Question about Vivitar ViviCam 8025 Digital Camera
When i try to record myself , it records and has good quality but i can not hear anything that i am saying . Its like its on mute or the volume is low , how can i hear myself speaking . People said that vivitar 8025 doesn't have video , if that is so why is it installed onto the camera ?? HELPPP I NEEDDD ANSWERSSSSS !
    Brigadier General:
  • 11,967 Answers
The 8025 doesn't have a built-in microphone....therefore, "silent movies".
Posted on Sep 10, 2010
I recently recieved a Bush Noise Cancelling Desktop Microphone M-013NC , i've plugged it into the back of the computer and turned all microphone volume settings upto full, but when i try using the sound...
There are two separate settings in control panel for record and playback. It appears you have playback enabled but not recording - see below
Using a microphone with computer
To use any microphone with your computer you will need to enable it in control panel. The following instructions are for Windows XP but are broadly similar for Vista and Win7
Click START, CONTROL PANEL, SOUNDS & AUDIO DEVICES
Click VOICE
In Sounds & Audio Devices Properties window locate SOUND PLAYBACK box. Click the VOLUME button. Make sure that there is not a check-mark in the MUTE box against microphone in the list of devices and that the volume slider is at the top of the scale.
Make sure the MUTE ALL box isn't checked before closing the window.
Now click the VOLUME button in the SOUND RECORDING BOX. Here SELECT microphone as an input source for recording (as opposed to un-checking mute in the playback controls).
NOTE if your microphone is not listed in the 2 sets of volume controls click OPTIONS, PROPERTIES on the tool-bar and place a check against microphone in the list entitled 'show the following volume controls' and then click OK. Same applies for Internal mic.
That should be it.
To adjust audio volume generally.
Under VOLUME tab adjust Device Volume as necessary. Also (under Loudpeaker Settings) click Speaker Volume and adjust slider to suit.
You might put a check mark in the box to show the volume control on the Task Bar so you can go straight to it to make adjustments in the future.
Feb 21, 2011 | Audio Players & Recorders
Friends say When i speak sounds like Static any 1 know how to change setting or find it in computer. Im using Satellite Fusion
The external microphone itself could be the culprit, or its connection to the 3.5mm port could be flaky. To test the theory do this:
1 Connect an external microphone to the computer.
2 Click Start, point to All Programs, Accessories, Entertainment, then click Sound Recorder.
3 Click the Record button and speak normally into the microphone.
>>>> WIGGLE THE CONNECTION AT THE LAPTOP OR FLEX THE MIC CABLE WHILE RECORDING. Maybe even narrate what you are doing while you record your voice. "Flexing cable near mic, now near plug..." <<<<
NOTE: You can only record 60 seconds at a time.
4 When you have finished recording, click the Stop button.
5 To hear what you just recorded, click the Play button.
6 To save the file, select Save from the File menu.
>>>> If you hear crackling in the playback that correlates with your handling of the cable then bad seating or a bad cable are the problem. <<<<
Adjusting recording quality
The better the quality of the recording, the more disk space the sound file requires. Experiment to find a balance that fits your needs.
1 Open Sound Recorder, if necessary (click Start, point to All Programs, Accessories, Entertainment, then click Sound Recorder).
2 In the Sound Recorder window, click Edit, then click Audio Properties.
3 In the Audio Properties window, adjust the Sound Playback quality and volume, and the Sound Recording volume.
4 Click OK.
Your new settings take effect the next time you record.
Dec 30, 2010 | Toshiba (P000257700) Microphone
I have a canon sd 1100 camera with video recording. It no longer records the sound with teh video and I don't know if I hit a button or if it just broke. any thoughts?
If you're not hearing anything on playback on the camera, try pressing the up-arrow during playback to increase the volume. If you're not hearing anything on playback on a computer (and neither the viewer nor the computer are on mute) then something is broken on the camera, causing it not to record audio.
Jul 06, 2010 | Canon PowerShot SD1100 IS Digital Camera
I can hear other people but when i speak they cant hear me
The problem is with the mic you can verify it with by trying to record the sound using the sound recorder application. if you not able to record the sound.check whether mic is detected and it is not muted .sometimes mic may be muted.increase the volume of the mic by clicking the sound control option.
Mar 03, 2010 | Apevia Laptop Keyboard for Acer Aspire...
Skype Mute
  1. Click Start, and then click Run.
  2. In the Open box, type sndvol32.exe, and then click OK.
  3. Click Properties on the Options menu.
  4. In the Adjust volume for box, click Recording.
  5. Click OK.
  6. In the Microphone box, verify that the Select check box is selected.
All the properties listed on the Playback section of the Volume control are independet of the recording settings. So you could record through the microphone by selecting it on the recording section, and mute it on the playback section. Then, you could record sound, but wouldn't hear it through the speakers while you are recording.
Sep 14, 2009 | Computers & Internet
Hi everyone..:) I have a problem with my microphone. :S It's shows that everything is ok (in the control panel) but it's not.It can't record voices , and you can't hear your voice no meter what you do. But...
to to the volume icon on the task bar then double click
then go to options, properties then select recording and click ok.
then make sure that the microphone is not set to mute and the volume of the mic is not all the way down
Aug 01, 2009 | Lightwave GT-10 5 Section Aluminum...
I hear them on Skype they can't hear me. It's always worked before. Their computer is not on mute. I must have to do something with mine. What?
It seems like you have to change the setting of recording setting in master volume section.
Double click on volume button, select options then properties then recording and check microphone check box and try it may solve your problem
Apr 23, 2009 | Dell XPS M1730 Notebook
Cant hear recording in Logic 8 with the UA25
i have a mac and UA25 and there are no problems.
Mar 01, 2008 | Edirol UA-25 External Sound System
Not able to record sound
Hi '
Try check the volume control maybe on low volume or in mute, If in mute select off increase thje volume and ok.
Oct 10, 2007 | Canon PowerShot A520 Digital Camera
Vivitar ViviCam 8025 Digital Camera Logo
Top Vivitar Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
