Question about Honda Garden
My Honda Lawnmower engine is reving up and down. Tried adjusting the pilot and high speed but still reving up and down. Cleaned up air cleaner etc. Was working bang on one day and the next day went to use it and now this. Please help? Thanks Mr. Burke Model is HRA215
  • 183 Answers
I think your mower has a blade clutch. If so, does it surge when the blade is engaged or only when disengaged? Either way it usually means there is some sort of debris in the carburetor. If it is surging with the blade disengaged, that is usually an indication of excessive wear in the carb and I would recommend to replace the carb. Otherwise, it can be cleaned.
Posted on Sep 10, 2010
2013 Honda Activa will not idle when warm
Hi, Anonymous you need to make sure you have no intake leaks by spraying some Brake Kleen, Contact Cleaner, Starting Fluid etc. around the intake manifold and seals, if the RPM's go up or down significantly then you have a leak that needs to be fixed before you can continue with the carburetor adjustment.
The engine should be at operating temperature with the enrichener off to set the idle between 950-1050 rpm. Turn the idle skrew clockwise to increase the idle speed and counterclockwise to decrease the idle speed. If you have access to your air fuel mixture skrew you may turn it as well, if not there is a video below on how to gain access, make sure you start with clean or new spark plugs. Gently turn the air fuel mixture skrew clockwise until it starts to bottom out "STOP" do not over tighten as it will damage the taper on the end, now back the skrew out 1-1/2 full turns to establish a starting point start the engine and check the idle rpm's and turn the idle skrew accordingly for 950-1050 rpm if necessary, turn the air fuel mixture skrew 1/4 turn at a time and let the engine settle for about 10 seconds, turn the skrew clockwise for a leaner mixture and counterclockwise for a richer mixture, you are seeking the highest rpm your air fuel mixture skrew can acquire without going past 3 full turns from bottom then resetting the idle skrew back down to 950-1050 rpm If you can not detect any rpm change and can not stall the engine by turning the air-fuel mixture skrew all the way in then your pilot/low-speed jet is too big and needs to be replaced with the next size smaller. Final adjustment should be made with a clean air filter mounted to the carburetor.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Honda Activa 2013 Engine Stalling
Honda Activa Engine idling stalling issue caused by faulty ring fitment...
http://www.family-motorsports.net/GY6-50cc-150cc.pdf
http://www.partsfish.com/page/oem-parts-for-honda
Honda activa 2009 Owner Manual
Jun 28, 2014 | 2011 Honda Activa
Honda VT 750 Shadow idle too low
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Idle adjustments
Adjusting the Mixture Screws
Honda 1998 VT750C Service Manual
Honda VT750C Owner Manual
Apr 21, 2014 | Honda VT 750 Shadow Motorcycles
Adjust idle on honda shadow
Honda Shadow VT700C Running Lean Fix Pilot Jet Needle Shim
http://www.cycleterminal.com/Service-Manuals/Honda-VT500C-Shadow-Service-Manual-English.pdf
http://mybikemanuals.com/honda/honda-vt-owners-manuals
Oct 18, 2013 | 1986 Honda VT 500 C Shadow
3.5 hp 92908 B & S lawnmower engine, black smokey plug, pulsates...changed diaphragm, cleaned points and plug, adjusted air space etc...no luck? Some black exhaust smoke...maybe rings? Help!
Black smoke is over fuelling from float level too high or not controlling fuel flow. Check air filter is clean. Check for loose jet in carby
Sep 15, 2013 | Measuring Tools & Sensors
2002 Honda CR 125 R idle adjustment
2002 cr125 Idle adjustment
CR125 carb adjustment
Honda CR 125R 2002 Sevice Manual
Honda Elsinore CR125M Owner Manual
Mar 29, 2013 | 2002 Honda CR 125 R
Honda cb 750 idle adjustment
CB750 idle problems
CB750 Tuning Adjusting
Honda CB750f2 Manual
Honda CB750F2 Owner Manual
Apr 09, 2012 | 1998 Honda CB 750 Nighthawk
2005 Honda CRF 450 R idle adjustment
Hi, Haselhuj you need to make sure you have no intake leaks by spraying some Brake Kleen, Contact Cleaner, Starting Fluid etc. around the intake manifold and seals, if the RPM's go up or down significantly then you have a leak that needs to be fixed before you can continue with the carburetor adjustment.
Idle adjustment screw
How to Adjust Idle On Dirt Bike Tips and Tricks 1
Honda CRF450X 2005 Service Manual
Honda CRF450R Owner Manual
May 28, 2011 | 2005 Honda CRF 450 R
2008 Honda VT 750 Shadow Aero carburetor adjustment
Hi, Rockin_hick1 you need to make sure you have no intake leaks by spraying some Brake Kleen, Contact Cleaner, Starting Fluid etc. around the intake manifold and seals, if the RPM's go up or down significantly then you have a leak that needs to be fixed before you can continue with the carburetor adjustment.
idle screw air fuel mix
2008 Honda Shadow Aero Idle Problem
Feb 02, 2010 | 2005 Honda VT 750 Shadow Aero
Engine wont open up to full throttle without stalling
sometimes carb cleaner isn't enough. It is best to use cleaner and compressed air to clean out all the jets. I bet you still have trash in the high speed jet that cleaner alone won't get out
May 02, 2009 | Garden
I have a 1981 Honda CT110 Trail 2 wheel motorcycle. I have been working on it and everything seems to be working normal except the idle. It will idle normal for a time and the suddenly rev real high. I...
The problem is an air leak leaning the fuel mix. The idle speed starts going up a ramp until it is wide open. The valves no longer seating well is a possible cause as is carb manifold gaskets, rings and a cylinder head not torqued down tight.
Apr 23, 2009 | 1982 Honda VT 250 F
Garden Logo
1,219 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
