Question about GE Refrigerators
My problem is that my Freezer is working but then my refrigrator isnt working.
  • GE Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
Water Running in efrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Posted on Sep 11, 2010
Get freezer to work?
Defrost system component(s) failure or a failed evaporator (cooling coil) fan motor failure. The fan motor should be located in the freezer section.
Sep 16, 2014 | GE Refrigerators
I have samsung refrigrator model RL729WCSW since yesterday the Fan inside refrigrator has Hitting noise and the sound will Stop When The Door Is Opened.would you explain me how to rectify the problem. the...
The defrost is not working and the fan is hitting ice buildup...
Check out these tips...they can help you figure out what is going wrong with your refrigerator
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 21, 2010 | Refrigerators
Freezer of the refrigrator is not freezing. Norge,
sounds like the cold coil is freezing up and this is a defrost problem.. ck the defrost themo/ and the heater . / may also be the defrost timer . but every 3 mo ( i would think the defrost terminator is failing .. ) mm
Aug 09, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Freezer and refrigrator both not cold as supposed to be
make sure the compressor is working first,if not then replace the ptc overload on the compressor,if you have had lights blow out in the refrigerator section and theres a chattering/clicking sound in the rear and the new lights strobe dimly and the digital temp read-outs are dark,then its the main board in the rear thats bad
May 23, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer portion doesn't freeze.
check settings. if good check if compresor is running. a relay on compresor could fail
Feb 10, 2010 | Maytag Admiral Top-Freezer Refrigerator
Not cooling
Roy,
Are the evaporator coils in the freezer frozen up?
The evaporator is located behind the cover in the back of the freezer.
If so this may be a defrost issue.
The adaptive defrost timer may have failed.
This is located in the ref. side inside the front control pannel.
If not then you may have a freon leak.
This would have to be repaired by a qualified technician.
Jan 15, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Leak inside and outside of refrigrator
Hi, it is worth fixing. There is a drain plugged in the freezer. Get me model # and I can assist you further on this matter.
Thanks
Vic
May 22, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
The refrigrator is warm and fills up with water.Freezer to cold.
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jan 02, 2009 | Whirlpool ARC4030 Stainless Steel Top...
Refrigrator stopped working
Morning, This seems quite a easy problem to fix.! Check to see if the f/.freezer has to compressors (motors)? If so the you find that is more than likely to be that the fridge thermostat has broken. A very easy way of checking if you electrially minded is to remove the thermostat from the housing a connect the live and common wires together and switch on, It then should switch on if there is no other problems, Then just replace the stat.
Good luck......
Dec 29, 2008 | Whirlpool GB9SHKXL Bottom Freezer...
Refrigerators Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
