computer itself.
One tell tale sign a computer is in hibernation is that the power light on the computer will slowly blink.
I hope this helps.
Aug 08, 2009 | Dell Computers & Internet
ViewSonic VX924 19" LCD Monitor Logo
71 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
