Question about GE (PSS26MSRSS) Side by Side Refrigerator
Our GE Profile side by side refridgerator Model 25 freezer temperature varies from -3 to 4 several times in a day even when access is very limited. The temperature can be reset. Does this require servicing?
  • GE Master
  • 43,501 Answers
A variance of ten degrees is what I would consider to be normal for the freezer...would not worry about it
heatman101
Posted on Sep 11, 2010
Ge profile fridge model PSC 25MSW/PCF 25 MG W PSH25MGW freezer works fone but fridge too warm.
Check to see if you can see any ice building up in the damper between the frig and freezer.
Oct 23, 2014 | Refrigerators
GE Profile Arctic Side x Side Refrigerator PSC23MGNA
if you were able to do the test... check the compressor unit, also the do check on the electrical relay of the ref.
Jul 01, 2008 | GE Profile CustomStyle PSC23MGSWW 36" 22.7...
Zis480mnc ge monogram built in refer temp varies from 34 to 48 several times a day.
Try replacing that evap thermistor. The diagnostics on thermistors can be wrong. If it is rounded on the end, replace it. There is a damper between the freezer and refrigerator. There may be a refrigerator fan motor in the damper assembly, It could be bad. It could be a bad control board. When you run diagnostics there is one function that checks all the fans.
Sep 25, 2014 | Refrigerators
GE Profile, bottom, freezer Freezer does not stay at 0 degrees. With uses during the day it gets up to 20 degrees. Ice cream does not stay frozen. This happens mostly in the summer. Once it get cold...
most refregerator..usually open the door at day time..so it will not keep on required temperature o degreefrequent opening refrigerator,must be adjust the thermostat to higher setting..
Jul 11, 2011 | GE Refrigerators
I have a GE Profile Side by Side TPX21PR/Tpx21BR. The freezer is not freezing ice cream or even bread, but the meat seems fine. There has been a loud noise emanating from the unit for over a year.
Kindly provide few more details so that i could provide more appropriate solution to your problem :-
1. How old is the unit?
2. Kindly hear the noise - Is it from the freezer section or upper back or lower back of the refrigerator?
3. Do you hear the compressor running?
4. Any problem with temperature in lower section or is it limited to freezer section?
Let me know,so that we could proceed.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
May 21, 2011 | GE Refrigerators
I have a ge profile side by side refrigerator model number psc25psta. The freeze is not getting cold. How do I reset the temperature.
Here is a link to the main GE Support page for your refridgerator:
http://products.geappliances.com/ApplProducts/Dispatcher?REQUEST=SpecPage&Sku=PSB42YSXSS
And here is a link to the Online User's Manual with the operating instruction for it:
http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-60558.pdf
See page 5 of the User Manual for detailed instructions on how to adjust the fridge and freezer temperatures. It reads as follows in the manual:
To change the temperature, press and release
the WARMER or COLDER button. SET will illuminate in
the display, as well as the set temperature. To change
the temperature, tap either the WARMER or COLDER
button (while SET is illuminated) until the desired
temperature is displayed. Refrigerator temperatures
can be adjusted between 34F and 47F and
the freezer temperatures can be adjusted
between 6F and +8F.
Once the desired temperature has been set,
the temperature display will clear after 10 seconds.
To display the temperature, the DISPLAY TEMP button
may be tapped.
Several adjustments may be required. Each time you
adjust controls, allow 24 hours for the refrigerator to
reach the temperature you have set.
Good luck and please comment back here and RATE 4 Thumbs Up if this was at all helpful.
Just click on the highlighted links with your mouse in order to access the information described.
If the link does not open properly, you may need to download a PDF Reader program for your computer. The best reader can be downloaded free at www.adobe.com where you just click on the DOWNLOAD ADOBE READER button on the right hand side of the page and follow the on-screen instructions.
Just comment back here if you require any further assistance, I will be pleased to assist you in any way I can.
Thank you very much.
Joe.
Feb 14, 2011 | GE Profile PSB42YSXSS Stainless Steel (252...
Help! My GE Profile Arctica runs 24 hours a day...sounds like a fan. It stops when either door is opened, then starts as soon as the door closes. The temps on either side are higher than what they are set...
It is normal operation for ARTICA fans to run continuosly except when the door is open. If the door remains open for 3 minutes the fans will run anyway.
The temperature will vary about 6 -8 degrees from the selected temperature. The temperature will increase during a defrost cycle.
I do not believe you have a problem.
Apr 21, 2009 | GE Profile Arctica 25.4 Cubic Feet...
GE TFX22R SIDE BY SIDE
you defrost problem or check condenser fan at the back of refrigerator see if it runs
Apr 07, 2009 | GE Profile 21.6 cu. ft. Side-by-Side...
My GE Profile is 1.5 yrs old and I have the same problem. I came home to find all my food spoiled! It seems many GEs have had this problem, I agree GE should do something, there are expensive units.
Jun 17, 2007 | GE Profile CustomStyle PSC23MGSWW 36" 22.7...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
142 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
