Question about Directed 1100d Car Audio Amplifier
Cant get amp out of protection mode - Directed 1100d Car Audio Amplifier
MY soundstream LiL Wonder 4.620 is only going in protection mode
Disconnect all speakers Meter power, remote, ground at amp, if all is good move on, if not check main fuses
Turn amp on; If in protect mode then your amp is toast Turn amp on, if not in protect mode then start reconnecting speakers one by one until your amp goes into protect mode, then you'll know which speaker is bad.
Sep 19, 2011 | Car Audio & Video
I have a 1000 watt sony explode mx-2165gtx and i have 2 12inch rockferd subs all hooked up in my truck. i turn on the sterio and turn it up just a little bit and it goes into protect mode i cant figure out...
Sounds like you're overloading the amp. Which rockford subs are they exactly? I can find the specs and see if theyre just too much for the amp or you just have to hook em up to the amp different so the amp wont go into protect mode
May 22, 2011 | Sony XM-2165GTX Car Audio Amplifier
How do i get the protect mode off
turnit it off complety, unplug, check for speaker cable shorts and then power backup, if it does it still get a service person to look at it, one of the main output power transistors could be faultiy on one of channels amps
Mar 21, 2010 | Mitsubishi M-VR1000 Receiver
My kenwood kvt 514 is in protect mode
It sounds like your amp is not grounded properly and is tryin to use your radio as a ground through the RCA's or there is a bad channel (dead short) in the amp.
Jun 02, 2009 | Car Audio & Video
Protection mood
Hello john_hart,
Check the speaker wiring too. If one of the speaker wires is shorted or grounded, the amp will go into protection mode.
Hope this helps.
May 20, 2009 | Kicker KX600.1 Car Audio Amplifier
Cant get protect mode off on amp
you burned up a couple of dioeds if if wnt go back to a regular mode
Apr 01, 2009 | Hifonics Brutus BX 1605D Car Audio...
Protection mode
try 1 speaker at a time could be blown speaker also try different rcas and inspect positive cable make sure its not grounding out near firewall or pinched somewhere else
Mar 31, 2009 | Sony XM-2002GTR Car Audio Amplifier
My amp stays in protection mode
Does it go into protect in the vehicle if you disconnect the speaker wires from the speaker terminals of the amp?
Nov 29, 2008 | Sony XM-2002GTR Car Audio Amplifier
Protection mode?
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Double check your connections. .A thumbs up would be greatly appreciated if this answer is helpful to you. protection-mode-shonxoarcym4awy4zl1imx4o-2-0.jpg Lanzar
May 25, 2008 | Lanzar Car Audio & Video
Amp keeps turning itself down - cant turn off 'protection'
yes,pls.stop plugging the system,you may harm your system if you do so,the system has it's own system analysis mode,and if there's something wrong in the circuitry,it will activate,you need the authorize service center my friend,it's a technical problem.
Dec 09, 2006 | Cambridge Audio Azur 540A Amplifier
Open Questions:
directed 1100 d turns on but no sound ok ive got a directed 1100d amp when i turn my system on the amp powers up then clicks stays on but doesn't put out anything if you leave it on for a while it will start to reverberate through the sub like its trying to play but never goes any further can anyone give me an idea what is wrong or an idea how to fix it? I have a Directed 1100d i was using it to power 4 12" woofers in my home ht setup, ive used other amps with good results. it worked fine but did have a slight hum from the woofers so i turned the gain down it seemed to help. So i used it for a few hors and then heard a light thump from my woofers when i went to check it out the 1100 was in protect mode and was really hot. I decided nto disconect it and leave it cool down, the next day i tried it with a single 10" sub it was no longer in protect mode light was geen but all i got out of it was hum from the woofer but no music. The ht woofers are rated at about 4 ohms a pair I also opened it up and there was no signs of any blowen or discolored components. I then proceeded to check the output transistors with a digital meter they seem ok, the amp also has 4 what they call fast response diodes with 3 leggs the 2 outside leggs short out but im not sure if they are suppose to or not.the numbers on the diodes which actually look like transistors are 2ea YG225N2 and YG225C2 ive surched the web but havent come up with a way to properly test them any help would be great thanks.
Jun 02, 2009 | Directed 1100d Car Audio Amplifier
See all Directed 1100d Car Audio Amplifier Questions
Directed 1100d Car Audio Amplifier Logo
55 people viewed this question
Top Directed Car Audio & Video Experts
Colin Stickland
Colin Stickland
Libran Moreno
Are you a Directed Car Audio and Video Expert? Answer questions, earn points and help others
