Question about HP 6530b Notebook
Totally dead, replaced ac adaptor, which was dead too, did not help. still dead.
    Guru:
  • 689 Answers
Why was the adapter dead --you should have checked the fuse on the plug first--sounds like an internal component failure to me--repairable by tecnichians
Posted on Sep 10, 2010
    Master:
  • 497 Answers
Hello, I am thinking that your battery needs to be replaced as well. Possibly because of the stress it took from your ac adapter issues. So, to check to see if the issue at hand is now your battery... 1) UNPLUG THE AC ADAPTER FROM THE LAPTOP. 2) REMOVE THE BATTERY. 3) PLUG THE AC ADAPTER BACK INTO THE LAPTOP 4) TURN IT ON.
If the battery was now the issue, your laptop should have turned on at this point.. If it did NOT turn on, then there is a different issue that we should troubleshoot. Let Me Know, ok?
Why My Inspiron mini will not start?
It is unfortunate that the computer is not turning on. Request you to try following the below steps which might help:
    (1)Turn off the computer.
    (2)Remove all the external peripherals like AC Adaptor, flash drives, battery, etc.
    (3)Press and hold the power button for 30sec which releases the static on the computer (if any)
    (4)Put back the battery and plug in the AC Adaptor.
    (5)Let the computer charge for some time.
    (6)Try turning on the computer.
    If the computer doesn't turn on then check hoe the Power LEDs on the system, battery and AC Adaptor react. Then I can check and help you further.
    Thanks and Regards.
    Kiran Kumar.
    #iworkfordell.
Jun 22, 2014 | Dell Inspiron Mini 10 Notebook
Panasonic pnlv 234 ac adaptor
Chances are poor to find a universal adaptor to replace a PNLV234. It has dual outputs, 5.5VDC @500mA and 5.0VDC@ 500mA. The connecter is similar to a phone jack with 4 conductors. I am trying to find a genuine Panasonic source as mine blew from a power surge.
Jul 13, 2013 | Lands Phones
2 ac adaptors have stopped working on acer laptop
Take the battery out. Unplug the charger from the computer. Press the On button for 30 seconds. Then plug the charger in. If it works, then put the battery back in and you're in business again.
If it still can't work, perhaps the charger you bought is a dead one, just contact the seller to get a replacement one after all you have used it for about a few minutes. If you don't believe in that seller, just contact them for the refund and go to other vendor for a new adapter. I recommend the following one for you:
http://www.chargerbuy.com/replacement-acer-aspire-5739g-ac-adapter-19v-4-74a.html
http://www.chargerbuy.com/replacement-acer-aspire-5738-ac-adapter-19v-3-42a.html
Oct 26, 2012 | Lifetime Acer Aspire 5738PG Replacement...
The ac power adaptor ac-v515 is dead.
I can't find the AC v515 adapter any where! But You can buy the next best thing. A battery charger one that will at least fit an NP-F730 battery. Go on to eBay and type Sony vc1000 and anything related will come up. These chargers can be used in your car and at home, what's more they are not expensive.
Nick
May 02, 2012 | Sony Handycam DCR-VX1000 Mini DV Digital...
Brand new battery will not charge
If the battery has never been used but stored dead for a long time, a first time charge will take some time. If the laptop doesn't receive some voltage from the battery, it will not know it's there and will take a long time to start chargeing from the trickle of charge it receives when totally flat. Use your laptop with the AC adaptor and if after 24 hours it has not started to charge, return it for a replacement.
Hope that helps.
Nov 25, 2010 | Toshiba Satellite L305D-S5895 Notebook
Laptop won't staart up.
Yes, it should run off AC power even if the battery is removed. Sounds like either the motherboard or your AC adaptor might be failing. I would start by trying the AC adaptor with another dell to verify it it's not dead.
Good luck,
Raf
Nov 09, 2009 | Dell Inspiron 5160 Notebook
Does not start; no power indicator light
Take out the battery and then try the different ac adaptors. If you still get no lights on the laptop then the motherboard is bad and would need to be replaced. Just make sure that you know at least one of your ac adaptors are good.
If the adaptors have lights and they turn on then you know the ac adaptor your working with is good. Also make sure they are plugged into a good working outlet.
May 29, 2009 | HP Pavilion ze2000 Notebook
Wii console don't have any power
If you have no lights, no activity, nothing at all, totally dead. Then try another ac adaptor in a known working outlet and see if it powers up, if it does power up then you know your original ac adaptor is bad.
If it still doesn't power up with a new adaptor then there is a problem with the main board inside of the Wii and the board would need to be repaired or if you have warranty left on it, get the system replaced.
May 20, 2009 | Nintendo Wii Console
Won't turn on.
yes the lap top can boot up with the ac adaptor without battery .but if there is a problem in its RAM  the memory chip.it will still power on with adaptor but will not go further then that.or the other problem can be its main board getting short in between.get the laptop checked at proper professional repair center before further use as because if you just try to turn it on several times the internal components which are short will get heated and will short many other small components and the reparing cost will get increased.
Feb 28, 2009 | Gateway M305CRV Notebook
My sanyo vpc-hd700 will not turn on because the red light will flash but the camera won't turn on.
Your AC adaptor has very likely failed.
Check the AC adaptor on your camera.  Mine failed this morning after only 2 days of ownership. (I just purchased an Xacti HD2000 camera 02/05/09)
The Bad P/N I had was a Sanyo VAR-G9.  Based on my very light use after two days, I expect these are totally trashy power adaptors and there are likely several hundred bad ones like it in the field  Thats just a wild guess on my part, but after only two days, a unit like this should not fail at all.
The camera said "Low Battery", then could not be charged, then only the red light would flash.
I confirmed with a Digital Volt Meter that there was no 5.0V coming out of the AC/DC converter.
Radio Shack sells (and I bought) a replacement 5.0V 2.0A capable power adaptor.   Take your unit in and they can help you.  Make sure that you don't have any little children that may play with the voltage switch on the replacement, as any voltage over 5.0V can damage your camera.
With the replacement unit, my camera charges fine.
May 02, 2008 | Cameras
HP 6530b Notebook Logo
184 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
