Question about Canon PowerShot SX100 IS Digital Camera
When I put knew batteries in my camera they die instantly. How do I rectify this problem?
    Brigadier General:
  • 11,967 Answers
The only thing that will deplete batteries that fast is that they are being shorted out. Anything odd in the battery compartment? Batteries inserted correctly? You may need service.
Posted on Sep 10, 2010
Hi, My kodak EasyShare M320, when I switch it on, the lens will come out and goes back instantly and die down. what is the problem?
I own a Kodak EasyShare but is a different model. If my battery is low this is the same thing that happens to my camera. You might try putting in a new battery and see if this resolves this issue.
~mike...
Apr 04, 2011 | Cameras
My mamiya rz67, which i have never used before, is making this long high pitched noise. i also dont feel the shutter is firing correctly.
Change the battery! This happened to mine too, I was terrified... never knew it took a battery until then, as I don't have a viewfinder with an inbuilt lightmeter. Unfortunately the rz needs it just to run, this is where the rb actually wins. The battery is underneath, you should be able to get a new one from a camera shop.
Dec 18, 2010 | Mamiya RZ67 ProII Medium Format Camera
OneStep Express Instant Camera: where do i put the battery in?...
The battery comes with the photo pack.
The photo packs are long out of production.
Remaining photo packs have flat batteries and are horribly expensive. They're only of use if you modify the camera (not easy without breaking it) to accept an external 6v power supply. Some photo packs are advertised as "fresh" due to refrigerated storage, but only the photo chemicals will be fresh as cold storage kills batteries even faster.
May 17, 2010 | Polaroid OneStep Express Instant Camera
Where is the battery located on the polaroid onestep express instant camera?
The battery is incorporated into the photo pack: you get a new battery when you change photo packs.
The problem is that all photo packs are now long out of date.(the last photo packs were manufactured nearly three years ago) and that batteries are likely to either be dead or to have insufficient power to finish a photo pack. Photo packs which have been kept refrigerated will have fresh photo chemistry, but cold kills batteries, so the only way that they're guaranteed to work is by modifying the camera to accept an external 6v power supply.
The expense of photo packs, their scarcity and the fact that most are now useless means that Polaroid Instant cameras are now worthless and virtually unusable. Last summer, a French company acquired the rights to remanufacture photo packs but has yet to announce a production date, but if they do go into production you can expect to pay at least £30 for just ten photos.
All photo formats eventually die: unfortunately Polaroid Instant has effectively done so along with some 35mm negative and transparency films.
Apr 10, 2010 | Polaroid OneStep Express Instant Camera
Hi, The rectifier of my honda CBR 1000f year of made: 1992 has just burned again. I had the old one replaced last november 2009. I want to know what the problem could be that the new one has burned. What...
The three yellow wires carry AC current from the generator to the rectifier. The rectifier turns this AC current into DC current and sends it back to the battery through the red and the black wires. I am not certain what the purpose of the 7th wire is on the new rectifier except that it may be used for thermal sensing of the rectifier - which would explain why it is mounted tight to the unit.
Of all the components that make up your Honda's charging system, the rectifier is the most likely to fail. The reason is usually excess temperature buildup - which causes the diodes inside it to fail. If you are running extra electrical accessories on your bike, this can cause the rectifier to overheat and die. Same thing if you frequently let the bike sit until the battery goes dead, the rectifier works hard to recharge it each time.
You may be able to extend the life of the unit by avoiding things that put extra strain on it, as described above. Also make sure there's nothing covering the cooling fins on the rectifier - or blocking airflow to it (dirt, that extra pair of gloves stuffed next to it, etc.).
Finally, there's one thing that will kill the rectifier instantly: connecting the battery cables backwards. That'll fry it every time.
Jan 15, 2010 | 1992 Honda CBR 1000 F
Nexia Q1 is flashing low battery when i put in brand new ones
Use alkaline batteries or rechargeable ones with over 1000mA
Dec 29, 2008 | Fuji Nexia Q1 APS Point and Shoot Camera
My camera dies way too fast
If you use a lot of batteries, it is a good idea to have a battery meter (tester). Radio shack has one for about $5. I say this because I've seen a lot of "brand new" batteries that aren't any good, especially imports. AA, AAA, C,D batteries should all read at least 1.5 volts dc. Under test, if the battery voltage drops slowly, it is bad. A very good battery will actually show a slight increase in voltage under load. Make sure the polarity (+,-) of the batteries installed is correct.
If you are sure you have the correct memory card and it still doesn't stay in, it could be that the retainer tab is broken. If this is the case, try inserting a small piece of paper as a shim, and that may hold it in place.
If the camera is under warranty, you may want to return it.
I hope this helps.
Nov 25, 2008 | Samsung S860 Digital Camera
Kodak Z740 digital camera
TIPS:
1.)NEVER PUSH THE LENS IN AFTER CAMERA DIES, BUY A NEW BATTERY IMMEDIATLY AND TURN IT BACK ON, CLOSING THE LENS!
2.)NEVER USE AN AC ADAPTER, USE A RECHARGEABLE BATTERY OR A REGULAR BATTERY!
..to fix this...
Do as i say..
1.) Remove battery
2.) Remove front plate (screw driver may be needed)
3.) Check all gears, make sure they are correctly fitted in place)
4.) Move the gear manually to make the lens come out.
5.) keep it out, put the front plate back together.
6.) reinsert the battery, turn it on.
or...
1.) Remove the battery.
2.) Wait about 6-8 hours.
3.) Reinsert the battery.
or...
2.) Try hooking it up through AC adapter, put correct voltage.
3.) Try turning it on.
4.) Remove AC adapter, reinsert battery.
5.) Turn it on.
If nothing happens just tell me..
Hope this may help;
Regards,
VOTIT
Oct 08, 2008 | Kodak EasyShare Z740 Digital Camera
Camera lense
There is a very very easy way to fix this problem..
This can happen if...
1.) If the battery dies when the camera lens is open (and you close it manually, or sometimes, even if you dont.)
2.) If you used a AC adapter with too much voltage or not enough. (this can happen even if you used the correct voltage, refrain from using AC adapters at all)
... all together its ethier a voltage or camera lens problem...
TIPS:
..to fix this...
Do as i say..
1.) Remove battery
or...
or...
5.) Turn it on.
Hopefully all this information helped,
May 05, 2008 | Minolta Vectis 2000 APS APS Point and...
Changing battery in one600 camera
The battery is in the film pack. The one600 doesn't use any other type of battery except what comes with the film.  Either the film is really old and the battery died or it's defective.  If the film is relatively new and you haven't been able shoot all 10 shots, then you might call the manufacturer for a replacement.  Otherwise, I'd buy a new film pack.
Mar 03, 2008 | Polaroid One600 Ultra Instant Camera
Canon PowerShot SX100 IS Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
