Question about Bosch 24 in. SHX56B05 Stainless Steel Built-in Dishwasher
My shx56bo5uc/14 leaves all the glassware coated in film? Sometimes the detergent door does not close properly?
  • 5,081 Answers
There are many probable causes of failure .
A dishwasher's water inlet valve is its most common part to fail. When your dishes are not being fully cleaned, quite often a faulty water inlet valve is to blame. Test your dishwasher's water inlet valve, and if it is no longer functioning as it should, you will have to replace it.
Water temperature is a key element in achieving clean dishes. A dishwasher's heating element is not designed to heat the water that enters it. Rather, the heating element is designed to maintain the heat of the water that enters the dishwasher. Its a good idea to run the hot water in your sink for a couple of minutes before you run the dishwasher. Just to make sure the water is nice and hot before it enters the dishwasher. If the water is unable to stay hot, it can adversely affect your dishwasher's cleaning ability.
There is a filter in your dishwasher. Its function is to keep large particles of food and foreign objects away from the pump. Many of the newly-manufactured dishwashers have self-cleaning filters, and routine cleaning isn't a concern. However, some other dishwashers need to have the filter removed and cleaned regularly. If the filter or grate is clogged or blocked with debris, it may interfere with the normal functioning of your dishwasher
Posted on Sep 11, 2010
The dishwasher runs through it's cycle but does not clean the dishes properly and leaves a cloudy film and smears on the inside of the machine and the dishes
    Common Problem
  1. Confirm the wash water is hot
    1. Try heated wash(sani wash) if available
    2. Run hot water in sink to warm up before starting
    3. At least 120 degree Fahrenheit water temperature
  2. Open door check wash arm position start washer for a minute
    1. Confirm wash arm has rotated
    2. Check for plugged spray tips at either end of wash arm.
    3. Use small tweezers to remove
    4. Check for rack and dishes interfering with arm rotation
  3. Place cup in upper rack with opening up cycle washer.
    1. Confirm that cup quickly fills with water
    2. Not washing check water level in tub mim 1 1/2 inch
  4. Discontinue use of rinse/dry liquid additive.
    1. Confirm rinse/dry additive not leaking from dispenser into tub
    2. Washer detergent contains sparkle additive and too much sparkle/rinses/dry additive will coat dishes
    3. Try alternative wash detergent that contains minimal rinse/dry additive and use without liquid rinse/dry additive.
  5. It will take several wash cycles after the elimination of rinse/dry to purge the oily film from dishes and machine..
  6. If success "joy" is achieved with no additives then cautiously add back wash detergent with additives. Additives are important to facilitate drying and protecting the glassware china from leaching. The leaching process permanently etches the surface of glassware leaving a cloudy appearance.
Jan 03, 2016 | Dishwashers
How do you eliminate the film on glassware after washed in dishwasher ?
Your heater may not be working properly. It is used to heat the water during the main wash as well as dry the dishes at the end. But don't under-estimate the importance of using the right detergent. Some discount detergents (especially liguids or gels) don't work very good. Stick with Cascade or Finish powders or those All-In-One tablets by Finish corporation (the ones with the little red "power ball"), or the new tablets put out by Cascade called "Platinum". In our repair business and experience, we find those work best.
Aug 30, 2014 | Kenmore Dishwashers
My dishes come out of the dishwasher with a white milky coating on them. Especially glassware is very milky.
Hi
White film deposits are observed if water is hard or when you are using more detergent than needed, try filling detergent cup half way. Try using white vinegar after the wash cycle is complete, run a complete cycle. Also turn down the heat on the hot water fed to the dishwasher. Try using water softener for better results.
You can also add vinegar in the final rinse cycle. Make sure that your soap dispenser drawer is opening and closing fine.
Hope this helps... Please post back if more information is required.
Daniel
Apr 20, 2011 | Amana 24 in. ADB2500AW Built-in Dishwasher
My glassware is not rinsing properly. It leaves detergent residue
The scum, film and white residueproblems have started since the reductionof phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
DishwasherResidue and Film on Dishes
heatman101
Apr 16, 2011 | GE Dishwashers
How did I get the film off my glassware? My glassware has a thick film that is very unappealing. I have to hand wash them. I use cascade detergent.
If you are not using a water softener use a rinse aid such as Jet Dry. This will help to eliminate scum on glassware. Use the solid form of Jet Dry. If you use a water softener you need to decrease the amount of detergent.
You can determine the cause of cloudy glassware by soaking a glass in vinegar for 5 minutes. If the cloudiness is removed it is a hard water deposit and more detergent is likely needed. If the cloudiness is not removed it is a permanent condition known as etching. In this situation, use less detergent and stop pre-washing. In actuality, dishwashing detergent needs a bit of soil to work on, otherwise it will tend to foam up.
Mar 12, 2011 | Whirlpool Dishwashers
#1 Dishes and glasses are not clean. Glasses come out with *** film. #2 Cascade gel soap residue in cup dispenser and on dishes close to it. #3 Not drying glassware in upper rack. #4 Black ***...
heatman101
Jul 14, 2010 | Kenmore 24 in. 17602 / 17604 / 17609...
My dishwasher is leaving the glassware spotted and filmy. Silverware is also being left with a film or in some cases residue from food.
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Dishwasher Residue and Film on Dishes
heatman101
Jun 25, 2010 | Frigidaire PLD4555RFC Dishwasher
A coating or film is left on my glassware. I use
Are you using powdered detergent? The liquid detergent will leave residue, but powdered doesn't, as least in my dishwasher.
Mar 11, 2010 | Dishwashers
My electrolux icon dishwasher leaves food residue in the interior of glassware and mugs. It has etched and left milky scratching permanent texture to all glassware. I have replaced glassware change...
heatman101
Mar 10, 2010 | Electrolux EIFLW55HIW Front Load Washer...
Bosch 24 in. SHX56B05 Stainless Steel Built-in Dishwasher Logo
95 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
